#651 |
Re: Its Mine the World Famous 67 Dragtruck
Very nice, got a set of those too. Same guy who gave me mine gave me a L79 corvette winters intake manifold.
#652 |
Hey leftcoast,
Do you happen to know what year these came on ? Just curious, the bolt holes are offset if that helps. They're going on a set of pretty nice 034 heads with shaft mount rockers. Don't tell anyone, it's a secret. |
#653 |
Should be early 1960's vettes. Not sure what year they stopped putting them on the cars, but I know it was the late 80's when they stopped making them at GM, the set I got were the last at the dealer and my stepgrandpa had to have them. Sadly I threw away the boxes they came in w/ the part numbers.
#654 |
I found it. They came on 55 to 59.
#655 |
THE DAMN YANKEE
my bad on the extra 10 ft it's been almost 20 years since i've crossed that stripe! it won't be another year though. 09 i'll have some video and #s hopfully 1/2 way respectfull #s
#656 |
good luck with your times I was just pickin at you about the 10 ft.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
#657 |
Hey,
Think I'm gonna' try the 4-7 cam swap. I've got a freind picked up 2 tenths and says it takes some harmonics out. Any thoughts or comments ? |
#658 |
there was a story about it in the hot rod a while ago and i seriously considering doing the same
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
#659 |
My next cam is a 4/7 swap!
#660 |
70rs/ss talked me out of the extra $$$ for the street but for the
track I don't see passing. Did I mention my freind picked up 2-tenths. And he's NO ROOKIE |
#661 |
Cross your fingers guys I took a 502 block to the machine shop yesterday hoping it will clear at .030. With my stroker crank that will make a 548.
#662 |
fingers and toes crossed ....... let me know wat happened
#663 |
Block is fine we are gonna have a 548 in there by spring.
#664 |
THE DAMN YANKEE
it's gonna be nasty! if i get back down to panama city fl for work i'll hit ya up and make a road trip your way. phipp
#665 | |
Cool.
#666 |
glad to hear it wasn't junk, good luck
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
#667 |
I actually did some trading and got a bowtie block so if it checks out I may run it to keep from having to run gen VI stuff. The gen Vi block is already bored but the guy it belongs to really didn't want to sell it anyway so he may keep it for his boat if the bowtie block checks out.
This thread needed another post I wasn't liking how many it had.
#668 | |
Rusty but Trusty
Hope you have great luck with the new engine. Lee
72 SWB, 454 / th400... hoping the kids don't get all the parts before it gets built |
#669 |
I'm gonna upgrade the anti roll bar to get it not to twist as much. It has twisted since I bought and Tom said it did this with him also.
#670 |
i've seen on a couple of ocasions they used an helper airbag inside the coil to counter that
#671 |
that wouldn't work for me as I don't have coils. I have coilovers but I haven't tried stiffening the right shock but it might help a little.
#672 |
it would take some trail and error but you might want to experiment with heavier spring on one side instead twisting up the shock on one side might as this might end up unbalancing the truck halfway down the track do to the thumb when it hits bottom
or mount shockwaves (pricey)
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts Last edited by watahyahknow; 01-19-2009 at 07:47 PM. |
#673 |
Junior Member
Hey DJ
Dont mean to change the subject but what RPM do you leave the line at? I know track conditions are an issue but was curious about how much your able to put down without getting scary. Thanks
68 GMC 565 BBC Abruzzi super pro glide 9.85@135.00 ![]() |
#674 |
I have a pretty tight convertor so I don't have a huge window to work with. I have left from 3000 to 4000. 4000 is up againest the convertor. The truck actually like more power on the starting line. With the bigger slicks (33x10.5w's) it would take all I could throw at it. I left on 250 and 300 shots of spray. Tom actually left on 2 kits with a 31x10.5w.
#675 |
mini truck racer
It looks twisted and may be some what , but more than anything it is the axles natural rotation under power . The driverside tire is drivin into the ground and the passengerside tire is being lifted as the pinion is forced to rotate . Anti sway gets rid of most of this .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
