Old 06-08-2013, 10:35 AM   #576
ryanroo
ryanroo's Avatar
Re: 85 GMC Sierra Classic 1 Ton Crew Cab
Bumpers, bags and twins, man you better have a good pile of interesting things to trade!
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 06-08-2013, 11:40 AM   #577
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
I hear he has some of those "things that go boom" that he doesn't want any more, he thinks they should be banned so he wants to get rid of them...
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 06-08-2013, 01:29 PM   #578
Mattman2010
Mattman2010's Avatar
I think I can handle doing the twins on my truck, but for now I'm just going to go single as I don't want to blow this motor up right after I get it running. I'm sure we can figure something out tho!
I don't have any of my "things that go boom" anymore. Had a bad boating accident happen a while back and none of them survived.
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 06-17-2013, 03:25 PM   #579
Mattman2010
Well Ive gotten some stuff done on the truck. Was looking at the out boarded rear shocks and just was not finding a good way to make the upper mount that didnt look like some big bracket welded to the frame. So I went back to the original way that I had the shocks.
I then decided it was finally time to seal up the rear of the frame. I did not run the rear cross member all the way inside of the frame because I had nuts welded inside the frame for the bumper and the receiver hitch and so I used the end plates as ways to tie the frame to the cross member more.
Got my safety chain hook ups all welded up shock mounts welded, and also gusseted my gas tank strap mounts.
Brought the D60 back into the shop so I can tear it down. Going to try to get the axles and frame all painted at one time so I can have it as a roller ASAP.
Build Thread
Build Thread
Thread
Old 06-17-2013, 06:16 PM   #580
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
LMFAO!!!!!!!!!!!!!!!! You, my friend, are so full of
Nice work on your shocks. I always hate when you're trying to mount something that never was there, but can't seem to find a nice or cool way to make it appear.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 06-17-2013, 06:19 PM   #581
Dieselwrencher
Oh yeah, I almost forgot.........................
Happy 21st Birthday Young'n!
Ryan
Old 06-17-2013, 08:33 PM   #582
y5mgisi
Second Chance Program
y5mgisi's Avatar
Just a whole beefy setup.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 06-23-2013, 04:06 PM   #583
Mattman2010
Thanks fellas!
Been getting the frame and axles ready for paint. And today I was able to lay down some paint.
Build Thread
Build Thread
Thread
Old 06-23-2013, 04:16 PM   #584
kikkegek
kikkegek's Avatar
nice! what did you use for paint?
kikkegek is offline   Reply With Quote
Old 06-23-2013, 04:55 PM   #585
Mattman2010
It's the tractor paint that you can buy from tractor supply. It's cheap but I put it on my k10 3 years ago and it's done fine. This was a different brand then the stuff I have on my k10 tho so hopefully it is just as good.
Build Thread
Build Thread
Thread
Old 06-23-2013, 09:19 PM   #586
brimc
brimc's Avatar
Looking very good!
BRIAN
1986 Chevrolet K20 Silverado 12 Valve CUMMINS P Pumped Intercooled/Getrag360/Divorced NP205/10B/14BFF Detroit Locker - DD Canadian Winter Beater.
My Chevrolet CUMMINS Build http://67-72chevytrucks.com/vboard/s...d.php?t=585509
brimc is offline   Reply With Quote
Old 06-24-2013, 08:46 PM   #587
Dieselwrencher
Nice work! Looks good, even if it is flatish black. Don't scratch it putting it back together!
Ryan
Old 06-27-2013, 01:58 PM   #588
Mattman2010
Thanks Ryan! Either you or I jinxed it and i did scratch it putting the rear axle in... When I was putting it in I was lining it up the housing rotated on me and the spring scratched the frame... But I think once I get everything bolted together I may do another coat over the whole thing.
Once I got the rear axle in I moved it back into the shop.
Decided mount the rear shocks as well.
I then put all new seals into the front axle housing and got the gears all set back in the housing. Started cleaning the knuckles out as well so that I can get some paint on them. Just need to get the kingpin rebuild kits and I should be able to have it back as a roller.
