Old 12-30-2015, 12:34 AM   #601
MP&C
MP&C's Avatar
Re: 55 Wagon Progress
Made another trip to the car wash tonight. Tire soak, high pressure soap, and a rinse...
While Kyle was media blasting, I used the 36" AFS to block the tail gate.
This had been blocked a couple times before and never seemed to come out right. Of course, I was using a shorter block as well. The 36 really did the trick in getting things nice and flat...
.....and getting things ready for another epoxy session...
Moved these out of the way, closer to the door so we can get tires on this weekend. Order trim rings today, now for some baby moons that fit... I swear they get brighter every time I look at them..
Robert
MP&C is offline   Reply With Quote
Old 12-30-2015, 02:03 AM   #602
Bomp
Bomp's Avatar
Looks great.
How many times, or what's the deciding factor from laying down epoxy vs primer or high build primer?
Must forgive my questions,,, I'm in class here learning from the master. : )
Bomp is offline   Reply With Quote
Old 12-30-2015, 06:55 PM   #603
MP&C
MP&C's Avatar
I used slick sand on the last car we did, the 65 Fairlane:
http://www.garagejournal.com/forum/s...ad.php?t=86935
It does have a couple spots that look like some shrinking took place. One of those I see it but the owner doesn't but I need to improve the next one kinda things.
I think the epoxy will give a much better base than the slick sand as epoxy doesn't have the porosity that the SS does. So other than some spots of evercoat 416, most everything on this build has been epoxy. Just wanted to try it and see if it held up any better.
Robert
Old 01-01-2016, 09:37 PM   #604
MP&C
MP&C's Avatar
Picked up some 400 grit PSA paper yesterday, used it this evening to get the tail gate finished to 400 grit, next week we'll wet sand to 600 grit.
Nephew Chris came over and helped Kyle and I get the frame off the rotisserie and back on the floor..
With the rotisserie freed up, we now have a new paint fixture...
Parts prepped for epoxy primer tomorrow...
While I was getting these parts taped off, Kyle started blowing apart the rear end for media blasting..
Robert
Old 01-01-2016, 10:07 PM   #605
Advanced Design
Advanced Design's Avatar
I like the way you have tied off the small pieces side to side so they don't move around when painting. A simple yet great idea.
Progress and parts are looking really good.
Advanced Design is offline   Reply With Quote
Old 01-03-2016, 12:15 AM   #606
MP&C
MP&C's Avatar
yeah, that's one thing I can't stand is parts spinning around while you're trying to spray them..
Today Kyle worked on getting the axle pads welded on....
.....while I was spraying some SPI epoxy....
.....and while I had some epoxy mixed, we poured some inside the tailgate to seal the inner and outer skins ..
Axle pads done, then heated the opposite side to counter the weld shrinking...
It's real close, just a little more straightening to do...
other parts from the booth today....
....and then sprayed some silver metallic Imron on the A-arms..
Robert
Old 01-03-2016, 10:49 AM   #607
Turtleman
Turtleman's Avatar
Imron!!.......... ACKKkkkkkk......... I use to paint Aircraft with that... yuck!
(Great Product though)
Turtleman is offline   Reply With Quote
Old 01-03-2016, 11:06 AM   #608
oldman3
oldman3's Avatar
Man, I thought they quit making that years ago, guess not...Jim
oldman3 is offline   Reply With Quote
Old 01-03-2016, 11:13 AM   #609
MP&C
MP&C's Avatar
this gallon can has been sitting around for quite awhile (going on 20 years). Can't bring myself to throw it away, for things like these a-arms it gives a tough as nails finish...
Robert
Old 01-03-2016, 03:06 PM   #610
swamp rat
swamp rat's Avatar
I am curious on the heating of the opposite side of the perches, was there a visible amount of warpage after welding or was this step more just precautionary?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-03-2016, 03:43 PM   #611
MP&C
MP&C's Avatar
OK, here's the backwoods method of checking the rear for any weld distortion. Bolt everything back together, including wheels. Rotate the wheels to insure they are indeed NOT BENT. Now raise the rear up in the air and place tires down on top of a couple milk crates. Now grab the third member and rotate around, looking for any wobble in the wheels. Typically with the welding process causing some shrinking, you will notice a wider area opposite the pads. We used a tape measure between the wheel edges, and notated the dimensions taken after rotating the axle in 90 degree increments. Heat up the long side to add some shrink there. Let manually cool and check again..
