Old 04-04-2012, 04:00 PM   #551
Kim57
Kim57's Avatar
Re: My 57 Pro Street
The UPS guy was my friend today.
AAW Highway Series 22.
Looks like a real nice kit.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 04-04-2012, 04:59 PM   #552
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
Nice, are they universal or specific to the LSx?
Tri5
1955 Chevy Stepside/LS1 drive train
http://67-72chevytrucks.com/vboard/s...d.php?t=371513
Tri5Nerd is offline   Reply With Quote
Old 04-04-2012, 05:27 PM   #553
Kim57
Kim57's Avatar
Tri5
It's a universal set. I probably could have gotten by with less circuits but I would rather have to many than not enough. With this kit I only need to put in the wires I will use so i wont have a bunch of extras hanging around.
Kim
My build thread
Old 04-04-2012, 06:03 PM   #554
Tri5Nerd
Tri5Nerd's Avatar
Kim
Does it have for multiple radiator fans? I'm asking because I'm going to try to use the LS1 radiator and fan setup and it has 2 fans.
Tri5
Old 04-04-2012, 06:51 PM   #555
Kim57
Kim57's Avatar
Tri5
It has 1 wire for the radiator fan. I'm sure if you contacted them they would be able to let you know if your fans would work. I plan on running 2 fans myself but they will be after market so I'm going to have to research that.
Kim
My build thread
Old 04-05-2012, 01:42 PM   #556
_Ogre
_Ogre's Avatar
you can never have too many circuits in your truck
by the time you add all the options they will disappear fast.
my preference is to run the fan directly off the battery and only use the fan circuit to feed the relays for the fans.
i have a distribution block in my console, heavy cable from battery to the dist block.
panel feed, stereo amps (fused at block), fan (30a breaker), vintage air (30a breaker) and my motor feed (ram jet harness 50a maxi fuse)
all run off the distribution block
shop air compressor timer
Old 04-05-2012, 01:44 PM   #557
GeorgeVale
Love the firewall and trans tunnel Kim you are making some great process and the quality of the workmanship is supreme. Re the radiator fans shouldn't they be supplied direct from the battery via a relay. ta George
GeorgeVale is offline   Reply With Quote
Old 04-05-2012, 03:38 PM   #558
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: My 57 Pro Street
A little up date.
I needed to make my trans hump so here's what I did.
I made a frame out of some round stock and then made some templates out of heavy card stock.
Kim
That is a sweet setup!
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 04-07-2012, 09:49 AM   #559
AUSSIE54
AUSSIE54's Avatar
G'day Kim,
Fantastic job on the firewall. Very neat indeed!
Regards,
Trently
AUSSIE54 is offline   Reply With Quote
Old 04-07-2012, 04:57 PM   #560
OKGMC4
OKGMC4's Avatar
You could always de-pin the circuits you don't need. I took out my extras very carefully at the rear of the block and stored them in baggies for later use if I ever need them. It really cleans up under the dash not having the extras in the way. You'll find that there are a BUNCH of circuits you won't use because of the LSx harness.
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 04-07-2012, 08:17 PM   #561
Kim57
Kim57's Avatar
Originally Posted by AUSSIE54 View Post
G'day Kim,
Regards,
Trently
Thanks Trently.
That's why I went with the AAW kit because I only put in what I need.
Kim
My build thread
Old 04-08-2012, 11:38 AM   #562
Madd Doc
Madd Doc's Avatar
Is there any down side leaving the vent as is aside from debris getting in there? I live in a very wet area and have concerns about water getting in and rusting. I still like the idea of fresh air and mine seems rust free but if its a common area for rust I might have to close it up as well.
My build thread
http://67-72chevytrucks.com/vboard/s...14#post5273714
“I would rather spend 2 hours making a part that cost $2.00”
Madd Doc is offline   Reply With Quote
Old 04-08-2012, 02:53 PM   #563
Kim57
Kim57's Avatar
My build thread
Madd Doc
The only down side to leaving it open is that stuff can get in and cause a rust problem.
The rust wasn't my concern as I saw one at a show with it closed and liked it so that's why I did it.
Kim
My build thread
Old 04-08-2012, 06:05 PM   #564
Madd Doc
Madd Doc's Avatar
Ok thanks, awesome job on that fire wall, look great.
Old 04-09-2012, 10:01 PM   #565
Denee007
Denee007's Avatar
Just when I think I'm doing something miraculous by filling a few holes in my firewall, I see your build and immediately Wowed! Your work is incredible! ; )
Ps- I'm going to check into that wiring kit that you bought! I'm not ready for it, but have to keep my credit card ready for things that I'll need!
Dne'
Denee007 is offline   Reply With Quote
Old 04-11-2012, 12:58 AM   #566
Kim57
Kim57's Avatar
A little up date.
Got my headers in.
Two different sets #1= 1-3/4' primaries with a 3" collector.
#2= 1-5/8" primaries with a 2-1/2" collector.
Had to go with #1 because #2 would interfere with the brake pedal even though #2 cleared better on the passenger side.
Was probably going to use them anyway because of the larger primaries. Everything I've seen on the LS engines shows they like them.
Kim
My build thread
Old 04-11-2012, 01:05 AM   #567
Kim57
Kim57's Avatar
As you can see in the previous post #1 fit really well on the passenger side. It looked the same on the drivers side until I put my brake pedal on. The collector dumped right where the pedal comes out of the firewall.
#2 fits just fine on the drivers side but gets a little close to the frame on passenger side. It sticks out a little further to clear the starter. A little work on the frame will cure that problem.
The last pic is the bracket to raise my AC pump up.
Kim
My build thread
Old 04-11-2012, 01:07 AM   #568
Kim57
Kim57's Avatar
I sent the headers out to get ceramic coated after I cleaned the welding slag up a little.
Kim
My build thread
Old 04-11-2012, 01:07 AM   #569
55Cameo
55Cameo's Avatar
Looking realy nice. love the progress so far. Like the headers, may have to look into those
55Cameo is offline   Reply With Quote
Old 04-11-2012, 01:11 AM   #570
Kim57
Kim57's Avatar
Thanks.
They're Sanderson headers. Just under $500 coated. They make a few different sets for the LS engines.
Kim
My build thread
Old 04-11-2012, 01:15 AM   #571
55Cameo
55Cameo's Avatar
Sounds good for what you have. I like how tight it tucks with the space limitations. Makes it look clean
Old 04-11-2012, 07:52 PM   #572
lowdownstar
big guy
lowdownstar's Avatar
Looking good Kim!
lowdownstar is offline   Reply With Quote
Old 04-11-2012, 11:23 PM   #573
oldman3
oldman3's Avatar
Sweeet.....Jim
oldman3 is offline   Reply With Quote
Old 04-19-2012, 05:44 PM   #574
Kim57
Kim57's Avatar
Just a small update.
Got the headers back from being ceramic coated. They even got the stuff inside the primaries and collectors.
Got the frame notched to clear the passenger header. Will be welding in a piece of schedule 40 pipe to finish it off.
Also got the fire wall set back all welded in and ground down.
Now I'm trying to find a seating arrangement that I can live with that wont cost a fortune.
Kim
My build thread
Old 04-19-2012, 06:46 PM   #575
renegade8720
Looking Good!!!!!
renegade8720 is offline   Reply With Quote
