Closed Thread
Old 03-08-2010, 07:51 PM   #601
MalibuVLX
Re: Got some new wheels: Boss 338's in 20x10 and 20x8.5
Keith,
Thanks for your help on this. I spoke with a guy that distributes the American Eagle stuff today out of Ohio. He was pretty much a tool and advised me to put a spacer on it and the others are going to be available in a month or so. So bottom line, S.O.L.
The cap is not an issue right now, the actual rotor flange bottoms out where the center hooks in. I am off about 1/2 in. I have a set of spacers, but was trying to avoid it.
I read this entire post and looked for part numbers. Sorry if I missed it. If you come across the mfg or where you bought them, that would be a big help as well. I got these new 1 in rotors from a local CarQuest from a guy that actuallly knows cars/trucks w/out having to have the VIN to look up a part.
MalibuVLX is offline
Old 03-08-2010, 08:17 PM   #602
lolife99
67-72 parts collector,…
lolife99's Avatar
Originally Posted by MalibuVLX View Post
Keith,
Just adding the 1" rotors won't work. (My SSBC rotors or any other 1" rotors)
You have to change spindles and calipers.
No way around it.
If your wheels are about 1/2" from seating on the rotor flange,... you have the 1.25" rotors.
If you plan to lower it, just purchase the drop spindles for 1" rotors.
I recommend Belltech. (they make both versions)
Then,... just swap your calipers for some 1" calipers from your local parts store.
Keith
Convert to disc brakes.
lolife99 is offline
Old 03-08-2010, 09:07 PM   #603
zammer
Addicted user
zammer's Avatar
I got my 1" rotors from NAPA... Of course that is NAPA in Canada, so it may be different in the US..
Kris
zammer is offline
Old 03-08-2010, 09:08 PM   #604
zammer
Addicted user
zammer's Avatar
A better angle..
zammer is offline
Old 03-09-2010, 12:33 PM   #605
TyKby2
TyKby2's Avatar
What kind of link system is that I have never seen one set up like that.
Kevin
1974 Chevy C-10 (The Mistress)
1971 VW Bus
1973 VW Super Beetle
1996 Jeep Cherokee
TyKby2 is offline
Old 03-09-2010, 01:29 PM   #606
lolife99
lolife99's Avatar
Looks like the rear suspension from RideTech.
Keith
lolife99 is offline
Old 03-09-2010, 01:33 PM   #607
TyKby2
TyKby2's Avatar
thats cool i just haven't seen that set up before, i've always seen 4 links with air bags. is that a bolt on kit for that model of truck.
Kevin
1971 VW Bus
1996 Jeep Cherokee
TyKby2 is offline
Old 03-09-2010, 04:04 PM   #608
zammer
Addicted user
zammer's Avatar
Yeah its a "Cool Ride" front and rear full kit from Ride Tech ( ART ) for the 62 or 63 > 72 2wd trucks and blazers
It is a bolt on suspension that includes lots of grinding stock rivets off of the old components... Not too big of a deal as I have been grinding just as many bolts off the frame as rivets.. I can't wait to try it out... Check out ride tech's website as they have more detailed pics and prices..
KRis
zammer is offline
Old 03-09-2010, 04:22 PM   #609
TyKby2
TyKby2's Avatar
do they have square body stuff
Kevin
1971 VW Bus
1996 Jeep Cherokee
TyKby2 is offline
Old 03-09-2010, 04:51 PM   #610
zammer
Addicted user
zammer's Avatar
Yes they do... check out this write-up on them..
http://67-72chevytrucks.com/vboard/s...d.php?t=344982
ALso, yo may be able to do a trailing arm suspension like the kit I have on your square if you want to get rid of the leaf springs..
CCP makes a trailing arm kit for squares now I see, check them out too..
Kris
zammer is offline
Old 03-09-2010, 11:16 PM   #611
TyKby2
TyKby2's Avatar
Thanks, I'll have to go check it out. Anymore info on the wheels, oh, what happened to the 20x8.5 wheel with 5 on 5 bolt pattern they don't list it anymore.
Kevin
1971 VW Bus
1996 Jeep Cherokee
TyKby2 is offline
Old 03-09-2010, 11:27 PM   #612
brossow
Amateur Rust Fighter
brossow's Avatar
That's a damn good question. Maybe it's been temporarily removed while they re-tool. Looks like someone's gonna have to make another call. I'm gonna if I waited all these months just for them to pull the plug on the size I need.
