01-28-2018, 01:26 AM | #676 |
Re: What did you do with your truck today, Part 3
purchased my door jam switches today and set out to create light! I sort of did? I pulled the seat out and cleaned up the floor. it was a terrible mess. for reasons unknown to me when I got in it dawned on me that the light on the shifter indicator had never worked. I'm don interior lighting and that counts. the indicator itself had also not worked for as long as I could remember. the shifter is 15 years old so maybe it did work but I don't remember it. since I had to take the whole dammed cover off to get to the light i figured might as well fix it all. the indicator issue was immediately apparent. the cable that connected it to the shifter arm was snapped. its a pretty hefty cable so I'm not sure how that could have happened but the jerk who put it in has a way of making terrible things happen. I had the excess from my holley throttle cable left over and was able to cut it to size and make that work. I figured the bulb was burned out so I replaced it but the light still didn't work. checking the wires I found one that wasn't connected well and popping it on correctly brought the new bulb to life. I took the time to wash the shifter cover and top cover but when I went to install them I realized the C clip that holds the indicator cable to the shifter is missing. must have come off when the cable broke. I will get one tomorrow and put it all back together and then continue onto the dome light. good day. got stuff done.
01-28-2018, 09:59 PM | #677 |
screwed with the wiring for a while. didn't make much progress on it. pulled the fuse panel down and looked at the back to try and find the wire I'm looking for. In the "dome " light fuse there is only 1 wire and its black or appears so in my light. It might be blk/blu wire. I hooked it up to the dome light and when I grounded it I popped the fuse. so that was a great waste of 2 hours. to make sure today wasn't a total loss I installed the passenger side mirror. ive had this mirror under the seat about 5 years. I installed the driver mirror 5 years ago but installing the passenger is a pain. I did it though and it looks good. I'm going to get more fuses and keep researching this wiring.
01-28-2018, 11:21 PM | #678 |
Now that's some work on those doors at one time, unique.
Mudman.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
01-29-2018, 01:00 AM | #679 |
try pulling the dome light bulb and checking for a short. sometimes it is the wrong bulb installed, or just pull the whole thing and bench test it. if you bench test it and it's good then you just need a good power source and then a wire to ground it at the headlight switch. sometimes easier and quicker to start over.
01-29-2018, 01:35 AM | #680 |
Replaced my noisy Holley fuel pump with a Mallory pump. What a difference. Can't even hear the new pump running.
01-30-2018, 08:56 AM | #681 | |
01-30-2018, 09:01 AM | #682 |
Pulled wiring harness and starting over!
Last guy had the dome light blinking with the flasher, front parking lights on with the brake lights, fan on with accessory switch...do I need to keep going? |
01-31-2018, 03:36 AM | #683 |
02-03-2018, 05:49 PM | #684 |
making more dust...
02-03-2018, 06:48 PM | #685 |
my whole crew and I have the flu. I wont be doing any work for a while. I did get some door parts in the mail though. if I ever get better I will be back on the lighting. still haven't found the correct size c clip for my shifter.
02-03-2018, 10:40 PM | #686 |
Active Member
First time posting on the 47-59 forum. I just inherited my father in laws 54 panel. It's whole and mostly original, 235 and 3 speed on the floor. It hasn't run in years, the wiring is a mess. But I wanted this truck for years. Tried to buy it in the late 90s. I have to finish my 70 C10 before I get anything done on the 54, but I'm excited! Has original grille, chrome running boards, seats.
David Larsen 1970 Chevrolet C-10 Last edited by dflarsen77; 02-03-2018 at 11:18 PM. |
02-03-2018, 10:55 PM | #687 |
Glad Im not only one with upside down and sideways pics. Looks like a nice project on a scarce vehicle. Reminds me of my 52 suburban and that cross counry trip to woodstock.
02-04-2018, 12:03 AM | #688 |
Like the panel, congrat's.
Mudman.
02-04-2018, 01:32 AM | #689 |
I too like the 54 Panel
My Spelling is Not Incorrect...It's 'Creative' . . 1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E http://67-72chevytrucks.com/vboard/s...d.php?t=789617 59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341 |
02-04-2018, 02:32 AM | #690 |
The outside looks rough so the inside is quite a nice surprise, so solid.
Mudman.
02-04-2018, 04:18 PM | #691 |
that's going to be cool! I like the 54 sheet metal the best and a panel is just cool.
02-04-2018, 08:12 PM | #692 |
Making dust...
02-05-2018, 06:26 AM | #693 |
02-10-2018, 10:53 PM | #694 |
51 Panel: Made some strap tensioners today to hold my rear-mount fuel tank in place.
02-11-2018, 12:50 PM | #695 |
I finished up the bodywork on the DS rear fender, swept the shop then opened both doors and blew it out with the backpack leaf blower. Once the shop was "clean" I took a break from sanding and worked on some loose ends. First step was adding some Dynaliner on the floor under and behind the seat. Then I finished modifying the brake pedal, painted it and cut out 40oz jute carpet padding to fit the flat portion of the floor.
Today's goal is to install the freshly painted brake pedal, figure out the console wiring (stereo and power port) and get some jute cut out for the passenger side toe board. If time permits, I got a nice chunk of aluminum to make a column mount for the tach. I better get busy... Last edited by Black_Sheep; 02-11-2018 at 01:06 PM. |
02-11-2018, 04:16 PM | #696 |
02-11-2018, 06:49 PM | #697 |
Can see why on trucks, usually all about the doors on a classic car, nice to see on a truck.
Mudman.
02-11-2018, 08:44 PM | #698 |
Scored some 59 Fleetside spear trim pieces, just the ends. Does anyone know if the straight trim pieces with the curve on the front ends is unique to the fleetside, or possibly used from another GM product?
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
02-13-2018, 10:07 PM | #699 | |
. . . I don't know what that is But I know I like it . Probably get your answer for "Chevy's of the 50's" . ............Sp . . . .
02-18-2018, 01:00 PM | #700 |
I put spacers between the frame and the brake pedal mount to center the brake pedal in the hole through the toe board. Once that was done, I trimmed the pushrod between the pedal and booster and adjusted the pedal height so it won't bump off the toe board when I let off the brakes. Minor detail, but it was something I felt was very annoying. Now I can figure out where the stop light switch should go and get that in.
I also tried to fire it up, but no joy. After adding a few gallons of fuel it popped right off, all systems are go... |
