Old 12-27-2012, 11:14 PM   #626
JRANGER
JRANGER's Avatar
Re: Project 78 High Sierra
lol its also dented up so chrome it is
JRANGER is offline   Reply With Quote
Old 12-28-2012, 09:00 AM   #627
motornut
78K & 79C Jimmys
motornut's Avatar
Originally Posted by JRANGER View Post
Well got the tach all hooked up.....She fires up at 1600RPM when cold....Once she calms down idles about 1050RPPM...Is that high for my engine? Turned the idle screw a bit but it wouldnt go lower
Also the Radiator hose wasnt extremely tight on the block so it squirted out a bit on the block and valve covers...BOOO! Lol
I heard its suppose idle around 700 but i dont know for sure on an 82 305....It was warm when idling warm....It idles much higher when cold almost 2000RPM
Tach looks good, fits right in
my 79 305 stock should be Auto500rpm (D) ,Man600rpm (N)
fast idle Auto1600rpm(P)(N),Man1300rpm
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 12-28-2012, 10:22 AM   #628
JRANGER
JRANGER's Avatar
Interesting...So its really weird...When frozen cold it idles at 500, fast idle at 1000 but when slightly warmer it idles at 900 and fast idle is at 1300.....IM going to raise it to 1600 and call it a day as i have no clue whats going on but it doesnt seem like it will go futher...Someone mentioned something about some arm i can adjust on the passenger side but im not sure
Old 12-29-2012, 03:27 PM   #629
JRANGER
JRANGER's Avatar
Ok with the bed off i finally put the rear poly urethane body mounts on.... have had the front ones on but i couldnt get the rears cut out...So with the bed off i took my Reciprocating Saw and hacked them out...
Also someone tell me where the remaining ones go??? Im clueless
Old 12-29-2012, 04:06 PM   #630
cubber
I think those might go under the radiator core support.
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 12-29-2012, 06:08 PM   #631
trout
Those go under the bottom
Edited by staff
trout is offline   Reply With Quote
Old 12-29-2012, 07:06 PM   #632
JRANGER
JRANGER's Avatar
Under the bottom of what? The Cab mounts already have the Cone shaped bottom connectors
Old 12-29-2012, 07:09 PM   #633
JRANGER
JRANGER's Avatar
Just bought some Modular connectors to use to re-wire the cluster all together...Tired of this copper piece moving and touching each other....Im going to solder wires directly to the copper ends and then hot glue it all in place to hold it solid....Then take the other end and wire it into the male connector
Should be what im up to next weekend if they arrive
Old 12-29-2012, 08:21 PM   #634
77ChevySharkBite
77ChevySharkBite's Avatar
Nice man sounds awesome, gimme an hour or so you'll see the goodies I got today I actually decided to put my big bit pants on bundle up and work on the beast today
Korwin
77 C10 Silverado Sharkbite LWB Build
67 Chevy C10 Frame Off
06 Dodge Magnum 2.7v6 aka swag wag!
2010 Honda Accord 2.4I4 DD aka Liquid Metal
77ChevySharkBite is offline   Reply With Quote
Old 12-29-2012, 08:28 PM   #635
cubber
^^ I'm pretty sure, especially if you bought the whole body kit, and not just the cab bushings.
=MATTHEW
Old 12-29-2012, 09:02 PM   #636
JRANGER
JRANGER's Avatar
I believe your right Cuz you da MAN!
Old 12-29-2012, 10:21 PM   #637
cubber
305! 305! 305!
=MATTHEW
Old 12-29-2012, 10:23 PM   #638
JRANGER
JRANGER's Avatar
lol......Too bad the 305 is SLOW!!! I wonder what gears I have...hmmmmm
Old 12-31-2012, 07:12 PM   #639
JRANGER
JRANGER's Avatar
Well got to work on the truck real quick and have it starting up much better...The choke was opening up to quickly so i turned it back a notch and it started after 2 tries...Im pretty sure it would of been 1 try but i was trying to hit the gas and caused it to stall now im just working on the high idle rpm and i think it will be as good as gold
Old 12-31-2012, 09:45 PM   #640
cubber
Your ability to figure out how something works and then repair it is really impressive, and thats no BS.
=MATTHEW
Old 12-31-2012, 09:55 PM   #641
JRANGER
JRANGER's Avatar
Google is king
Old 12-31-2012, 10:42 PM   #642
Billy81
Billy81's Avatar
I am really digging that tach, looks pretty cool.
Billy81 is offline   Reply With Quote
Old 01-01-2013, 01:08 PM   #643
JRANGER
JRANGER's Avatar
The tach was $18 Dragon Digital off EBAY I love it...They make other Gauges too so i may have to think about going all digital on the side but im not sure i want too yet
Old 01-01-2013, 01:09 PM   #644
JRANGER
JRANGER's Avatar
I actually tried the cold start today...It took 3 tries but definitely starting better...Now i didnt try to give it gas until after the third start so im pretty sure its good...Im going to try again later
Old 01-01-2013, 04:33 PM   #645
JRANGER
JRANGER's Avatar
Look what I got today from Will aka "killthewabbit"
Looks great...Underside was a bit Rusty so i hit it with the rustoleum i had left over from the frame painting....House Stinks a little bit now though lol
Going to have to get some WD-40 and hit the stock bolts to get the old bumper off though......Damn suckers are stuck!!!
Old 01-01-2013, 05:12 PM   #646
JRANGER
JRANGER's Avatar
O and success of start up.....I adjusted the High RPM a little too much as when it starts to warm up it hits 2000 RPMs again but if i pump the gas a few times then start the truck and slightly hold my foot on the gas for a sec she doesnt stall out Woot
Old 01-01-2013, 05:39 PM   #647
cubber
That's good news! Nice bumper, too.
=MATTHEW
Old 01-02-2013, 12:04 AM   #648
chevybuilder18
chevybuilder18's Avatar
love the bumper!! Lol.
Her name is Quicksilver
1978 Chevrolet silverado, shortbox stepside currently being swapped IN is a LM7 5300 vortec, 4l80E, factory 4.11s, slammed, a dream ride and coined QUICKSILVER
gotta pay $$ if you wanna play
chevybuilder18 is offline   Reply With Quote
Old 01-02-2013, 12:14 AM   #649
chevybuilder18
i second this. This is your first project restoration and customization of a vehicle, if i may say before this even happened you were intrested in doing this but knew nothing but now you do.. These kinda things take years ive heard but youve made it look easy
Old 01-02-2013, 12:26 AM   #650
JRANGER
JRANGER's Avatar
HaHa well thanks....I was always interested in trying to do a restore of an old Mustang. I never intended to restore this truck...Just wanted a beater but once i started on the floor panels i just got hooked... I am nothing without this website and all the articles on the web. Its everyone elses knowledge that allows me to find the information I needed to learn this stuff... Then on top of that when you have these guys here in Nashville that will come and give you a hand you cant help but want to learn...Ive always been able to learn quickly by simply watching...Knowledge is power and the more i can absorb the better....The lessons I learn from this truck will be handy when i get that 68 Mustang i want.....Nothing is perfect but every mistake is a lesson towards doing it the right the next time...Plus i like working with my hands and I enjoy the feeling you get from doing it yourself..
Its just how I do everything.... Just another thing to learn
