Old 07-11-2018, 01:47 PM   #551
ultrahd4me
ultrahd4me's Avatar
Re: "Elwood" the 77_remix
Ken, I would recommend you try a smaller bolt or 1/4" round stock and weld it to the broken bolt. I usually extend the wire from a small mig out further than normal, all you need is one good tack and that bolt will come right out. A 110V mig with .023-.025 wire is perfect for that. Good luck sir
Follow me on Instagram: @midtennc10
Youtube channel: Midtennc10
ultrahd4me is offline   Reply With Quote
Old 07-11-2018, 02:53 PM   #552
SBTork
Garage wrench
SBTork's Avatar
Originally Posted by N2TRUX View Post
One down, and one to go. I used the same method on this side, but it was destined to be a battle from the beginning. Even though I center punched the stud, the bit was determined to walk off center. I finally got adequate depth for the extractor bit and began the process of run it in, take it out and lube it again. Things were going smoothly till the tip of the extractor snapped off down in the hole.
I tried a center punch to shatter the extractor tip, with minimal progress. In frustration I found a hardened drill bit and tried to drill through. Of course that snapped off too.
Now I have the remains od the extractor and the bit in the hole.
I decided to walk away and research my options.
If it were me, and this is just me talking....I'd mask off the block and surrounding areas with some weld proof material and fill the area with weld and weld a nut onto the broken bits and get it out that way. I had to do this with 3 exhaust manifold bolts that broke off in the cylinder heads, it worked great. It took some planning, prep and patience to get them all but that was the only way for me.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 07-12-2018, 09:24 AM   #553
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by SCOTI View Post
This is called 'Scotluck'.
I thought it was Sh!tluck, Scoti. Thanks for clarifying.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-12-2018, 09:28 AM   #554
N2TRUX
Happy to be here
N2TRUX's Avatar
Ken,... look into Edelbrock aluminum water pumps.
I'm a believer in them. That's also what Billet Specialties uses in their Tru-Trac kits.
Keith, I have used Auto Zone pumps for years with no failure. Just my luck that I get the one that doesnt meet the usual standards. I will be using an Edelbrock pump now. Eddie Motorsports includes them with their S Drive kit as well.
Articles-
"Refining Sierra"
Old 07-12-2018, 09:30 AM   #555
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by rustytruck50 View Post
....Are you thinking Helicoil? My limited experience with broken bolts doesn't offer up much else...good luck!
I get a feeling I will end up with a Heli-Coil insert once I'm done. Before I can do that, I have to get more of the remains out of the hole.
Articles-
"Refining Sierra"
Old 07-12-2018, 09:32 AM   #556
N2TRUX
Happy to be here
N2TRUX's Avatar
Very viable options if the remains werent deep in the hole. It may come to that, but first I'm going to try a diamond tip burr to eat the hardened bit remains out.
Articles-
"Refining Sierra"
Old 07-13-2018, 10:11 AM   #557
N2TRUX
Happy to be here
N2TRUX's Avatar
Not being one to waste valuable shop time, I decided to step away from my broken bolt crisis. I will have to make it right, but wanted to end the day having accomplished something positive.
Chris and I dug in to the Eddie Motorsports and found the instructions. Fortunately they were written for guys and have plenty of pictures. Its ironic that I was once an avid reader, but hate instructions with more words than pics. These had a nice balance of both.
Articles-
"Refining Sierra"
Old 07-13-2018, 10:15 AM   #558
N2TRUX
Happy to be here
N2TRUX's Avatar
We spread things out on a bench so we could see what we had. I requested the polished version and my rep encouraged the Protective Fusion Clear Coat to eliminate having to maintain the polished surfaces. I highly suggest this feature as most of the parts become virtually impossible to polish once installed.
Articles-
"Refining Sierra"
Old 07-13-2018, 11:01 AM   #559
LT7A
Ken, I have a broken off water pump bolt with the hardened tip of an extractor buried in it as well. What I found works on the hardened tip is a grinding stone on the end of a Dremel. "Works" may be the wrong word since as you can imagine it is a very slow process. And once you have the hardened material out of the way then you're still left with getting the rest of the bolt out. I may rent a magnetic drill so that I have something stable to try to drill out the center of the shaft. Then with a bunch of heat and penetrating oil I hope to get the remainder of the bolt out.
Old 07-13-2018, 11:44 AM   #560
gringoloco
A guy with a truck
gringoloco's Avatar
Welding a nut on the broken stud is the way to go. Keeps the weld inside the hole, gives you something to grip, and heats it up nice for smooth extraction
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 07-13-2018, 02:14 PM   #561
LT7A
I would like to have that as an option, but per Ken's post number 556:
"Very viable options if the remains werent deep in the hole."
