Old 08-01-2013, 05:59 PM   #551
knomadd
knomadd's Avatar
Re: Rustbuket 67 build "Georgia"
I just went through your entire thread at work (shhh... don't tell my boss). You've done quite a bit of work. I do have one question, if you don't mind. When you did your exhaust cut out in the cross member, are the pipe sections you welded in necessary, or just preference? I ask because I think this is the route I'm going to go with, but seeing the wedge cut into the factory piece, I'm thinking it was meant to have a little flex, and the pipe doesn't allow for that. Maybe I'm over thinking it? Nice progress, and great job so far.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 08-03-2013, 11:04 AM   #552
67c10rustbuket
67c10rustbuket's Avatar
Unhappy Re: Rustbuket 67 build "Georgia"
Originally Posted by Mustard72 View Post
Nice!
Thanks Nick!
Originally Posted by oldman3 View Post
Nice piece...Jim
Thanks Jim
Originally Posted by mcbassin View Post
Nice progress Dan! I like the gas filler notch too.
Thank you, I would like it a lot more if I didn't need to notch it
Originally Posted by MJs69CST View Post
Notch looks great.
ThANKS MJ
Originally Posted by VA72C10 View Post
Everything is looking great!
Thank you Johnathan
Originally Posted by ~Whitey~ View Post
You've come a long way since I last checked your thread. Looks good, really like the silver control arms, and I'll be copying you on that filler notch most likely! Great job.
Thanks Jimmy, and thanks for the tip on the ECE backing plates. I have some out in the garage now.
Thanks for checking out my truck.
I agree with you that the welded in section of round tube is not really needed. If you take a look at the ECE crossmember and other aftermarket crossmembers it is just a cut out. My reasoning was we only had 4.5" round at work so that is what I used. With the 4.5" my cutout was on the edge of the radius of the bend so I thought welding in the reinforcement would be a good idea. Ideally I would like to have used 3.5" round with no reinforcement. I work with engineers all day so I understand the overthinking, I do it all the time. slows me down
I finished the tank notch and mounted the tank for the last time. I have been working on several other things and stocking new parts but the pic situation here is too much of a pain to post pics. I will try to sign up with photobucket in a while and try that out.
We have also been taking care of a few things with an insurance claim at the house too, new roof, gutters going up right now, I have to paint the back porch,garage door and overhangs and have a new shed built. This is taking up much of my "spare" time.
Ellie wants to post some smilies:
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 08-03-2013, 11:13 AM   #553
67ctener
67ctener's Avatar
I love the picture from the back with the cab on the frame. Almost like looking at a womans backside. Great job with the fab of the notch.
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
67ctener is offline   Reply With Quote
Old 08-03-2013, 01:15 PM   #554
67c10rustbuket
Sexiness
Attempting to link through photobucket.
Trimmed the notch down getting ready to weld.
Welded in, smoothed out just a little bit.
Welded in with a little primer, it was raining on and off when I was trying to work
Another shot in primer. Not the prettiest welds. I need to buy a bigger welder soon. The Millermatic at work has me spoiled.
Dan <---(my name)
Old 08-03-2013, 01:16 PM   #555
67c10rustbuket
I had to notch out the rear crossmember to clear the notch.
Dan <---(my name)
Old 08-03-2013, 01:17 PM   #556
67c10rustbuket
I will finish uploading and updating after lunch. Photobucket works pretty well. I dig it
Dan <---(my name)
Old 08-03-2013, 01:33 PM   #557
Hardesty454
Hardesty454's Avatar
Lookin good there stud!
Rob
1971 c10 - ground up in progress
Tripp's Speed Shop Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=589750
Hardesty454 is offline   Reply With Quote
Old 08-03-2013, 02:57 PM   #558
67c10rustbuket
Thanks Chief, I have been watching your new build thread. Dont think I commented yet though. Looks like a great start
Tank notch painted with tank installed, again....
I really wish the fill neck was .75" taller. If it were it would fit perfect between the frame and bed floor. Oh well done with it now
Dan <---(my name)
Old 08-03-2013, 02:58 PM   #559
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
Looks good Dan!!
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 08-03-2013, 03:04 PM   #560
67c10rustbuket
These pics show how it is mounted directly to the underside of the frame. I used two 1/2" bolts on each side through existing holes in the frame. A typical receiver hitch wont fit with the Boyd tank but I found the CPP hidden hitch will fit. I may have to get one of them someday
Driver side
Passenger side
This shot also shows some .25" rubber strips I cut on the shear to go between the tank and frame. Not sure if I need to use them or not. Any thoughts??
Here are a couple shots of the tank installed. Sure looks purdy
I also torqued all the hardware on the rear and marked them with a sharpie so I don't forget
Dan <---(my name)
Old 08-03-2013, 03:05 PM   #561
oldman3
oldman3's Avatar
That sure looks nice, super job. I know you used lock washers and nuts to bolt in the tank, I think I would use locking nuts, just to be extra safe...Jim
oldman3 is offline   Reply With Quote
Old 08-03-2013, 03:12 PM   #562
67c10rustbuket
Here are my rear shock relocators. I started these a long time ago but I decided I was going to copy robnolimit instead of this style. BUT the nolimit shock relocators would interfere with the Porterbuilt track bar bracket on the driver side of the frame. Sooo back to plan A.
Upper shock mounts removed and marked. Be careful they are not symmetrical.
