Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-05-2021, 08:54 AM   #676
regan wilson
regan wilson's Avatar
Re: Ok Boys and Girls it's Storytime
The passenger side was the worse. There wasn't much holding it together.
NHRA Super Street 469C
It only runs 10.90 at 156 mph
regan wilson is offline   Reply With Quote
Old 03-05-2021, 08:58 AM   #677
regan wilson
The drivers side was a much cleaner break.
Old 03-05-2021, 09:01 AM   #678
regan wilson
The drivers side went back together pretty smooth.
Old 03-05-2021, 09:05 AM   #679
regan wilson
The passenger side was a *****. We had to twist it and use the jack and jack stands with a ratchet strap to pull it together. Weld here weld there and then it started pulling itself together. We weren't gong for pretty we were going for strength.
Old 03-05-2021, 09:11 AM   #680
regan wilson
Tony went ahead and rewelded around the C notches on both sides and we called it a day. We will clean it up and plate the outside. Once we are done with that we will get the weight distributed right and start on adding tubing over the shock mounts to tie everything. I may have to do some adjusting and shimming on the bed. All in all a for a near disaster I think it went back together pretty well.
Old 03-06-2021, 09:14 AM   #681
regan wilson
The rig I tried to get it home from the track with. It worked for awhile.
Old 03-06-2021, 10:23 PM   #682
71Dragtruck
71Dragtruck's Avatar
Damn $hitty deal, but good thing you caught it before it completely broke.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 03-08-2021, 07:52 AM   #683
regan wilson
Yes it sucks Monty. In the end I'm glad it happened just not the 800 mile round trip and missing a race. I was able to rearrange my schedule so we are going to start back on it at 8am this morning. Maybe we can get it finished and I can get it home I hope.
Old 03-08-2021, 03:19 PM   #684
aggie91
I'm just glad to be here!
aggie91's Avatar
Glad to see you progressing. You know Tony will make it right!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 03-08-2021, 08:56 PM   #685
71Dragtruck
Success?
Sponsored by:
Hard Candy Customs
Old 03-09-2021, 06:58 AM   #686
regan wilson
When I got there yesterday morning he was doing some welding. He found one or two small cracks and welded them up too. Then we had to determine bar placement in the back. There was only a 4 inch long area to use. I got them marked and cut some holes in the bed.
Old 03-09-2021, 07:02 AM   #687
regan wilson
I left out that I worked on the bed shimming it in the back .I think the bed gap looks as good or better than it ever has. It was never perfect because the of the way I had the cab mounted before the cage was built. If I don't like it when I get it home I can still play with it some more.
Old 03-09-2021, 07:08 AM   #688
regan wilson
We sampled different angles of tubing bends with some templates. We decided on a 45 degree I kinda liked a 30 better but it would have been harder to weld at the bottom.
Old 03-09-2021, 07:10 AM   #689
regan wilson
We sampled different angles of tubing bends with some templates. We decided on a 45 degree I kinda liked a 30 better but it would have been harder to weld at the bottom. There will be some 90 degree struts where the floor is cut. Then hopefully we can get all that mess put back together.
Old 03-09-2021, 07:22 AM   #690
regan wilson
We got both bars bent and mocked up. Then had to call it a day.
Old 03-09-2021, 07:23 AM   #691
regan wilson
oops
Old 03-09-2021, 07:27 AM   #692
regan wilson
This is turning out to be exactly what I wanted to do for awhile.
Old 03-09-2021, 10:00 AM   #693
SCOTI
SCOTI's Avatar
Definitely looks like those will help the effort.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-10-2021, 09:15 AM   #694
regan wilson
I got it home yesterday evening. He didn't have time to help me with the floor and the tubs. I'm going to have to fix that mess myself. I've already gotten the tubs pretty straight. I need to cut up the pieces of the floor I took out and fit them around the 90 degree braces. Then clean this mess up and do some bedliner and paint the bars.
Old 03-10-2021, 10:40 AM   #695
SCOTI
SCOTI's Avatar
It will be interesting to see if it reacts differently now.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-10-2021, 01:34 PM   #696
71Dragtruck
That’s kinda the same idea behind how mine is done, sample principal anyway.
Sponsored by:
Hard Candy Customs
Old 03-10-2021, 02:31 PM   #697
aggie91
aggie91's Avatar
Looks good!
Karl
The LST Challenge:
Old 03-10-2021, 09:03 PM   #698
regan wilson
I'm sure it will. If it picks up R/T that's not a bad thing. I hope it picks up a ton.
Old 03-10-2021, 09:04 PM   #699
regan wilson
Leave it to me to wait until it breaks .Lol
Old 03-10-2021, 09:04 PM   #700
regan wilson
Originally Posted by aggie91 View Post
Looks good!
Thanks Karl
