Old 04-23-2013, 10:17 PM   #551
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Re: 85 GMC Sierra Classic 1 Ton Crew Cab
Do a big 5" side pipe down the side like that picture someone posted.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 04-23-2013, 11:18 PM   #552
Mattman2010
Mattman2010's Avatar
NO!
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 04-30-2013, 03:05 PM   #553
Mattman2010
Well have not been able to mess with the truck that much as I have wanted, but for good reasons. All I got done today was the fitting for the fuel outlet on the tank. I put it on the drivers side and put it at the rear end of the sump.
Hose end fitting screwed on.
Hopefully I can get some more time soon so I can get the two returns welded into the top of the tank and weld the top onto the tank and pressure test it.
Build Thread
Build Thread
Thread
Old 04-30-2013, 05:56 PM   #554
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Looking good buddy!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 05-02-2013, 02:49 PM   #555
Mattman2010
Worked on the fuel tank some more today. Its getting really close.
Got my drain welded in the bottom.
Got the two return line fittings in and also the auxiliary tank fitting as well.
Build Thread
Build Thread
Thread
Old 05-02-2013, 05:57 PM   #556
bohmankid
bohmankid's Avatar
Nice job on the tank man. Pretty ambitious building your own. I wouldn't trust myself
bohmankid is offline   Reply With Quote
Old 05-03-2013, 12:17 AM   #557
Mattman2010
Yeah I was not planning on making a custom fuel tank but after looking at all the options I could find for my truck making a custom tank was by far cheaper than getting one made and I have enough confidence in my abilities to try to tackle it. So far it is looking exactly as I designed it and its coming along pretty easy. But I am glad I decided to because I think it's nice to know how to make a tank.
Build Thread
Build Thread
Thread
Old 05-06-2013, 03:35 PM   #558
Mattman2010
Got the tank all welded up and got it pressure tested. Did some more work on the tank straps and wanted to make sure everything fit good so I stuck the tank in the truck.
Looks like everything fits just the way that I wanted it to. Going to start working on the filler neck some time soon and get the brake lines made and I should be able to start tearing the truck back down so I can finish up some welding and start spraying some paint.
Build Thread
Build Thread
Thread
Old 05-08-2013, 10:04 PM   #559
Mattman2010
Well I started relocating my rear shocks but I am not sure exactly where I should mount them. I have two places that I think will work best, but not sure which is better.
I first started making them mount here. It will clear everything with new top mounts.
But after making the lower bracket for mounting there I decided to look at mounting them back inside the frame.
Now on this setup the top bolt would be turned to match the bottom one.
One reason why I like them behind the axle and on the outside of the frame is that it will allow for me to have more room to make an anti-wrap bar.
Build Thread
Build Thread
Thread
Old 05-10-2013, 04:15 PM   #560
Mattman2010
Got the shocks for the rear mounted.
Next is to work on getting the proportioning valve mounted and getting the brake lines made for the frame. Then I should be about ready to tear it apart and finish a lot of welding and paint the frame.
Build Thread
Build Thread
Thread
Old 05-10-2013, 08:57 PM   #561
Dieselwrencher
Looking good Matt!
Ryan
Old 05-17-2013, 09:00 AM   #562
Mattman2010
Started on the brake lines yesterday.
Rear
Front passenger side.
Need to buy some extended lines so that I can figure out where I want my front brake lines to hook up. Once this is done its tear down time.
Build Thread
Build Thread
Thread
Old 05-17-2013, 02:49 PM   #563
Dieselwrencher
Looking nice buddy!
Ryan
Old 05-23-2013, 03:42 PM   #564
Mattman2010
Got my extended brake lines and also started making the mounts for the front and rear lines. Having trouble getting my flares to even look right so I cant finish up the brake lines just yet.
Brake lines
Front brake line mount
Rear brake line mount.
Also started looking at ideas for my safety chains on the gooseneck hitch.