Build Thread
Build Thread
Thread
Old 07-02-2013, 03:18 PM   #589
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Subscribed! Nice
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 07-09-2013, 02:50 PM   #590
Mattman2010
Well I went up to Dieselwrenchers for a week and spent time helping him get his long horn running for Goodguys and I brought home some more parts.
2nd Gen intercooler and a shifter for the transmission and a couple other things.
Got to looking at how to install the intercooler in the core support and putting it in the front was looking like it was going to take a lot of work. It is very close to the lights and the grill does not have a lot of room between it and the core support.
So I decided to flip it over and see if it would fit any better. Looks like I will just have to cut the main supports out of the core support and it should fit in very nicely. I will have to build some new supports but that should be easy. I am looking around for a radiator for the truck now so I can make sure that after I cut it it will all fit like factory.
I also got in a intake flange from Ryanroo so I can make a custom intake for the truck. Thanks Ryan!
Build Thread
Build Thread
Thread
Old 07-09-2013, 06:50 PM   #591
Dieselwrencher
Nice plan on the intercooler. Thanks for the help, I hope you had a good time. PS You may want to check your gun case............... I hope the black rocks will suffice.............
Ryan
Old 07-09-2013, 06:57 PM   #592
Mattman2010
No problem man it was fun. Oh don't worry I checked it before I left to make sure they were still there.
Build Thread
Build Thread
Thread
Old 07-09-2013, 06:58 PM   #593
Dieselwrencher
LMFAO! I'm sure you did.
Ryan
Old 07-12-2013, 03:59 PM   #594
Mattman2010
Well I ended up buying the radiator back that came out of this truck when it had a 454.
I set the radiator in the stock place and it looked like there was a ton of clearance for the intercooler so i started cutting on the core support.
Intercooler will fit down in there nicely after i drill two holes for the bottom mounts. Then I will have to build some upper mounts and put in some new vertical supports.
Build Thread
Build Thread
Thread
Old 07-13-2013, 10:26 PM   #595
Mattman2010
Well tonight I got some time in the shop and have the intercooler finally setting in the core support just how I want it. I still need to make the top mounts which should be pretty easy. One thing I was trying to do while I was mounting this intercooler was to not modify anything on the intercooler so that if something happened to this one I would be able to buy a replacement and it would fit right in.
The only thing I had to do was move the upper mount rubber isolators in farther so that they would clear the back of the headlights and allow for a bolt to be able to pass through them.
Build Thread
Build Thread
Thread
Old 07-13-2013, 10:53 PM   #596
ryanroo
ryanroo's Avatar
sure fits in there nice!
72 K20 12v build
Old 07-14-2013, 09:19 AM   #597
legendman
legendman's Avatar
Don't forget to leave some clearance for the bolt heads that hold the rad support to the frame, I trimmed the rubber isolators down just enough to get a wrench on the bolt head.
1999 Chevy K2500 RCLB 350 4L80e
2004 Chevy 3500 C&C Dmax Allison
Originally Posted by smackzed View Post
I put a chevrolet tailgate on my last truck and it started acting like a girl...love me, need me, want me pay attention to me. Took it off and put the GMC back on (fixed the latch) and it went back to being the same old dirty bastard it used to be
legendman is offline   Reply With Quote
Old 07-14-2013, 11:37 AM   #598
Mattman2010
I have enough clearance on mine so I won't have to trim it down at all. How did you go about making the top mounts? I think I'm just going to make a u shaped bracket that gets bolted to the core support and the the intercooler bolts to that.
Build Thread
Build Thread
Thread
Old 07-14-2013, 12:08 PM   #599
brimc
brimc's Avatar
You have that IC sitting in there nice. Almost as if it was made to go there. As far as clearance goes for the rad support to the frame, what about welding a nut plate on the support and running a bolt up from the bottom. Almost the same idea as the original cab mounts? I was thinking this would work as long as the bolt size was cut down only to protrude 1~2 threads max. Might be easier than getting a wrench in there?
BRIAN
Old 07-14-2013, 12:13 PM   #600
brimc
brimc's Avatar
Oh, and the upper mounts you could try some angle iron then drill/tap out to bolt it to the IC. Then when you have it lined up weld the angle to the rad support, using the IC to hold it in the right spot. Not sure if this is th best way, but that was how I was planning on doing it.
Looks great keep up the good work.
BRIAN
