Old 12-10-2015, 11:46 PM   #576
MP&C
MP&C's Avatar
Re: 55 Wagon Progress
The braces for behind the lower skirt were mangled pretty well, had to untwist the pretzels to get accurate measurements..
Getting all the holes prepped...
Welding in the new braces..
All the pieces of the puzzle... Well, almost..
Now to bust it apart for paint prep..
Robert
MP&C is offline   Reply With Quote
Old 12-11-2015, 12:20 AM   #577
oldman3
oldman3's Avatar
Sure looks alot better...Jim
oldman3 is offline   Reply With Quote
Old 12-12-2015, 08:38 PM   #578
MP&C
MP&C's Avatar
Well, only one more piece to make for the bus, we need a cap to join together two pieces of rub rail....
Bent up some 18 ga on the Baileigh magnetic brake...
Then for the highly technical stuff, bent the rest using vise grips to clamp it in place and a dead blow to incrementally tap the ears around...
Continued to use the hammer to tap it around, then tightened up the radius on this die/post dolly
We'll get some paint on the bus parts tomorrow..
Robert
Old 12-12-2015, 09:17 PM   #579
MP&C
MP&C's Avatar
Duplicate post
Robert
Old 12-17-2015, 12:34 AM   #580
MP&C
MP&C's Avatar
Got some paint on the bus parts tonight....
For the hardware, we media blast the heads and then paint....
Robert
Old 12-17-2015, 04:34 PM   #581
oldman3
oldman3's Avatar
Looks good...Jim
Old 12-18-2015, 11:40 AM   #582
MP&C
MP&C's Avatar
Thanks Jim!
Robert
Old 12-19-2015, 07:21 PM   #583
MP&C
MP&C's Avatar
The other night while spraying parts, I made a couple trips over to the bus location with the spray gun... in between coats, to get some primer on the bare steel we put in... SPI epoxy on the structural components..
.....and some epoxy AND yellow added to the nice scraped up lower corner..
Coming together...
Rivets were media blasted and urethane only, just like the screws. This shows how well the paint holds up to the installation "abuse"...
Done!
Robert
Old 12-19-2015, 07:56 PM   #584
Advanced Design
Advanced Design's Avatar
Nice work Robert.
Advanced Design is offline   Reply With Quote
Old 12-19-2015, 09:29 PM   #585
swamp rat
swamp rat's Avatar
We knew you could do it!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 12-20-2015, 12:52 AM   #586
oldman3
oldman3's Avatar
Turned out great...Jim
Old 12-20-2015, 08:42 AM   #587
Cape Codder
Cape Codder's Avatar
Nice work, I bet the original builder wasn't that concerned with priming behind the panels.
Cape Codder is offline   Reply With Quote
Old 12-20-2015, 12:18 PM   #588
trixter99
I have no time for this
trixter99's Avatar
It seems a shame they didn't have you fix the scrape ahead of the wheel while yo were at it.
1986 Chevy short box ( PROJECT )
1994 Chevy Blazer lifted 6"
2009 Gmc 2500 HD
1999 Hugger orange Camaro SS
2007 BMW X5 Sport
trixter99 is offline   Reply With Quote
Old 12-20-2015, 03:22 PM   #589
MP&C
MP&C's Avatar
Yes, but this wasn't an insurance job, nor was the previous incident when that dent was added. With the cost being paid by the owner, sometimes a line is drawn in the sand as to what is worth the cost of repair.
Robert
Old 12-20-2015, 04:59 PM   #590
trixter99
trixter99's Avatar
I hear ya I did collision repair for 15 years. Nice work on the bus always top notch
2009 Gmc 2500 HD
2007 BMW X5 Sport
Old 12-21-2015, 10:19 PM   #591
MP&C
MP&C's Avatar
Thanks!
Dropped it off before work, picked it up afterward.
After about an hour in the driveway with an air hose, the flow of trapped media is scarce, but I'm sure there's still some there. We'll get some SPI epoxy sprayed tomorrow night...
Robert
Old 12-22-2015, 01:59 PM   #592
Bomp
Bomp's Avatar
That frame is a thing of beauty,
Quality of work is second to none.
Even on a school bus no short cuts are taken.
When Im out in the shop I reflect back to this build and it makes me try that much harder.
Thanks for posting, even the small stuff.
Merry Christmas and Happy New Year.
Bomp is offline   Reply With Quote
Old 12-22-2015, 02:35 PM   #593
Low Elco
OOOO Cleeeeean! Gotta love some blasted metal.
Low Elco is offline   Reply With Quote
Old 12-22-2015, 06:41 PM   #594
oldman3
oldman3's Avatar
Nice turn around time, frame looks great...Jim
Old 12-22-2015, 11:40 PM   #595
MP&C
MP&C's Avatar
Thanks for the comments fellas..
55 parts everywhere....
Two coats of SPI epoxy....
Had some left in the paint gun so a couple of extra pieces were moved in...
Oh yeah....the "new" trailer wheels were all blasted and ready to go, so they got a couple coats on the back side...
Robert
Old 12-24-2015, 06:39 PM   #596
MP&C
MP&C's Avatar
The frame had some slight pitting so the sides were hit with the DA to flatten things out a bit, and some Evercoat 416 used to address some of our plug weld grinding marks on the frame plates...
Here's the "winter" heating method for spraying in cold temps. 170,000 BTU aimed at the air return, and the air handler fan turned on constant to circulate the heat. Open window for air intake..
After three coats of primer, the sides of the frame are looking much better than before...
Also got some more primer on these parts as well, should be ready for blocking in a few days.
Robert
Old 12-24-2015, 06:45 PM   #597
duallyjams
duallyjams's Avatar
Have a Merry Christmas
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 12-24-2015, 07:02 PM   #598
Bomp
Bomp's Avatar
Nice and Clean.
Merry Christmas
Old 12-25-2015, 01:04 AM   #599
MP&C
MP&C's Avatar
Thanks guys. Merry Christmas everyone!
Robert
Old 12-27-2015, 07:54 PM   #600
MP&C
MP&C's Avatar
The other day when we primed the frame a second time we also did the front side of the trailer wheels..
and today I mixed up some Centari that has been sitting on the shelf a few years.. It sprayed pretty decent...
And more blocking.....
Robert