Brent
'72 Chevy SWB stepside - [ Build Thread ]
'79 ChevMC SWB fleetside - [ Build Thread ]
'64 Chevy SWB fleetside & '66 Chevy SWB stepside (waiting in the wings...)
brossow is offline
Old 03-11-2010, 01:04 PM   #613
RED67
Forever Grateful
RED67's Avatar
any word if they modified these wheels....I remember reading something about Thursday....
R.I.P Dad 04-07-42 - 05-27-09
RED67 is offline
Old 03-11-2010, 01:58 PM   #614
jam-bo383
jam-bo383's Avatar
Question: I've got these wheels (18x8) for my 78 Blazer that already has drop spindles for 1.25" rotors. Would best bet be to have my rotors machined? I don't mind having it done since I have friends who run a machine shop. I just want to know if that is just as good an option (& def. cheaper) than having to purchase new spindles, rotors, etc.
jam-bo383 is offline
Old 03-11-2010, 03:43 PM   #615
lolife99
lolife99's Avatar
Even with machining the diameter of the hub,... the length of the hub on the 1.25" rotors is still too long.
Look at the pics I posted, showing the difference in the two rotors.
The 1" rotors just barely work, and then you still have to clip the tabs on the center caps to clear the rotor dust cap.
Everyone needs to wait on purchasing these wheels until the new wheel design comes out,... or plan on swapping to 1" rotors.
Keith
lolife99 is offline
Old 03-11-2010, 04:27 PM   #616
mrhino
well, I didnt wont to wait for god knows how long for a set of wheels, That may or may not be revised. so I spent $50 and had my 1.25 rotors machined down, I did have to flatten the grease cap and cut the tabs of the chrome cap. It can be done. $588 for wheels, $50 machine work, having cool wheels on my truck today! priceless
mrhino is offline
Old 03-11-2010, 04:40 PM   #617
jam-bo383
jam-bo383's Avatar
No mods to my spindles are necessary? I don't want to spend a ton o' cash & have to un-do what I've already done! BTW, thanks, in advance, for you guys' help! Very new to this forum & there's tons of info here.
Nevermind, mrhino, I just saw your older post stating that you had to take a little length off the spindle. I'm assuming that you re drilled the hole for the cotter pin? Approx. how much did you remove of the top?
Old 03-11-2010, 04:48 PM   #618
big mike71
big mike71's Avatar
Is $588.00 for all four wheels?
I'm not as good as I once was, But I'm as good once as I ever was.
big mike71 is offline
Old 03-11-2010, 05:31 PM   #619
mrhino
no I used the same hole, I just took off maybe 3/16 of a inch
mrhino is offline
Old 03-11-2010, 05:34 PM   #620
mrhino
yep! including shipping Ebay its a wonderful thing
mrhino is offline
Old 03-11-2010, 07:55 PM   #621
6D8_C10
6D8_C10's Avatar
What are your wheels, 18s or 20s?
What about tire size?
68 c10 350/th350 winter daily driver
90 Nissan 180sx, sr20det gt2871r turbo, track car,summer daily driver
"Just so we are reminded of those who are held back,
Up front there ought to be a Man in Black". Johnny Cash.
6D8_C10 is offline
Old 03-11-2010, 08:12 PM   #622
TyKby2
TyKby2's Avatar
What happened to the 20x8.5 wheel with 5 on 5 bolt pattern they don't list it anymore?
Kevin
1971 VW Bus
1996 Jeep Cherokee
TyKby2 is offline
Old 03-11-2010, 09:13 PM   #623
brossow
brossow's Avatar
Call 'em and ask. That's what any of us would have to do. I haven't had time yet.
Brent
brossow is offline
Old 03-11-2010, 09:52 PM   #624
TyKby2
TyKby2's Avatar
I don't want this size, but I was just wondering for the guys that do.
Kevin
1971 VW Bus
1996 Jeep Cherokee
TyKby2 is offline
Old 03-12-2010, 09:06 AM   #625
fast 95
fast 95's Avatar
Just so you guys know, the 18x9.5's have a deeper lip than the 20x10's. My cousin bought a set for his S10 and we compared them. Just some food for thought for the guys that are looking for that real deep wheel in the rear.
fast 95 is offline
Closed Thread
