Old 07-07-2013, 02:19 PM   #576
_Ogre
_Ogre's Avatar
Re: 51 Chevy 1/2 ton, My S10 swap
looks good atommik
glass is in, that means your close to running down the road
bright yellow, bright orange what's the difference as long as they see you coming
shop air compressor timer
Old 07-09-2013, 09:15 PM   #577
Atommik
Atommik's Avatar
Got some "shiney" stuff today!!
Atommik is offline   Reply With Quote
Old 07-10-2013, 02:03 AM   #578
51Charlotte
Very nice!
I can't wait to see her outside in the sun
51Charlotte is offline   Reply With Quote
Old 07-11-2013, 05:07 PM   #579
Atommik
Atommik's Avatar
Good news, I removed the fuel pump/sending unit and found that the tank was really clean inside, but the section of fuel line between the pickup tube and the fuel pump was shot causing the external fuel pump to suck air. I removed the S10 pump I wasn't using and extended the pickup tube, and reinstalled it. Now I have fuel pumping.
Leaks are pretty much gone, so I took it for my first official drive
!! I forgot to connect the vacuum line to the trans so it would not shift out of 1st, but I made it around the block with no other trouble!!
Very excited to reach this milestone!! Pics to follow.
Old 07-11-2013, 05:14 PM   #580
Atommik
Atommik's Avatar
pics...
Old 07-11-2013, 06:12 PM   #581
msaintg
msaintg's Avatar
hmmm, purdy.
I wish my tranny problems were just a vacuum line
msaintg is offline   Reply With Quote
Old 07-11-2013, 06:52 PM   #582
Clarance J
Clarance J's Avatar
Congratulations on getting it on the street even if it was just around the block. It sure has been nice build to follow and read since the first post pictures of it in the field with no tires and a bed full of junk. Again, congratulations. Now to tie up all the loose ends. Thanks Atommik.
Earl
You have to have patiences or you'll be one.
Clarance J is offline   Reply With Quote
Old 07-11-2013, 07:05 PM   #583
av8tr33337
av8tr33337's Avatar
That thing is nice. Great work!
av8tr33337
AKA Bartman Email av8tr33337@yahoo.com
Bartman's Ad-S10 Chassis Swap
http://67-72chevytrucks.com/vboard/s...d.php?t=415418
My First Youtube Video
http://www.youtube.com/watch?v=B6hSt...eature=channel
More Pics of the 51 Project
http://s668.photobucket.com/albums/v...hassis%20Swap/
1951 3100 Pickup
av8tr33337 is offline   Reply With Quote
Old 07-11-2013, 07:12 PM   #584
Bubba54
Trucks looking really nice. Just curious is your hood emblem stainless or chrome ?
Thanks Shawn
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=582647
Bubba54 is offline   Reply With Quote
Old 07-11-2013, 09:00 PM   #585
Atommik
Atommik's Avatar
Stainless, from LMC Truck.
Still need to use the buffer and do the final polish, then I'll start installing the rest of the trim.
Old 07-11-2013, 11:24 PM   #586
oldman3
oldman3's Avatar
Looks great...Jim
oldman3 is offline   Reply With Quote
Old 07-11-2013, 11:45 PM   #587
99 to Life
99 to Life's Avatar
congrats, first test drive is the best. Great feeling, no matter how many kinks you have to iron out.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 07-12-2013, 05:12 AM   #588
51Charlotte
Wow, that thing pops outside.
Very nice!!!
Congrats bud
Old 07-13-2013, 03:21 PM   #589
Atommik
Atommik's Avatar
Finished the exhaust this morning. After getting another look at it on the ground, I think I will shorten the length of the tail pipe. It sticks out too far.
Also got the vacuum line 95% done for the tranny. Just need to make the final connection at the vacuum port on the carb. Should be able to finish that before work on Monday.
Well, with all of the "big" items complete, time to make a new list of "little" things to do! It's going to be a long list...
Old 07-13-2013, 08:48 PM   #590
99 to Life
99 to Life's Avatar
glad to see its finally all coming together an is a driver. One thing I'd suggest is having easy access to your battery. Nothing worse than trying to fix problems and to add to that the battery goes dead. For example I had a module go bad in my dist. I just ordered up a whole new distributor, from trying to start it before I realized the problem, then after I got new dist in I didn't have enough juice to get it going, so I had to swap out the battery just to finish up getting it going and retimed. Things like that will pop up, especially with a carb set up. Other than that I think your going to be fine.
Old 07-13-2013, 10:14 PM   #591
Atommik
Atommik's Avatar
99,
I am planning to have some hinged bed wood panels for access to the battery. I'll be building my own bed floor so it shouldn't be a problem incorporating the hinges into my design.
Old 07-14-2013, 12:22 PM   #592
_Ogre
_Ogre's Avatar
you can thank the ethanol mix in our gas for this
took me 3 times to get the right line for my pump
i'm very good and fast at dropping my tank
Old 07-15-2013, 11:04 AM   #593
xpickup
xpickup's Avatar
Atommik, looks great. That orange is bright outside. Keep up the great work.
Shannon
xpickup is offline   Reply With Quote
Old 07-16-2013, 11:30 PM   #594
Atommik
Atommik's Avatar
Thanks Shannon.
Well after a 20 minute test drive during my lunch break with no surprises, I decided the time was right to drive it home!! Since my work is only 6-7 miles from home I knew it would be a shorter drive than at lunch time. So I went home and then had my daughter drive me back to work after supper, then I drove the truck home, no problems at all!!
It's nice to finally have it home so I can work on it when ever I want. If I need to do something I can't do at home, I'll drive it to work. Should work out well!!
Had a couple of neighbors stop by that hadn't seen my truck since it was is pieces in the garage.
Old 07-17-2013, 02:06 AM   #595
51Charlotte
That's awesome! I bet it felt good to swing it into the driveway!
Old 07-17-2013, 07:18 AM   #596
xpickup
xpickup's Avatar
Atommik, glad you have it on the road now. It will be nice that it is home, then you can work on when you can. Great looking truck.
Shannon
Old 07-17-2013, 09:46 AM   #597
oldman3
oldman3's Avatar
Glad it is all working out for you, nice build, enjoyed watching, enjoy and keep us posted...Jim
Old 07-17-2013, 04:45 PM   #598
Katrina/10
Katrina/10's Avatar
Was that the fuel line included with the pump?
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 07-17-2013, 09:43 PM   #599
99 to Life
99 to Life's Avatar
awesome man, that is really cool your on the road. In a couple years you'll look back and be like wow where'd I find the time to build that and it will sink in that much more how much work goes into these and the joy of having them is def a blessing of some sort.
Old 07-17-2013, 09:46 PM   #600
Atommik
Atommik's Avatar
Yeah, the fuel line was the original out of the S10 tank. It connects the fuel pick up tube and the pump. It's only about 2 inches long. Most likely used to help with vibration control.
