Old 07-21-2015, 09:48 PM   #676
trkfrk
trkfrk's Avatar
Re: Started my first frame off - 72 SWB LS1, 6-spd manual
Originally Posted by mcbassin View Post
I still need to install the wing windows. I'm not sure if I want to attempt to rebuild mine or buy new ones.. It would save me a lot of money to rebuild mine.
Ordered a new shift knob today (F'ing Fast) lol, since I broke mine by over tighting it.
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 07-21-2015, 09:53 PM   #677
trkfrk
trkfrk's Avatar
I also stained an extra piece of my cherry wood to see what it would look like. I think I'm going to go with it.
Mark
Old 07-21-2015, 11:08 PM   #678
9teen69
9teen69's Avatar
Nyce shifter, beds going to look sweet!
I rebuilt my wing windows, well one of them so far. Not hard just time consuming, soaked mine over night in Evaporust and repainted lower bracket.
Protect that paint and take your time.
72 Cheyenne SWB C10 (daily driver)
(Super fake cause I just love the glovebox emblem)
70 Camaro RS (frame-off in pieces)
70 Camaro RS (daily driver backup)
69 Custom LWB C10 (son now drives)
9teen69 is offline   Reply With Quote
Old 07-22-2015, 07:58 AM   #679
mcbassin
Still Learning
mcbassin's Avatar
I rebuilt my vent windows. I used precision gaskets. It wasn't too bad. I did mine during the winter when there wasn't much going on in my shop. The rivets for the pivot that come with the kit I bought really sucked. I ended up making some that worked out really good. You can check it out HERE
Nice shift knob and wood for the bed.
mcbassin is offline   Reply With Quote
Old 07-30-2015, 04:54 PM   #680
trkfrk
trkfrk's Avatar
Thanks.. I'm hoping to finish cutting my cherry wood this weekend.
Yes, I thing I'm going to give it a shot you guys make it sound easy.
Mike, you took some really good pictures. I'm going to order the same gaskets. Thanks for the help.
I finally found the issue with my cam sensor The wires going into the ECM were in the correct locations but going into the plug 2 out of the 3 wires were crossed. It's always something simple lol.
Mark
Old 07-31-2015, 08:15 AM   #681
mcbassin
Still Learning
mcbassin's Avatar
If you run into a snag on your vent windows just give me a shout, I will help you if I can. I rebuilt mine and the latch would barely catch. The rubber takes a while to conform. I don't plan on ever opening them so that's not a big deal. They sealed up good.
Glad to see you found the cam sensor problem.
Old 08-10-2015, 03:26 PM   #682
GoaterAz
GoaterAz's Avatar
Thank You! You're really going to dig the 6 speed.. It's so fun to drive..
Here is the line I ordered off of eBay and worked perfect. I kept the OEM bleeder. If you need more info or pics let me know.
Thank you for the info, that was the one I was eye-balling. Perfect.
What size hole-saw did you use in the firewall for the engine harness? Did you have any pictures of the completed mounting if ECM/Fuse Box and Vintage Air under the dash?
Reading through the VA instructions, it looks like it's going to be TIGHT under there.
You remember when drinking too many beers was a bad idea?
Me neither.
GoaterAz is offline   Reply With Quote
Old 08-10-2015, 08:13 PM   #683
trkfrk
trkfrk's Avatar
Thanks for the help Mike.
Mark
Old 08-10-2015, 08:28 PM   #684
trkfrk
trkfrk's Avatar
I used a 2" hole-saw. At first I thought it was going to be too big, but it ended up working out perfect after running all my wiring. I plan on installing the vintage air system in the next few months. I'm pretty sure my ECM is going to be in the way and will have to relocate it nearby. I intentionally left my wiring going to the ECM extra long.
Mark
Old 08-10-2015, 11:46 PM   #685
GoaterAz
GoaterAz's Avatar
Great info and Thank You for the picture. Can't wait to see how it turns out!