Robert
Old 01-04-2016, 01:58 AM   #612
swamp rat
swamp rat's Avatar
Thank you for the instruction, i never welded perches but have been concerned about the heat of welding if i did an axle swap ect, it was suggested i may want to do an axle swap to replace my Eaton, i have seen others post about welding perches but haven't read about anybody checking or dealing with warpage after welding, i would be concerned about wear, wobble, stress ect.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-06-2016, 12:24 AM   #613
MP&C
MP&C's Avatar
Well tonight we worked on getting the parts out of the booth so we can get the next load of parts ready for epoxy, and in between spent some more time on straightening the rear. In measuring at the bead of the 18" wheels, we had a +/- .020 on the passenger side and a +/- .035 on the drivers side.
....and more heat applied for some shrink..
We'll let that cool and get some of the front end parts bolted up..
Robert
Old 01-10-2016, 01:49 AM   #614
MP&C
MP&C's Avatar
Getting the front end put together...
....and more blocking and hanging parts in prep for the next round of epoxy...
The doors are getting real close to needing wet sanding..
Robert
Old 01-10-2016, 09:33 AM   #615
Gary V
Active Member
Gary V's Avatar
This project is simply fantastic! Always wanted a 55 wagon. Thank you very much for sharing this great build and your metal working skills!
Best regards,
Gary
DOMERINGER BUILD
Gary V is offline   Reply With Quote
Old 01-10-2016, 10:13 AM   #616
oldman3
oldman3's Avatar
Looks great...Jim
Old 01-10-2016, 12:16 PM   #617
MP&C
MP&C's Avatar
Thanks for the comments guys!
Here's a video taken yesterday using the 36" AFS sander. Note how the sander is grasped and the fact that this promotes letting the sandpaper do the work without "leaning" on it. Applying downward force through your palm to get the job done more quickly runs the risk of deflecting the sander downward at that point, causing low spots...
Block Sanding Video
Robert
Old 01-10-2016, 02:00 PM   #618
Advanced Design
Great video Robert. The tutorial on checking and correcting rear axle tube deflection is good too. In checking the run out at the wheel, is there possibility some of the run out is the wheel? One set I bought once had 0.040" run out mounted on the wheel balancer.
Old 01-10-2016, 02:06 PM   #619
trixter99
I have no time for this
trixter99's Avatar
I am curious why you aren't using a good 2k primer over the SPI epoxy then sanding the 2k and finishing withe epoxy then wet sand to finish. Is it to keep mil thickness to a minimum? With the amount of time you put into metal work it wouldn't take much 2k to finish your panels. I'm not bashing in any way I'm just wondering. I was in the trade for a lot of years and am a huge fan of your skills and patience.
1986 Chevy short box ( PROJECT )
1994 Chevy Blazer lifted 6"
2009 Gmc 2500 HD
1999 Hugger orange Camaro SS
2007 BMW X5 Sport
trixter99 is offline   Reply With Quote
Old 01-10-2016, 04:11 PM   #620
MP&C
MP&C's Avatar
With housing stationary and wheels rotated, we did see a bit of fluctuation of about +/- .005 to .010 in the wheels, but it was rather sporadic and not relative to the welded pads. When the tires where stationary and the housing was rotated around, before our heating efforts the runout started at about +/- .050, and was directly related to the welded pad location. At the point the housing was being rotated, the dial indicator remained in the same spot on the wheel, so although the wheel isn't perfect, the reading should have reflected housing issues only.
Our last major restoration was on a 65 Fairlane, where we did use some Slick Sand. A few years later, I now notice some slight shrinkage in areas and given SS isuch more porous and less stable IMO than epoxy, I am trying epoxy only to see if it provides better results...
Robert
Old 01-10-2016, 09:56 PM   #621
trixter99
trixter99's Avatar
I hear ya on the shrinkage of slick sand I used it a couple times and it shrank a little bit.
2009 Gmc 2500 HD
2007 BMW X5 Sport
Old 01-12-2016, 11:12 PM   #622
MP&C
MP&C's Avatar
Well Kyle was mostly on his own tonight as I had some repairs to do on the wife's vehicle..
New U-bolts came in yesterday, they have a pretty good selection on their web site if anyone needs some....
Threads taped off and all the parts media blasted...
Then Kyle got the rear torn down for media blasting as well. Blast cabinet just the right size..
Robert
Old 01-13-2016, 07:38 PM   #623
MP&C
MP&C's Avatar
Some Hoosier Profile parts showed up for the new wheeling machine.. Joe Andrews does some real nice work..
Robert
Old 01-13-2016, 07:53 PM   #624
oldman3
oldman3's Avatar
Whoa, those look super...Jim
Old 01-13-2016, 08:13 PM   #625
FarmerSid
FarmerSid's Avatar
Awesome Robert! I have a C4 IRS that is all aluminum but the input and output yokes are steel and rusty. Any recommendations on prepping the steel yokes for paint without complete disassembly of the rear end?
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
