Old 10-31-2017, 02:10 AM   #526
MiraclePieCo
MiraclePieCo's Avatar
Re: What did you do with your truck today, Part 3
Originally Posted by MARTINSR View Post
I didn't have a drain to clean so I got out in the garage and tacked the patch panel in place. WHOOO HOOOOO!
Brian
You always do such nice work Brian, then still have time to answer all our newbie questions on this forum!
MiraclePieCo is offline   Reply With Quote
Old 10-31-2017, 10:00 AM   #527
MARTINSR
MARTINSR's Avatar
LOL, thanks so much but I am not doing crap out in the garage, my "five minutes" is about it. I like sitting in my warm house and helping the newbes more these days the older I get.
Thanks so much for the kind words.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 11-02-2017, 03:45 AM   #528
MiraclePieCo
Installing an SBC in my '51 panel, things were getting pretty congested on the driver's side with exhaust, steering shaft and motor mounts all competing for the same space. So rather than use conventional mounts off the frame rails, I decided to fabricate some vertical motor mounts upward from my OEM MII crossmember. They solved my interference problem, they're well triangulated for strength, and I think they're kinda graceful-looking too! Will finish weld them after the motor comes back out from its trial fit.
Old 11-02-2017, 02:18 PM   #529
b-mac
b-mac's Avatar
Awesome work! But no rubber or urethane? Think it will rattle your teeth?
b-mac is offline   Reply With Quote
Old 11-02-2017, 10:03 PM   #530
MiraclePieCo
Stock Chevy rubber isolators bolt on the round tubes at the top - I just removed them for the photo to show the entire mount.
I pulled the engine today so here's a better photo of the mounts:
Old 11-02-2017, 11:26 PM   #531
Black_Sheep
Black_Sheep's Avatar
I managed to get the freshly painted column, u-joint and DD shaft installed without harming the finish on anything. I want to use stainless nylocks to couple the shaft to the rag joint but nobody local has fine thread stainless lock nuts. Go figure! I had to do a Bolt Depot order anyway, so I've got some coming. I also spent an hour looking for the stud plates for the lower inner fender brackets, they have to be around here somewhere...
Black_Sheep is offline   Reply With Quote
Old 11-02-2017, 11:59 PM   #532
MARTINSR
MARTINSR's Avatar
DAMN that's purty!
Brian
1948 Chevy pickup
Old 11-03-2017, 01:47 PM   #533
crossfire84
crossfire84's Avatar
what he said^^^^
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 11-03-2017, 08:18 PM   #534
OrrieG
OrrieG's Avatar
I have order from Fastenal to get had to find hardware.
https://www.fastenal.com/products;js...rm=nylock+nuts
Interior looks killer.
OrrieG is offline   Reply With Quote
Old 11-03-2017, 08:38 PM   #535
Black_Sheep
Check out boltdepot.com OrrieG, no minimum quantities and reasonable prices...
Old 11-03-2017, 10:12 PM   #536
evilokc
got a needle & seat and a new throttle cable to install. supposed to be beautiful tomorroe. hope it will be a fruitful day
evilokc is offline   Reply With Quote
Old 11-03-2017, 10:19 PM   #537
Black_Sheep
Got a good start on the floor plate and stumbled across the stud plates for the inner fender brackets when I was looking for something else...
Old 11-05-2017, 10:41 AM   #538
Black_Sheep
Finished up the floor plate and trimmed the inner fender panels to fit the smooth firewall. They will end up being the same satin white as the firewall...
Old 11-05-2017, 08:11 PM   #539
mud.man.rj
mud.man.rj's Avatar
Under hood....wow.
Mudman.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 11-05-2017, 08:57 PM   #540
Black_Sheep
After a lot of measuring and a little tweaking to get the cab square on the frame I torqued the cab mount bolts down. Same deal with the core support, it's now straight and square with the cab too.
I still had a couple hours of free time before my granddaughter's birthday party so I bolted the freshly painted grille brackets onto the grille with some 1/4" stainless flange bolts and made up a 6AWG cable to feed power to the cab. The insulated stud will provide a handy place to connect a timing light...
Old 11-05-2017, 10:25 PM   #541
evilokc
it was a good day in the garage. I installed the new needle and seat. I'm hoping that corrects my flooding issue. I ran it in the garage and had no issue but wont know for sure until I drive it. I changed out my broken throttle cable with the new holley cable. the quality difference between the cheap knock off cable and a real braided cable is ridiculous. lesson learned about being cheap when it counts. with the new cable I was able to use the new throttle bracket that I had to remove because the cheaper cable was binding. so as it sits throttle cable on, front float level correct, fuel pressure at 6psi. I only backed the truck out of the garage and then back into its spot but the pedal feel is night and day from the old cable. I need to raise the rear float but all is well in evil truck land tonight. heres a couple of quick pics. washing the motor was not on my list of needs.
Old 11-05-2017, 10:33 PM   #542
svr
svr's Avatar
Worked on my wheel tubs today, carved out a new set of dyes for my bead roller so I could put a matching stiffener in the side to match the original bed pattern. Then rolled a flange around the arc of the side pieces so I dont have to butt weld them in. Punched some holes so I can spot weld the inside and then weld the outside. Need to get some long clamps or vise grips so I can clamp the side tight as I weld them.
57 short box, 235, T5, C4
http://67-72chevytrucks.com/vboard/s...d.php?t=739132
svr is offline   Reply With Quote
Old 11-05-2017, 10:34 PM   #543
svr
svr's Avatar
Another
Old 11-05-2017, 10:37 PM   #544
evilokc
how wide are you going on the wheels?
Old 11-05-2017, 10:39 PM   #545
svr
svr's Avatar
Current tires are 285 wide, with stock C4 rims and 1 1/2" spacers they barely work and clear both inside and outside. Would need exactly the right rims to work without spacers so this will allow some wiggle room. So im adding 5" to clear my sway bar links and leave room for more tire just in case someday.
Old 11-05-2017, 10:40 PM   #546
svr
svr's Avatar
Rolling the flange
Old 11-05-2017, 10:41 PM   #547
svr
svr's Avatar
Ready to weld in
Old 11-06-2017, 11:25 PM   #548
Kevin Mac
Kevin Mac's Avatar
Nothing to special here, but I did manage to save some money on bed end brake lights. The plugs were already there so I found some 1" trailer marker lights to make them out of. The stock brake lights are none too bright so it is more a safety thing for me.
Mac
Kevin Mac is offline   Reply With Quote
Old 11-07-2017, 01:10 AM   #549
evilokc
Mac
dude those look cool. good work.
Old 11-07-2017, 07:51 AM   #550
DeeJayNOLA
DeeJayNOLA's Avatar
I'll be moving out to Albuquerque soon {like before Christmas}with or without my '49 Chevy 3600. But definitely with my '53 IH Travelall. See you in the desert.
Representing for the 504.
DeeJayNOLA is offline   Reply With Quote
