Old 03-01-2012, 10:58 AM   #676
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: Finally starting my Longhorn 4x4 conversion
Nothing else get a non intercooled VE and swap it to p-pump. they have the better pistons to play with any way. A 24v is hard to beat once it's swapped too.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 03-02-2012, 02:04 AM   #677
Beat68CST
Beat68CST's Avatar
Non intercooled 1st gens have a little more valve lift outta their cam also, don't they?
Beat68CST is offline   Reply With Quote
Old 03-02-2012, 11:21 AM   #678
mknittle
mknittle's Avatar
This is getting interesting! I know more about the big engines that the smaller ones.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 03-02-2012, 11:29 AM   #679
mknittle
mknittle's Avatar
Originally Posted by Its ShowTime!! View Post
what rear end and front end are you using?? im building my 88 and i wanna run 52's but i dont kno what will hold up!! any suggestions
How about rockwell DDs
Mark
My GMC build.
Old 03-02-2012, 11:45 AM   #680
6lcummins
Spend a little money on a D60 and a D80 and they will hold 1500HP and be reliable other than ring and pinions in extreme circumstances.
1996 Dodge 2500 Ext Cab Long Bed P24V Cummins Turbo Diesel 5 speed 4x4
"STOCK"
ASSEMBLY THREAD
6lcummins is offline   Reply With Quote
Old 03-02-2012, 03:29 PM   #681
Dieselwrencher
I've heard that before, but the lack of duration and the fact that the 1st gen cams are weaker in the area behind the first fournal and like to break when driving a turned up p-pump. I'd use a later cam when doing the swap.
Ryan
Old 03-02-2012, 04:23 PM   #682
Dieselwrencher
Today I took the body guy more paint and picked up my seat. He had a couple other things painted for me. The radiator support, hood latch, and hood guide plate. I guess it is progress.
My lutch is supposed to be here today, conversion lines next week, and some other misc stuff may trickle in later. I did get the RH door lock installed and it works! Now it is getting time to install door panels. Does anyone else think a layer of plastic or some thing will help eliminate road noise and stuff?
Ryan
Old 03-03-2012, 10:39 AM   #683
mknittle
mknittle's Avatar
I was kidding about the DDS his signature says go big and that was the first thaing that came to mind.
Mark
My GMC build.
Old 03-04-2012, 11:05 AM   #684
mknittle
mknittle's Avatar
the only thing plastic will do is keep moisture from getting to the card poard dood panels from the back. some of th guys on the 47-59 board are using a peel and stick roof patch product that would work if you put it on the inside of the outside door skin.It dampens vibration. I will see if i can find the thtead.
Mark
My GMC build.
Old 03-04-2012, 11:09 AM   #685
mknittle
mknittle's Avatar
the only thing plastic will do is keep moisture from getting to the card poard door panels from the back. some of th guys on the 47-59 board are using a peel and stick roof patch product that would work if you put it on the inside of the outside door skin.It dampens vibration. I will see if i can find the thread.
Mark
My GMC build.
Old 03-04-2012, 11:10 AM   #686
mknittle
mknittle's Avatar
here is a link http://67-72chevytrucks.com/vboard/s...d.php?t=476476
Mark
My GMC build.
Old 03-04-2012, 11:38 AM   #687
watahyahknow
watahyahknow's Avatar
the tar/bitumen based roofingstuff will stink up a storm when the truck sits in the sun the real dampningmat like brown stuff and dynamat has less smell and is more resistant against heat in general , you could just put clearcoat on the back of the doorcards that should seal them up just fine
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 03-04-2012, 12:20 PM   #688
Dieselwrencher
The inside of my doors already has a coating on them. I am more interested in keeping cold air and dust from entering the cab via the doors. I might put some insulation in there I have around. I'll post pics if I do it.
Ryan
Old 03-04-2012, 01:36 PM   #689
Dieselwrencher
I forgot to add my new to me clutch showed up yesterday. We carried in my steel bed floor and my buddy Mathew cut it to get ready to extend it so we can get the bed assembly started. Pics later.
Ryan
Old 03-04-2012, 09:45 PM   #690
mknittle
mknittle's Avatar
Not true, there are guys that have used it for years with no problems. here is one http://67-72chevytrucks.com/vboard/s...=476476&page=2
Mark
My GMC build.
Old 03-04-2012, 09:48 PM   #691
mknittle
mknittle's Avatar
Maybe body putty. it stays soft and seals good.The stuff that is it comes in a box about a foot long and has sevral layers of cords about A1/4' in diameter. some car companys used it between the dood and a plastic sheet.
Mark
My GMC build.
Old 03-05-2012, 12:35 AM   #692
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Man I had not checked in in a while, Truck is looking great.
before too long you should be driving it. It is going to be a one of a kind for sure.
Sadly looking like it will be probably a year and a half before I get to get my 72 cummins project going again.
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 03-05-2012, 02:41 AM   #693
Beat68CST
Beat68CST's Avatar
Ahhh, I hadn't heard of them breaking.
Have you tried any of the Hamilton cams? The street one seemed appealing to me for having a rowdy DD and be able to pull the world.
Old 03-05-2012, 10:45 AM   #694
mknittle
mknittle's Avatar
how are you doing? i was rereadind your bild thread and wondering if you were ok.
Mark
My GMC build.
Old 03-05-2012, 11:39 AM   #695
Dieselwrencher
Thanks, that stinks you won't be able to work on yours for a while. I know how that goes. This truck has been off and on for a few years. Hopefully I can get it wrapped up before June.
Ryan
Old 03-05-2012, 11:41 AM   #696
Dieselwrencher
Yep. Been using Zach's cams for a while. I have his 181/210 in my Vette, we have several 181/210's running in street trucks, we also have some 200/220's going too. We also are a dealer for Colt Cams as well. The prices on Hamilton's cams are really scaring people though.
Ryan
Old 03-05-2012, 11:44 AM   #697
Dieselwrencher
I know what you're talking about. They always used to use like a black butle type of stuff to hold on a sheet of plastic. I haven't decided what I'll be doing yet. I didn't mess with it at all yesterday. Working on a worn out poor dodge right now.
Ryan
Old 03-05-2012, 05:37 PM   #698
Dieselwrencher
Here are pics of the bed work beginning.
We also found out that apparently the bed mounting holes aren't the same on this frame. So that makes me think that the Longhorn bed mounting holes are spaced differently than the standard 8' beds. I always assumed the rear half would be the same. I was wrong.
Ryan
Old 03-05-2012, 08:02 PM   #699
duallyjams
duallyjams's Avatar
Steel bed longhorn cool.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 03-05-2012, 10:09 PM   #700
mknittle
mknittle's Avatar
And I thought I was the only one that ran into stuff like that
Mark
My GMC build.
