Old 05-04-2013, 12:23 AM   #526
G&R's57GMC
G&R's57GMC's Avatar
Re: Danny Boy is BAACK! w/ '55 Big Window
Here's a theme that you might consider, OR not ...
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 05-04-2013, 01:07 AM   #527
Dan in Pasadena
Dan in Pasadena's Avatar
Oh, you mean military themed cause my truck is sorta/kinda Army drab? Hadn't thought of that but I wouldn't do it because I was never in the military. I'd feel like a phony.
Side note? I went to high school from '68-'72. For my Frosh thru Junior year I just assumed I'd get drafted and be going to Viet Nam. My lottery number was #49 so I KNEW I was screwed. I was classified 1A. Then Nixon put a hold on new draftees and I was reassigned 1H - for "Holding". I lucked out, but I was on edge for awhile there.
Dan in Pasadena is offline   Reply With Quote
Old 05-04-2013, 11:51 PM   #528
Dan in Pasadena
A bunch of errands took up the morning but managed to do a little. I've got four of these uglies to repair.
Tossed my first attempt as I'm trying to get a tighter fit. I finally just pulled the latch actuator so I could get my arm down inside the door to hold the blank directly against the hole. Since door has "waves" from the factory so you've gotta make sure the patch is "clocked" right or these waves will not look right afterward. Using a piece of cardboard you never know. Putting the patch directly on the inside ensures it's clocked right.
Ground paint off all around & on small screw holes.
Close up #1. So far, so good!
Close up #2, NOT as good but it's gonna have to do:
Old 05-05-2013, 12:31 AM   #529
Kim57
Kim57's Avatar
Looks good.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 05-05-2013, 12:49 AM   #530
SCHRUMGMC
SCHRUMGMC's Avatar
What is with the Hole ?
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 05-05-2013, 01:13 AM   #531
Dan in Pasadena
It's a speaker hole the original owner cut into the door. Problem is there are two of them in EACH door! They're like 5" diameter too. Short of replacing the doors ($$$) there's no other way to address them. Unless I put speakers back in them - NOT. They looked amateurish....cause they are!
Old 05-05-2013, 01:52 PM   #532
rgunlock
rgunlock's Avatar
Hi Dan. As I mentioned in your other welding thread, I'm not that far ahead of you on this patch panel welding, but I do have a suggestion that has worked for me. On panels you can't really get behind for tracing. Cut out a patch that is a shape you desire, and large enough to cover both the speaker hole and why not, the screw holes as well. Lay it on the face of the door over the hole. Your wavy profile should lay right in. Trace around the edge of the patch itself onto the door. Then cut the door to fit your patch. I think you'll get a lot closer on the first cut and have less fitting to worry about.
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 05-05-2013, 06:32 PM   #533
Dan in Pasadena
Thanks Rick. That approach would make my patch bigger though, wouldn't it?
After thinking it over, I can try it and see how it works.
A square patch with straight sides WOULD be much easier than trying to make a custom, squiggly edged patch. I'll give it a shot and post the results!
Old 05-05-2013, 06:50 PM   #534
rgunlock
rgunlock's Avatar
You wouldn't have to cut out much more of your door if your patch only slightly overlaps the existing hole. But I do think it would make matching the patch to the hole much easier. Besides, you already have a pretty large gaping hole anyway, right
Rick
Old 05-05-2013, 07:46 PM   #535
Dan in Pasadena
Originally Posted by rgunlock View Post
...Besides, you already have a pretty large gaping hole anyway, right
Ha ha, yeah. The only thing that WON'T fit in that hole right now is my entire head!
But seriously, I should be able to cut a square hole with straight sides much much easier than the way I've been trying to do it.
I'm wondering if I can cut my patch on my tablesaw if I put a metal cutting blade on it? Much straighter, cleaner cut & easier than by hand using my angle grinder!