Cut them up with the plasma. Probably should have used a straight edge. They cleaned up fine on our vertical belt sander. Love that tool
All cleaned up.
Painted and installed.
Dan <---(my name)
Old 08-03-2013, 03:19 PM   #563
67c10rustbuket
The idea on the upper shock re-locator is to move the hole up and BACK for more travel and to straighten them back up as before lowering.
Here is a link where I got the measurements.
http://67-72chevytrucks.com/vboard/s...d.php?t=359399
Or you can just buy them from ECE or CPP.
I am doing my lowers like the ECE and CPP version from my own measurements rather than modifying the stock lowers to work. Here is a pic of my experimental shock fitting jig. Once I decide on a hole to use I will make some out of 3/16.
The lower mounts flip the tab down rather than up as original and maybe a little forward for better angle and more travel.
Dan <---(my name)
Old 08-03-2013, 03:26 PM   #564
67c10rustbuket
Originally Posted by screaminchevypickup View Post
Looks good Dan!!
Thanks Kyle!
Thanks Jim, You have a very good point. I was always told to use large flat washers when bolting aluminum like this but that kinda takes away from the lock washer doing its job. I will get some nylocs on there next time I go to the hardware store.
Dan <---(my name)
Old 08-03-2013, 03:32 PM   #565
67c10rustbuket
Mounted the Idler arm bracket and idler arm. Moog of course painted with Seymour cast blast. I really like the cast blast finish. Looks new but wont rust like a raw part.
I also have the pitman arm but cant put it on yet because I noticed my blasted/cleaned/primered steering gear started oozing fluid so I bought a gates reseal kit. waaaa
Dan <---(my name)
Old 08-04-2013, 12:06 AM   #566
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Dan, that puppies coming right along! All you lack now is finishing up.
Zoomin is offline   Reply With Quote
Old 08-13-2013, 09:05 PM   #567
El Campo
El Campo's Avatar
Everything is looking great! Have not been on here in way way too long and I am happy to see that you are doing a fine job at keeping on going. So many thing I love about your build!
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 08-13-2013, 11:26 PM   #568
Bomp
Bomp's Avatar
Nice Clean Work!
Bomp is offline   Reply With Quote
Old 08-23-2013, 06:41 AM   #569
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Read through the whole thread, and I am impressed! Great job on the rust repair and chassis looks awesome. I wish I was as resourceful as you are, keep up the pace and soon you'll be ridin'!
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 08-23-2013, 08:27 AM   #570
mcbassin
Still Learning
mcbassin's Avatar
Nice work on the shock mounts Dan. Keep up the hard work.
mcbassin is offline   Reply With Quote
Old 09-21-2013, 08:27 PM   #571
67c10rustbuket
Thanks Steve, yeah a bunch of finishing up
Thanks, glad to have you back
Originally Posted by Bomp View Post
Nice Clean Work!
Thanks Bompenstein!!!
Thanks Buck, resourcefull=cheap! I wish I were smart enough to find a truck like yours to start with. I didn't plan on a frame off when I bought my truck. The dang snowball just ran me over
Thanks Mike!
SO where was I? I punched holes in the rubber strips for between the frame and tank, installed them and changed out the nuts in favor of nylock lock nuts. Then I was messing around with some gas tank filler hose trying to figure where the filler will end up. I wanted it behind the rear wheel well in the floor but I really don't see how to make the turn up that close to the floor other than welding a sharp radius 90* pipe to a filler neck. Probably end up with a filler on the inner bedside or flush mount in the top of the bedside where the stake hole used to be. I will figure that out later once I put the bed together. I decided to go with a wood bed floor so I have a steel floor I need to get rid of.
Dan <---(my name)
Old 09-21-2013, 08:35 PM   #572
67c10rustbuket
Now back to the rear shocks and lower mounts.
I decided to use this hole It is just mirrored off the original bracket on the opposite side. The other holes just didn't work out as I thought.
I cut the brackets with the plasma and smoothed the edges, and formed on the press brake. Time for a test fit.
I ended up having to obround one of the holes because my u bolts are a hair over bent, Just to make installation easier. Then I made some gussets to add a bit of overkill to them.
I put the new brackets on and installed new .5" x 2.5" bolts, press fit
Dan <---(my name)
Old 09-21-2013, 08:44 PM   #573
67c10rustbuket
I bought some Monroe gas max shocks dirt cheap on rock auto and painted them to match the KYBs on the front Once I had them and mocked them up I realized I needed to add a .25" spacer on the lower mount to keep the shock tube from contacting the bracket so I made a couple spacers.
Now that everything was clear I installed the shocks and snapped a bunch of pics, everyone loves pics right
Paint was a little soft on this bracket
Dan <---(my name)
Old 09-21-2013, 08:50 PM   #574
67c10rustbuket
Now I have plenty of shock travel and it didn't cost me anything other than spare time
Next up is the steering gear, When I blasted it and primed it fluid started seeping out of somewhere so I bought a seal kit. I removed the pitman arm nut and rented a pitman arm puller. Time to read the instructions
Dan <---(my name)
Old 09-21-2013, 09:10 PM   #575
TchncnDen
I was able to change my seals out without disassembling the entire box. Just dig the old ones out with a pick or small screwdriver and tap the new ones in. I have done full rebuilds before and it's a pain in the butt and probably not needed.
TchncnDen is offline   Reply With Quote
