Old 04-04-2013, 10:05 AM   #526
Mattman2010
Mattman2010's Avatar
Re: 85 GMC Sierra Classic 1 Ton Crew Cab
Got some parts in.
Got the sending unit, 3/4" pipe thread plug with weld in fitting for a drain in the bottom of the tank, also got some 1/2" T-bolts for the fuel tank straps (Yeah probably over kill, but this thing is called "The Tank" haha), also got a vent for the tank, but thinking about using a different setup already because with this vent just mounted on the tank I could easily overfill the tank and this vent wouldnt work. Thinking about putting an AN fitting in the tank and get some hose and mount a filter up higher on the bed or something like that because Dieselwrencher gave me a couple more different ideas for filling the tank that I plan on looking at today.
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 04-04-2013, 02:54 PM   #527
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
You should just get an antirollover vent from a place like speedway motors. That way if the DOT ever checks, it will be legal.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 04-04-2013, 03:30 PM   #528
Mattman2010
Yeah I will look into those.
Test fitted the tank. Gotta cut the rear cross member out and weld it in and then get some angle iron for the front of the tank for its mount. Not sure what to run as a buffer between the tank and the cross member mounts.
Build Thread
Build Thread
Thread
Old 04-04-2013, 07:33 PM   #529
maxxxy
maxxxy's Avatar
On my gas tank I had an 1/8" thick old tractor tire inner tube that I cut into strips and used those to cushion it from squeaking.
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
Old 04-04-2013, 09:32 PM   #530
ryanroo
ryanroo's Avatar
looks like a roll over vent in the picture?
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 04-04-2013, 10:41 PM   #531
Dieselwrencher
Matt, shake it. Does it rattle?
Ryan
Old 04-04-2013, 11:39 PM   #532
Mattman2010
It is. There is a filter on the top of it but there is no way to put a hose on it. With the way that I am planning on putting my filler I could easily over fill it and have fuel running out of it. Thinking about using the stock filler up under the drivers side bed rail, seems to be plenty of room for it there.
It does!
Build Thread
Build Thread
Thread
Old 04-05-2013, 12:07 AM   #533
Mattman2010
Yeah I have been thinking about using an old inner tube for the cushions as well I have a couple laying around.
Build Thread
Build Thread
Thread
Old 04-06-2013, 05:34 PM   #534
Mattman2010
Today I started messing around with the cross members for the tank. Need to get it basically mounted so I can figure out where to best put all the fittings for my tank.
Rear cross member
Front cross member
over view of how the tank sets in the frame
Kinda what my mount situation will look like
You can see the steel plate i have at the back of the tank, that will be cut in half and welded to the top of the rear cross member. It will be where the tank pushes up on when the straps are tightened down. The front cross member is a piece of angle iron so the tank will push up against that.
I am also looking at ways to fill the tank. Right now I am looking at using the stock filler and mount it in under the drivers side bed rail kinda like so.
I then plan on making a box that looks like this for housing the stock filler.
Build Thread
Build Thread
Thread
Old 04-08-2013, 11:48 PM   #535
Mattman2010
Messed around with the tank some more today. got the front cross member tacked in and then started working on the tank straps.
Front mounts started for straps.
Rear mounts have yet to be finished.
Build Thread
Build Thread
Thread
Old 04-09-2013, 08:07 AM   #536
ryanroo
ryanroo's Avatar
fancy drawin' program you got there!
the straps are looking good. are you going to weld that wrapper back to the flat bar where it wraps the T-bolts?
72 K20 12v build
Old 04-09-2013, 09:11 AM   #537
Mattman2010
Yes I am. I just want to make sure they are right before I weld them.
Build Thread
Build Thread
Thread
Old 04-09-2013, 06:32 PM   #538
Mattman2010
Well today I got the rear tank strap mounts made and tacked on and the tank is now supported by the straps!
Also rolled the frame out of the shop to clean the shop up, snapped some pictures so you can see the whole frame.
Only got half of my shop cleaned, its starting to look like its going to rain and didnt want the drivetrain to get rained on.
Now I just need to make sure I know what size I need for all my fittings and know how many I need. Then weld those in and weld the top on and I will pressure test it then.
Build Thread
Build Thread
Thread
Old 04-12-2013, 10:32 PM   #539
Mattman2010
Well i got some more stuff done on the truck today and managed to spend my whole last pay check on some more parts.
Ground down the ugly ass welds that I had on the outside of the tank.
I then moved on to make the rear sway bar work again.
I order new brake lines tonight as well and I needed to get the shocks mounted where I wanted them before I got the brake lines and started running them so I also got the shocks tacked up today.
Should be getting some parts in next week and be able to finish up the fuel tank and then I will probably be broke and have nothing to do for a while haha
Build Thread
Build Thread
Thread
Old 04-15-2013, 04:19 PM   #540
Dieselwrencher
Looking great Matt!
Ryan
Old 04-15-2013, 05:23 PM   #541
bohmankid
bohmankid's Avatar
Thanks for the idea on the fuel tank filler I've been having the hardest time trying to decide where to mount mine since I've done my burban tank swap.
bohmankid is offline   Reply With Quote
Old 04-16-2013, 08:35 PM   #542
Mattman2010
Looking great Matt!
Thanks bro!
No problem man, I put my ideas on here so other people can use them as well!
Well today was kind of exciting, I had been waiting on a box to show up.
Its getting twins!
Build Thread
Build Thread
Thread
Old 04-17-2013, 01:11 AM   #543
Dieselwrencher
Ryan
Old 04-23-2013, 03:04 PM   #544
Mattman2010
Been looking at ways to mount the turbo and I think I have kinda came up with a plan. Before I really get into it I need to stick my cab and a front clip on the truck to make sure I have enough room for my idea. Pretty sure it will have to move forward a little bit tho.
Hoping to make a mount that comes off of the exhaust flange that ties into the motor and then a bracket going down from that to around where the motor mount bolts. Then 5" exhaust out the wheel well back to my 8" stack that I will be running.
Build Thread
Build Thread
Thread
Old 04-23-2013, 03:54 PM   #545
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 04-23-2013, 04:07 PM   #546
Mattman2010
Originally Posted by 1985-GMC View Post
Good thing your not close enough to puke on me. I like stacks!
Build Thread
Build Thread
Thread
Old 04-23-2013, 04:58 PM   #547
bohmankid
bohmankid's Avatar
Same here. Hell, I put stacks on my gasser for a month or so. It was fun.
Old 04-23-2013, 05:11 PM   #548
maxxxy
maxxxy's Avatar
If done right stacks are awesome! I mean, what's cooler than big shiny chrome pipes spewing black smoke out of the top?
Max
Max's bagged 81
Old 04-23-2013, 05:43 PM   #549
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Sweet build man, I don't know how I missed it, going to be one hell of a truck.
I am always glad to see another classic Chevy with a Cummins sitting between the fenders.
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 04-23-2013, 06:17 PM   #550
Mattman2010
Stacks on a gasser make me puke...
No chrome for me! Hate chrome!
Thanks man!
Build Thread
Build Thread
Thread