Old 05-05-2013, 08:37 PM   #536
Baldeagle SR
Dan I use a saw zaw it works good for cutting , Just brace your metal in a vice or use vice grips to hold it . Rich
Baldeagle SR is offline   Reply With Quote
Old 05-05-2013, 10:07 PM   #537
rgunlock
rgunlock's Avatar
I don't think I'd use the table saw. I've had pretty good luck using a jigsaw with a metal cutting blade, but as Baldeagle said, be sure you brace the metal you are cutting firmly. Otherwise, it will try to bounce around and makes it tough to keep a straight cut going.
Rick
Old 05-05-2013, 10:29 PM   #538
Dan in Pasadena
I've been planning to cut the "blank" out of the spare door using the angle grinder - but it is hard (for me) to get a true straight line. Which is why I mentioned using the table saw - to "square up" the blank prior to placing it over the hole for tracing.
Then there's cutting the hole out of the door after I've traced it. In my experience, a Sawzall or a jig saw will be hard to control on the wavy metal the doors have. I can try it but I've got minimal metal to spare here and still three blanks to make.
Old 05-05-2013, 11:18 PM   #539
SCHRUMGMC
SCHRUMGMC's Avatar
I've seen people cut the Panels half Assed, and it really makes me mad..My Ocd goes insane
1971 GMC Sierra
1959 GMC 100
Old 05-06-2013, 12:42 AM   #540
Kim57
Kim57's Avatar
I use a cheap delta table saw with a metal cutting wheel all the time for cutting sheet metal. You just have to go slow and let the saw do the work.
Kim
My build thread
Old 05-06-2013, 12:47 AM   #541
SCHRUMGMC
SCHRUMGMC's Avatar
In a perfect world, the Metal would cut itself the Perfect way by itself
1971 GMC Sierra
1959 GMC 100
Old 05-06-2013, 01:19 AM   #542
Dan in Pasadena
I'm not a good enough welder to be able to get away with half-assed fitting patch panels. GOTTA be well fitting or I'm gonna blow holes. Hell, I may blow holes anyway!
I'm feeling a little case of "anal glaucoma" coming on (I can't see my ass going to work tomorrow!) so I may have photos to share tomorrow!
Old 05-07-2013, 11:14 PM   #543
Dan in Pasadena
I know this is old hat for most of you but it's my first time attempting patch fabrication and weld repair. So I've been cutting, fitting, grinding, & cussing the last few days. I've got all four patches to this level of fit:
Each patch needs some touching up along the edges for final welding. I'm not sure if that'll happen tomorrow or have to wait for the weekend.
I DID go out and get some of those sheet metal clamp things but they leave a .040" gap around their perimeter and someone(?) told me the rule of thumb is the gap shouldn't be bigger than your wire - .023" in this case. So I think I'm just going to use the magnets shown in the photo.
Any/all opinions appreciated.
Old 05-07-2013, 11:18 PM   #544
Dan in Pasadena
PS: A big thanks to "rgunlock" (Rick) for his advice to cut the patch first and match it to a square hole. It was MUCH easier than trying to make 4 wavy round patches.
Plus, I'm such a bonehead. I cut 2-1/2 of the patches before my jig saw blade broke. Went and bought a much finer blade and the rest of the cutting was butter.
Old 05-08-2013, 12:08 AM   #545
Kim57
Kim57's Avatar
The patch looks good.
Kim
My build thread
Old 05-08-2013, 01:25 AM   #546
Daze57
Daze57's Avatar
x 2 ^
Daze57 is offline   Reply With Quote
Old 05-08-2013, 01:28 AM   #547
SCHRUMGMC
SCHRUMGMC's Avatar
X3 !
1971 GMC Sierra
1959 GMC 100
Old 05-08-2013, 07:18 AM   #548
rgunlock
rgunlock's Avatar
Hot diggity!!! That may well have been my 1st actual useful post then
That patch does look like it fits very well.
Rick
Old 05-08-2013, 07:57 AM   #549
indynick
indynick's Avatar
Coming along nicely
indynick is offline   Reply With Quote
Old 05-08-2013, 10:54 AM   #550
Dan in Pasadena
Thanks for the positive comments guys.
Like I said before, it feels like Chinese water torture...one drip of work at a time...
I WILL get rid of all the rust, the feels like hundreds o miscellaneous holes drilled in it over the years, but there are SO many small areas to be dealt with!