Build Thread
Build Thread
Thread
Old 05-25-2013, 07:43 PM   #565
Mattman2010
Got my gooseneck safty chain hooks up started. Just need to gusset them and finish welding.
Also started tearing the frame down again so that i can finish up some welding and then start prepping the frame for paint.
Motor and tranny out
Started finishing some welding and also started welding all the factory holes in the frame up.
Build Thread
Build Thread
Thread
Old 05-28-2013, 07:24 PM   #566
Dieselwrencher
Looking good buddy! About time you got it in the correct section.
Ryan
Old 05-29-2013, 11:00 PM   #567
Mattman2010
Thanks bud. Yeah yeah I know
Well the past two days I have spent probably about 16 hours in the shop. Trying to get the frame painted soon so that I can make it a roller again because its getting warmer outside and if you have noticed there is a pontoon boat stuffed behind my truck and I am sure my uncle is going to want to get it out at some point.
First I rolled the frame on the side so that welding all of the holes in the frame would be easier and to also finish some welding in hard to get parts that I was not comfortable welding upside down.
A whole bunch of holes I was welding up.
Some of the holes were really big so I made a couple plugs to make welding them easier.
After I got all the holes welded and ground down I flipped it over and did the same to the holes on the bottom and also finished some more welds.
When I boxed the frame I had places in the frame that where not even with the top of the frame and there were some big holes left. (Pics are of opposite sides because i forgot to take before and after pics of both sides)
And here it is with a plate welded in.
I then needed to build some braces for the poor man shackle flip that I did. Started out with a piece of steel c-clamped to the back of the bracket so that I could use the bracket to act as an outline for my cutting torch and grinder.
I then drilled the holes and created some gussets.
All I have left to do on the bottom end is grind down some welds, cut the receiver tube for the goose neck hitch down some and then I should be able to flip the frame on its other side and weld on the holes on that side.
Build Thread
Build Thread
Thread
Old 05-29-2013, 11:48 PM   #568
ryanroo
ryanroo's Avatar
Nice!
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 06-03-2013, 02:58 PM   #569
Dieselwrencher
Looking good man! Next time before you box your frame, patch the holes so it's easier to weld from the out side. Tired of welding yet?
Ryan
Old 06-03-2013, 05:16 PM   #570
Mattman2010
Originally Posted by ryanroo View Post
Nice!
Thanks man!
Yeah I wish I would have patched the holes before but this is the first one, didnt think about it at the time. Im not tired of welding but the holes are annoying. I dont understand what 90% of them where even for.
Build Thread
Build Thread
Thread
Old 06-03-2013, 09:18 PM   #571
Dieselwrencher
I've got a funny feeling GM didn't know either!
Ryan
Old 06-03-2013, 09:42 PM   #572
Mattman2010
Haha I'm starting to believe that too. But then again there were fuel line holders, wiring harness holders and brake line holders, exhaust hangers, fuel tanks, and parking brake brackets. Which all of those are gone now.
Build Thread
Build Thread
Thread
Old 06-07-2013, 09:23 PM   #573
Mattman2010
I got an iPhone 5 today and decided to try its panorama view today down at the shop. Kinda thought the pic was cool.
I got all of the holes welded up on the bottom and also cut the receiver hitch for the gooseneck down, and the safety chain mounts gusseted and also finished work on my engine cross member mounts.
I also hate the lower mounts on the rear shocks that I have and after looking at some things I like the idea of outboarding the shocks. And I know this truck will not be articulating a lot and I saw a lot of shock mounts are just sticking straight out on most of the newer vehicles. So I started looking into this setup.
Build Thread
Build Thread
Thread
Old 06-07-2013, 10:00 PM   #574
ryanroo
ryanroo's Avatar
you know, that shock location will work well with bags...
72 K20 12v build
Old 06-07-2013, 11:36 PM   #575
Mattman2010
Sweet, well let me get it running and then I'll drop it off at your house to let you bag it.
Build Thread
Build Thread
Thread
