Old 06-18-2011, 10:08 PM   #551
mooseknuckles
mooseknuckles's Avatar
Re: My 86 build
it still needs some work around the tailgate to get it fitting beter to close right, but everything else turned out ok. just didnt go as smooth as I thought it would.
mooseknuckles is offline   Reply With Quote
Old 06-18-2011, 11:22 PM   #552
mcboomport
mcboomport's Avatar
Re: My 86 build
Nice work!
mcboomport is offline   Reply With Quote
Old 06-19-2011, 09:33 AM   #553
mooseknuckles
Re: My 86 build
....I'll see if I can make it better today!
Old 06-19-2011, 05:15 PM   #554
mooseknuckles
Re: My 86 build
...did some more work on the bed floor today, I had to take the pass side off and do a little trimming to get it to fit perfect, also got the headboard nice and tight and welded it on. I have a few more holes to drill and I'll have to get some longer bolts tomorrow. and still have to finish up arond the back panel and tailgate...
Old 06-20-2011, 08:33 AM   #555
luifer76
luifer76's Avatar
Re: My 86 build
it looks really good bro....great job.....
nOtHiNg LiKe ThE gOoD oLe ChEvYs....
luifer76 is offline   Reply With Quote
Old 06-20-2011, 06:25 PM   #556
mooseknuckles
Re: My 86 build
thanks man.
Old 06-21-2011, 10:31 PM   #557
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Re: My 86 build
Great build man! questins for ya. how hard was it to cut off your rear axle perces and re weld them on and than find the pinion angle? i'm thinking about doing my own home made rear flip...
If it aint square, I don't care.
84 C35 CC Dually Project log...
http://67-72chevytrucks.com/vboard/s...d.php?t=414892
1tonchevy is offline   Reply With Quote
Old 06-22-2011, 05:53 PM   #558
mooseknuckles
Re: My 86 build
I had to use a 4 1/2" grinder with a cut-off wheel, it was a ***** because its hard to get at, but a plasma would be way easier...on the pinion angle I just got it close to where I thought it looked in line with the driveshaft, and welded the perches back on...it was pretty close, but if you can get a hold of an angle gauge its more accurate. I didnt really care because I knew that I was gonna link it. might I suggest that you go to the auto parts or trailer store and buy a new set of spring perches. its a lot less work!
Old 06-22-2011, 06:45 PM   #559
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Re: My 86 build
where can i find perches? everytime i ask around ppl look at me like i have 3 heads :S
Old 06-22-2011, 07:21 PM   #560
mooseknuckles
Re: My 86 build
any autoparts store should be able to get them. with a good counter parts guy.....look for moroso, mr. gasket, even mopar performance has them in there catalogs.
Old 06-22-2011, 07:23 PM   #561
mooseknuckles
Re: My 86 build
moroso...
Old 06-22-2011, 10:00 PM   #562
mcboomport
mcboomport's Avatar
Re: My 86 build
You don't need to cut them off for a flip kit. I have a pdf of the flip brackets if you want it. I had mine made at a steel shop.
Old 06-22-2011, 10:02 PM   #563
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Re: My 86 build
That would be great! onlything is are the dimensions for a 1/2 ton or 1 ton? mines a dually.
Old 06-22-2011, 10:19 PM   #564
mcboomport
mcboomport's Avatar
Re: My 86 build
They are for a half ton. I'll grab the file at work tomorrow for you. It's fully dimensioned, so you could measure your perch first to make sure it will work. If you use the brackets, make sure you make shock extender brackets as well.
Old 06-22-2011, 10:21 PM   #565
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Re: My 86 build
i have drop shocks if that matters?
Old 06-23-2011, 07:58 PM   #566
mooseknuckles
Re: My 86 build
T.G.I.F....gonna get some more done on the truck this weekend!...need to finish bolting the box on, and finish welding up the bed floor....my buddy is picking up a truck tomorrow for scrap, hes going to let me look it over before it goes....damn shame.
Old 06-24-2011, 07:00 AM   #567
73gmc454
73gmc454's Avatar
Re: My 86 build
the bed floor looks great , your makin good progress
my build 77 gmc shortbed big block, http://67-72chevytrucks.com/vboard/s...d.php?t=438237
73gmc454 is offline   Reply With Quote
Old 06-24-2011, 04:57 PM   #568
mooseknuckles
Re: My 86 build
thanks....slowly but surely.
Old 06-24-2011, 05:15 PM   #569
mooseknuckles
Re: My 86 build
...priced out a viair dual 480 pack today $625+ tax...I may order it next week.
Old 06-24-2011, 11:20 PM   #570
luifer76
luifer76's Avatar
Re: My 86 build
Nice i love those 480s man they perform really good.....
Old 06-25-2011, 09:50 AM   #571
mooseknuckles
Re: My 86 build
...so what would I need for switches, gauges, etc.
Old 06-25-2011, 05:23 PM   #572
bharrison1
bharrison1's Avatar
Re: My 86 build
Dude you can get em cheaper that that i got mine from grunion customs they were under four shipped!!
bharrison1 is offline   Reply With Quote
Old 06-25-2011, 05:24 PM   #573
bharrison1
bharrison1's Avatar
Re: My 86 build
http://grunionfabrication.com/compre...ack-p-830.html
Old 06-25-2011, 09:49 PM   #574
mooseknuckles
Re: My 86 build
wow. that is cheap!
Old 06-25-2011, 09:54 PM   #575
luifer76
luifer76's Avatar
Re: My 86 build
wow. that is cheap!
that is cheap!!!... makes me want to get me a set also....
