01-10-2017, 11:14 AM | #651 |
Re: 85 GMC Sierra "Scarlett"
Have you figured out your problem yet?
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
01-10-2017, 11:16 AM | #652 |
Happy to be here
Not at this time. I know I will need one if I start painting, but so far I have been fine with the tools I am using.
Not yet. I'm going to pull the pick up tube and nozzle assembly to see if there's an issue there.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 01-10-2017 at 11:27 AM. |
01-10-2017, 11:21 AM | #653 |
Happy to be here
Monday was Monday for sure, but I still managed to get some work done in the shop. Since the starter ahd been recently replaced I opted to clean it up rather than replace it. I came home and cleaned, prepped, and sprayed a coat of color before heading out to the gym.
After my workout and some dinner, I got another couple of coats on the starter. I still had a bit of time before I needed to go in so I cleaned up the crank pulley. Apparently I didn't get it clean enough and the paint crazed on the wet coat. Looks like I will be sanding it down again.
01-10-2017, 11:25 AM | #654 |
So you're running straight from the compressor to the blast cabinet?
01-10-2017, 11:29 AM | #655 |
Happy to be here
Yes sir. I have a small drier/regulator that I can use but I really want to add a bigger compressor and plumb the entire shop. Nothing is going to happen till after LST.
01-10-2017, 11:35 AM | #656 |
Cool good to know.
01-10-2017, 11:45 AM | #657 | |
- Robbie UNITED BY TRUCKS - classic truck video content YouTube: www.youtube.com/c/unitedbytrucks Instagram: @united_by_trucks Paw Paw '68 508 Dark Blue Custom C10 Teddy '68 GMC SWB 503 Light Green LS Build Mississippi Mud '75 Skyline Blue Patina SBC Build |
01-10-2017, 03:26 PM | #658 |
moisture will create clogging of media, the dust turns to mud. I run a coil of pex on the wall to cool the air after the compressor then a water separator it reduces moisture greatly. Again my cheapness.
01-10-2017, 08:43 PM | #659 |
What PSI are you running? Possible that your new media is to heavy with not enough PSI to create a vacuum to pick it up? To aid in air consumption I swapped out the air nozzle to an 1/8npt to 1/8 barb fitting with tubing over the barb fitting to protect it. The nozzle was roughly 3/16. I didn't notice any loss of power blasting and compressor maintains higher pressure.
01-11-2017, 01:02 AM | #660 | |
Happy to be here
01-11-2017, 01:19 AM | #661 |
Happy to be here
I went by Auto Zone today looking for starter bolts. I struck out there so I'm going to have order them.
I did pick up a new HD water pump. I'm a firm believer in replacing them when the motor is stripped bare. This evening I prepped and painted the water pump while working on cleaning the motor. The intake was bolted down with oversized washers so I pulled them. With the intake and front of the block clean, I laid down a few coats of color. I like what I see so far.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 01-11-2017 at 10:29 AM. |
01-11-2017, 01:25 AM | #662 |
no no no!
01-11-2017, 02:03 AM | #663 |
I have a pretty nice snap on blast cabinet, I usually keep glass beads in it, but I had to blast some very rusty steel so I tried the medium grit black diamond, it didn't flow very well at all. I bought a bag of the fine grit and it was much better. The glass beads are not as aggressive, but they sure flow nice.
77 k10 winter beater build http://67-72chevytrucks.com/vboard/s...d.php?t=716884 85 GMC short fleet budget build http://67-72chevytrucks.com/vboard/s...d.php?t=714222 80 C10 stepside build http://67-72chevytrucks.com/vboard/s...d.php?t=693848 |
01-11-2017, 09:53 AM | #664 | |
Happy to be here
01-11-2017, 10:54 AM | #665 |
Don't you know the only thing you buy at autozone is oil and air fresheners?
01-11-2017, 11:00 AM | #666 |
question: for general cleanup and paint prep what do you prefer?
1983 Chevy C10 250/3spd (current project truck) 1976 Chevy C10 350/350 Heavy Half (future project truck) |
01-11-2017, 12:43 PM | #667 | |
Happy to be here
01-11-2017, 02:31 PM | #668 |
I did not have good luck with black beauty in my blaster. Have you tried garnet? Works pretty good.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
01-12-2017, 08:40 AM | #669 |
Happy to be here
I plan to inspect the supply system this weekend. If there are no restrictions then I will consider my options for a different media.
01-12-2017, 08:56 AM | #670 |
Happy to be here
Last night was family night. My daughter and son in law came over for dinner. We had a nice visit, but they left early to get home and ready for work. Good visit, but my shop was calling me.
I prepped the drivers side of the block for paint. Fortunately it's fairly accessible with the headers off, so it didn't take long. I masked the frame and motor mount, then blasted some color on. It layed out nicely so I left it to dry. In the interim I decided to add some sparkle to the motor. I had ordered a polished stainless button head set from Alloy Bolts and couldn't resist any longer. I removed the timing cover bolts one at a time, and touched up behind them. As it dried I added a polished button head in place of the hex head. They add a nice bit of bling, and I love this part of my builds. Shiny objects are a distraction when your ADD. Combine that with OCD and they become an obsession. I had to have more so I installed the intake bolts as well. I used the same procedure here. By taking the bolts out one at a time and touching up as you go, it reduces the chance of gasket leaks. The end results are a bit of sparkle that's maintenance free.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 01-12-2017 at 02:00 PM. |
01-12-2017, 11:58 AM | #671 |
67-72 parts collector,…
You are a "masking machine", Ken.
I don't envy all the work you are doing.
01-12-2017, 12:08 PM | #672 |
Looks great, Ken. I like the 'one bolt at a time' idea. Very smart and efficient.
01-12-2017, 12:30 PM | #673 |
I don't mean the media nozzle to reduce down, the air nozzle inside the gun. I wouldn't recommend the slag in cabinet, I use aluminum oxide.
01-12-2017, 02:07 PM | #674 | ||
Happy to be here
01-12-2017, 02:12 PM | #675 |
I like slag for outdoor use, its aggressive but it does break down a bit more so its a little dusty for in the cabinet.