I'm in the same predicament. Hence my recommendation.
Old 07-14-2018, 11:43 AM   #562
N2TRUX
Happy to be here
N2TRUX's Avatar
This is the most common suggestion. Unfortunately its just not viable at this point. Had a I tried it when the body of the bolt was visible it could have worked. The handle on my MIG is broken and I cant find a replacement so I didnt consider it at the time.
Originally Posted by LT7A View Post
I would like to have that as an option, but per Ken's post number 556:"Very viable options if the remains werent deep in the hole."I'm in the same predicament. Hence my recommendation.
Exactly. I am going to try a punch to fracture the broken remains. If that doesnt work I will try the Dremel tool option.
Articles-
"Refining Sierra"
Old 07-15-2018, 12:05 PM   #563
N2TRUX
Happy to be here
N2TRUX's Avatar
Chris unpacked all of the parts to the S Drive system while I finished up stripping the front of the block. With all of the old components clear we were able to start mounting the Eddie Motorsports system. The firs step was to bolt water pump spacers to the block. I finger tightened all of the bolts but one, and said a few more curse words at the bolt hole from hell that I would need to address later.
Articles-
"Refining Sierra"
Old 07-15-2018, 12:12 PM   #564
N2TRUX
Happy to be here
N2TRUX's Avatar
The spacers were followed by a polished high flow Edelbrock water pump. With the pump mounted spacers were added to create stands for the main support brackets.
Articles-
"Refining Sierra"
Old 07-18-2018, 10:57 AM   #565
N2TRUX
Happy to be here
N2TRUX's Avatar
Next the main support bracket was added. This will support of of the accessories. With the support bracket in place we were able to begin adding components in their proper position. The power steering pump used is a late model GM pump.
Articles-
"Refining Sierra"
Old 07-19-2018, 09:17 AM   #566
aggie91
I'm just glad to be here!
aggie91's Avatar
That's gonna be nice!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 07-19-2018, 11:10 AM   #567
N2TRUX
Happy to be here
N2TRUX's Avatar
Thank you sir. The components are premium quality fit and finish. It should look very smooth when done.
Articles-
"Refining Sierra"
Old 07-19-2018, 11:14 AM   #568
N2TRUX
Happy to be here
N2TRUX's Avatar
Moving up to the alternator, I noted the manufacturers tag as I installed it. The kit comes with a Powermaster 170 amp alternator to provide adequate amperage to the system.
Articles-
"Refining Sierra"
Old 07-24-2018, 12:34 PM   #569
N2TRUX
Happy to be here
N2TRUX's Avatar
Running a bit behind on my updates, so lets add a couple more. With the drivers side in good shape, I moved to the passenger side. The A/C compressor was set in place. With the compressor in place I started adding the studs for the fan spacer. I'm not sure what combination will eventually end up here. I do plan to run a clutch fan.
Articles-
"Refining Sierra"
Old 07-24-2018, 12:42 PM   #570
N2TRUX
Happy to be here
N2TRUX's Avatar
This system requires a reverse rotation fan and clutch so I will make adjustments once I make these purchases. Until then I plan to use parts from the old system so I can finish mocking it up. Don't worry, EVERYTHING will be new.
Articles-
"Refining Sierra"
Old 07-25-2018, 11:10 AM   #571
N2TRUX
Happy to be here
N2TRUX's Avatar
Moving down now, I installed the crank pulley. After that the belt tensioner was bolted on as well.
Articles-
"Refining Sierra"
Old 07-25-2018, 08:22 PM   #572
Rickysnickers
That looks nice.
Old 07-26-2018, 02:38 PM   #573
rustytruck50
rustytruck50's Avatar
Cool!!
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 07-27-2018, 09:36 AM   #574
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by Rickysnickers View Post
That looks nice.
Cool!!
Articles-
"Refining Sierra"
Old 07-27-2018, 10:14 AM   #575
N2TRUX
Happy to be here
N2TRUX's Avatar
While waiting for the line kit to come in from Eddie Motorsports I ordered the replacement radiator. I really hated that I had destroyed a very clean copper and brass unit. I researched trying to have mine rebuilt, and that is no longer a viable option. The cost of copper cores has become so expensive that I could buy three with an aluminum core.
All of the LS swap experts recommend using the Spectra Premium CU730 which is the replacement for the OEM big block equipped trucks. I'm told these cool better than the factory 4 row copper cores.
Unfortunately Summit used UPS as the carrier on this shipment. I received my parts yesterday, and the box was damaged. The radiator wasnt hurt too bad, but I am having it replaced.
Articles-
"Refining Sierra"
