Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 03-29-2016, 11:22 PM   #626
Captainfab
60-66 Nut
Re: Power Steering Adapter Plates
Well, yes and no.
I have not had the time to develop one on my own since I am still working 80 hrs a week every week. What I do have to offer for the '60-'62's is in sort of a kit form put together with help from a couple of members. I don't currently have pictures of what I offer, I need to do that.
Here are a couple of threads from the guys that helped me with this.
http://www.67-72chevytrucks.com/vboa...d.php?t=657913
http://www.67-72chevytrucks.com/vboa...d.php?t=683028
It is a little more involved than for the '63-'66's but I have sold several to other members.
Originally Posted by Task Force Era View Post
I was skimming thru the thread and a few years back you didn't have a 60-62 plate. Do you have them now?
Old 03-30-2016, 11:39 AM   #627
Task Force Era
Task Force Era's Avatar
Ahhh. OK. I may could make that work on mine...
I have a 84 donor truck so I'm gonna swap the 305 outta that along with the cross member, steering box and steering column hopefully and all the brake components...
And speaking of, the 60-62 power brake booster plate you make. Will a 84 C10 unit work on that??
Task Force Era is offline   Reply With Quote
Old 03-30-2016, 11:42 PM   #628
Captainfab
60-66 Nut
No the '73-'87 truck boosters are not compatible with any of my booster brackets. They can not be used as the factory mounting brackets are riveted to the booster. There is a list of compatible boosters in the for sale thread. That list is also included with every booster bracket.
Here in post #70.
http://www.67-72chevytrucks.com/vboa...=357542&page=3
Old 04-01-2016, 01:23 PM   #629
kchampagne
kchampagne's Avatar
Hey Captain! Just wanted to confirm my receipt of the bracket, flange and tube. Excellent quality and workmanship! Thanks! Quick question on installation, do you recommend welding the tube to the original shaft and/or drilling the tube and shaft and install a bolt through? Should I install 2 bolts to be safe? Also, is it recommended to install a u-joint to ensure the steering shaft lines up with the new box? I am using the original steering column with no tilt. Thanks again!!
kchampagne is offline   Reply With Quote
Old 04-02-2016, 12:02 AM   #630
Captainfab
60-66 Nut
One grade 8, 1/4" or 5/16" bolt should be sufficient and my preferred attachment method. Welding would optional and I would not weld continuous. Two good stitches 180* apart.
Old 04-02-2016, 05:33 PM   #631
Lugnutz65
Lugnutz65's Avatar
Order placed. Looking forward to getting my 1974 PS box installed. Thanks.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 04-02-2016, 11:51 PM   #632
Captainfab
60-66 Nut
Payment received. I will ship your adapter plate on Monday.
Old 04-10-2016, 11:37 PM   #633
Captainfab
60-66 Nut
Here are some pictures, and dimensions for installing these power steering box adapter plates on the K series frames. Starting in post #136.
http://www.67-72chevytrucks.com/vboa...=632508&page=6
Many thanks to Les Otte for posting this info in his build thread.
Old 04-13-2016, 08:06 PM   #634
dwlambert1701
Got my plate in the mail today, I'll have to get this thing right though when I install it. Especially since the original Pump has been long since removed, gotta love full restorations. Thanks again brother
dwlambert1701 is offline   Reply With Quote
Old 04-17-2016, 02:08 PM   #635
The Rocknrod
Moderator
The Rocknrod's Avatar
My Steering arm is longer than my stock type idler arm. Think that'll be an issue?
Old 04-17-2016, 03:04 PM   #636
Bart Savage
Bart Savage's Avatar
Originally Posted by Bart Savage View Post
Captainfab, I"m doing a 2004 5.3 vortech swap into a 63 Suburban and need a steering box adapter plate and whatever else is needed for the steering swap. Please advise and pm with the particulars. Also need guidance on the correct pump and other bits to connect to stock steering column. Thank you for your expertise and knowledge, Scott
Still having a difficult time with the pitman arm on the 1989 r series 2wd steering gear. It's making the center link hit/rub the cross member. I'd welded the plate in place and discovered the issue...I cut it back out and double checked the position with the provided template with 3 of my car club buddies and it checks it ok. This is s 63 Suburbdn 2wd.....is there any difference in the c10 truck vs suburban? I've scoured the forum threads and and I'm at a loss! The 89 gear is used because I've done a 5.3 Vortec swap. Please help.