Me neither.
Old 08-11-2015, 02:35 PM   #686
knomadd
knomadd's Avatar
Yeah, I'm pretty sure you'll have to move all of that. It's pretty tight up there with the VA evaporator unit, mounting brackets and lines. You might get lucky and be able to squeeze something in there, but it would be a PITA to get to if you ever need to replace a relay or chase wires
I used custom fittings, but the plumbing is about the same routing. Here's mine all jammed in there...
and a front shot, just for good measure.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 08-12-2015, 01:37 PM   #687
trkfrk
trkfrk's Avatar
Wow, your right that is going to be tight. Thanks for sharing the pictures.. Love the color of your truck. I'm also restoring a 63 VW 2nd owner all original car. The original color is close to your blue. What color is your truck? Thanks.
Mark
Old 08-13-2015, 11:30 AM   #688
knomadd
knomadd's Avatar
No problem Mark. The truck is actually a factory Medium Blue, code 510. It's just been resprayed in Base/Clear.
I'm sure you'll love the AC once it's installed. I can't imagine going back to no AC in mine now that I have it. Keep up the good work, your truck is turning out great!
-Duane
Old 09-27-2015, 07:35 PM   #689
trkfrk
trkfrk's Avatar
This weekend I entered my truck in it's first ever Car Show, (the largest show of the year for the Las Vegas area). I was hesitant to do so, because my Truck is not completely finished. My family and I had a great time, and we met a lot of really cool people aka "Truck Enthusiasts"! I totally wasn't expecting to win anything, just excited to show the Truck & what I've finished so far! So when my Truck won; "Super Run 2015 Outstanding Vehicle" award, I was shocked AND proud!!
Mark
Old 09-27-2015, 07:37 PM   #690
trkfrk
trkfrk's Avatar
Pic 2
Mark
Old 09-27-2015, 07:42 PM   #691
trkfrk
trkfrk's Avatar
Another pic
Mark
Old 09-27-2015, 07:48 PM   #692
RRR18
RRR18's Avatar
Hell yes!
'67 BAD IDEA
Follow on Instagram https://www.instagram.com/rtimes3c10/
Ryan
RRR18 is offline   Reply With Quote
Old 09-27-2015, 07:56 PM   #693
trkfrk
trkfrk's Avatar
Originally Posted by RRR18 View Post
Hell yes!
Thanks Man!
Mark
Old 09-27-2015, 08:05 PM   #694
9teen69
9teen69's Avatar
Well deserved...congrats man!
Old 09-27-2015, 11:39 PM   #695
trkfrk
trkfrk's Avatar
Thank You!! I haven't been this excited since the day my first kid (my daughter) was born...lol
Mark
Old 09-28-2015, 07:32 AM   #696
mcmlxix
Collector of Projects
mcmlxix's Avatar
Congratulations Mark.
I want to go to the show but had home work to do...
Rich
1972 K5 Blazer CST Click HERE
Old 09-28-2015, 08:15 AM   #697
mcbassin
Still Learning
mcbassin's Avatar
awesome! congrats on the well deserved award. Your truck looks great, glad to see it our shining in the sun.
Old 09-28-2015, 02:17 PM   #698
trkfrk
trkfrk's Avatar
Thanks Rich.. There were a couple of really nice K5's there. I can't wait to see yours on the road soon.
Thanks Mike... It's really hard to work on it, since I enjoy driving it so much lol. I can't believe how well these LS's run with the great fuel mileage to go with it.
Mark
Old 10-08-2015, 01:21 PM   #699
trkfrk
trkfrk's Avatar
I've had the check engine light coming on. Fixed it with some new knock sensors from GM.
Mark
Old 10-08-2015, 01:25 PM   #700
trkfrk
trkfrk's Avatar
I just picked up some new tubular A-arms and sway bar. Hopefully I will get them on this afternoon so I can get the truck aligned this weekend.
Mark
