Old 08-31-2017, 05:02 PM   #526
tinydb84
tinydb84's Avatar
Re: Project "Steppin Wolf" LS swap
I would have thought that the truck would run 12's with that engine and some slapper bars. Turbo is cooler though!
I think it is going to be a bit too small though. Going from rear mount to front mount will require it to move a lot more air.
David
Instagram: myfabguy
Old 08-31-2017, 05:59 PM   #527
Liltroy
Liltroy's Avatar
It probably would have been a low 13 or high 12 second truck on motor alone with a stall. But with a stock converter and a 2.25 60ft, it just wasn't happening.
This turbo is definitely small but I payed $150 for the whole rear mount setup after selling the headers that came with it so it'll do for now. It was making almost 500 whp on the firebird in a rear setup so it should be good with what I'm trying to do. If not I'll upgrade later. Good thing about it is it should spoil right off idle so will feel more like a supercharger and with a stock stall that's exactly what I'm looking for. Like I said when I first started this build, I'm not looking for a drag strip monster, I'm looking for a fun daily driver. I'm pretty sure I've got the right combo for that goal.
74 Stepside"Steppin Wolf":78mm Turbo LQ4/4L80e,BTR stage 3 Truck cam,3.73 12 bolt with Detroit True-Trac
Project Steppin Wolf Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=670303
My Youtube channel "Bad Luck Garage" https://www.youtube.com/channel/UCRP...XkeEPCu_HmRfuw
Liltroy is offline   Reply With Quote
Old 10-02-2017, 11:18 PM   #528
Liltroy
Liltroy's Avatar
Alright gentlemen(and ladies), Turbo build is moving along great! I started a playlist that shows nitrous runs and then all the custom fab work we've done for the turbo set up. You can check it out here..
https://www.youtube.com/playlist?lis...2gHi_EKoCBYBkr
Old 10-02-2017, 11:25 PM   #529
Liltroy
Liltroy's Avatar
The entire hotside was fabbed together from junk. We chopped up a set of 6.0 manifolds, then made the crossover out of pieces of old exhaust we had laying around.This was the beginning.
Old 10-02-2017, 11:27 PM   #530
Liltroy
Liltroy's Avatar
Then I wrapped them and installed them on the truck.
Old 10-02-2017, 11:29 PM   #531
Liltroy
Liltroy's Avatar
intercooler has also been mounted and all coldside piping cut and run.
Old 10-02-2017, 11:31 PM   #532
Liltroy
Liltroy's Avatar
Oil pan has been tapped, feed line ran, etc. Dont have anymore pictures but lots of video of this whole process here:
Old 10-11-2017, 09:49 PM   #533
DPowers
DPowers's Avatar
Nice to meet you today. Cool build
DPowers is offline   Reply With Quote
Old 10-11-2017, 10:32 PM   #534
Liltroy
Liltroy's Avatar
It was good to meet you too! and thanks!
Old 11-24-2017, 09:07 AM   #535
Liltroy
Liltroy's Avatar
Ok guys here it is! FIRST DRIVE OF THE TURBO C10!
https://www.youtube.com/watch?v=k9eKkrQv6qA&t=25s
Old 11-29-2017, 07:16 PM   #536
Liltroy
Liltroy's Avatar
This is how much it cost me to do a completely custom budget turbo set up on my ls swapped C10!
https://www.youtube.com/watch?v=RybOvdANTMA