Scott
925-216-8933
Bart Savage is offline   Reply With Quote
Old 04-17-2016, 11:54 PM   #637
Captainfab
60-66 Nut
It isn't ideal but it will work. My Suburban has been that way for over 120,000 miles.
There is no difference between a Suburban and a pickup that would cause this issue. Are you certain that you have the draglink installed correctly? Pictures can often be a big help.
Scott
925-216-8933
Old 04-20-2016, 12:54 AM   #638
Bart Savage
then only thing removed from the steering assy was the steering gear/pitmanarm. what i discovered last night was the ac delco r1500 89 ps gearbox has a tapered shaft for the pitman arm however the ac delco 89 pitman arm hole is not tapered. Should it be? It seems as though it should be... At this point im going to return the parts and go with a non metric unit and get metric to standard hose adapters...what is the years recommended for the ps gearbox?
Old 04-20-2016, 11:20 PM   #639
Captainfab
60-66 Nut
Yes the pitman arm to the sector shaft is a tapered fit.
As far as I know the '68-'86 C series and '87-'91 R series steering boxes all interchange. The '68-'79 should have SAE style fittings. From about 1980 and up will be Metric with an O-ring.
I have no idea why you are having this issue. As I said in one of my PM's with you, I have not used a steering box that new. Without any pictures it is even more difficult to help troubleshoot.
Old 05-01-2016, 02:20 AM   #640
Bart Savage
I returned the 89 2wd r1500 gear and pitman arm eating 50$ in shipping and went to my local yard and picked an 86 2wd suburban and all bolted up fine.
Old 05-01-2016, 11:50 PM   #641
Captainfab
60-66 Nut
I am sorry to hear you lost $50.00 but I am glad you solved the issue. I will have to check into the '87-'91 R series steering box and pitman arm further.
Old 05-05-2016, 08:39 PM   #642
GrumpysC10
GrumpysC10's Avatar
Hey Capt. The steering box looks the same as the 96 Grand Cherokee. I only ask because I did a conversion on my 68 Chevelle from the original Saginaw steering box to a 96 grand Cherokee which was the same box just different gear ratio and it bolted right on, I can see that the bracket would be needed for this but could it be a direct bolt on with the bracket?
GrumpysC10 is offline   Reply With Quote
Old 05-05-2016, 11:39 PM   #643
Captainfab
60-66 Nut
I have no idea if a '96 Cherokee steering box will work, but I doubt it.
Old 05-07-2016, 11:19 PM   #644
jamier2
Originally Posted by GrumpysC10 View Post
... I did a conversion on my 68 Chevelle...
I did the same thing on my 66 Chevelle LS swap car. I know for sure the box mounts are the same, not sure about the travel of the pitman arm but I'm thinking that the correct truck pitman arm should be easy to swap out. I got my Cherokee box cheap from rock auto so when I get ready to do my 63 I'm going to give it a shot. I love the Cherokee box in the Chevelle.
jamier2 is offline   Reply With Quote
Old 05-07-2016, 11:52 PM   #645
Captainfab
60-66 Nut
I did a quick search and the '96-'98 Cherokee steering box mounts to the inside of the frame and has only 3 bolt holes. Not going to work......
Old 05-08-2016, 08:59 AM   #646
jamier2
Ok then. I didn't realize the mounts are different. On the research I did for that swap everyone said Saginaw had basically one box casing. Guess I'll use a normal one. Thanks for the research and I am looking forward to ordering a few of your products when I decide to start on this truck.
Old 05-08-2016, 11:05 PM   #647
Captainfab
60-66 Nut
No, there are more than one Saginaw box casting.
Old 05-20-2016, 11:49 PM   #648
Captainfab
60-66 Nut
I wanted to post this pic here so those of you making this conversion or contemplating it, can see what a power steering upgrade should look like. This is a very nice installation by member NVS-C10. He has a build thread if you would like to see more of his nice truck.
Old 06-08-2016, 02:16 PM   #649
stacerbob
BODY SHOP SUPPLIES INC.
stacerbob's Avatar
Does spacing the box off the frame have any effect on the steering center position? as in does it turn sharper one way than it does the other?
I have all the steering linkage and gear box off of a 72 I plan to install.
stacerbob is offline   Reply With Quote
Old 06-08-2016, 11:32 PM   #650
Captainfab
60-66 Nut
It does affect the turning radius initially. But once you have a wheel alignment, that issue should be taken care of.
