06-15-2013, 06:35 PM | #7201 |
Re: What did you do to your truck today!
Pulled the wounded 350/350 and am towing it to the carwash to clean it up in preparation for putting the Cad 500 and turbo 400 in it. More power is on the way.
I also ran to the wrecking yard and picked up a pair of the right brackets off a square body to mount the 500 per what others have done. Now I need to dig in the sheds and find the 425 pan and pickup tube I saved when my wife blew up the 425 I had put in my 82 Deville. She just called my buddy to come get here and tow her home when she did that one.
06-15-2013, 07:06 PM | #7202 |
Got my old man up early. Loaded my bed and cab on the trailer took to work and steam cleaned. Scuffed the underside. Prepped and applied some undercoating. Sitting back with a cool one, watching it dry...Once again, Thank you pops..
06-15-2013, 07:40 PM | #7203 |
RAT1968 '68 Cab/'71 Parts
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
06-17-2013, 02:25 PM | #7204 |
Replaced my drivers side door latch Sunday. That sucked! I swear to all things holly the passenger side better not fail because i'm not looking forward to doing that job again.
I'd love to put in some fresh door latch screws if any of you know where I can get some.
-- 1968 fleetside - nolimit wide ride front and rear + ridetech |
06-17-2013, 02:35 PM | #7205 | |
Cluster King
06-17-2013, 03:03 PM | #7206 |
Re : Saturday
Hm ;
I tried to post some new pix and it said " board down for mtce. " ~ I also still really would like to learn how to put the text between the pictures , i keep asking no one helps... . .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
06-17-2013, 04:10 PM | #7207 |
I decided to take the stuck on heater , repaired , began by removing the right inner fender :
06-17-2013, 04:12 PM | #7208 |
Pic. # 1 is the leading edge of my inner fender .
Pic. # 2 shows the lower edge of my core support . Pic. # 3 shows the pieces of fender & core support that ripped out .
06-17-2013, 04:13 PM | #7209 |
This pic. it the standard $7.00 So. Cal. Pick-A-Part inner fender with not one pin hole of rust .
06-17-2013, 04:20 PM | #7210 |
Then I removed the hood & right side hinge (BAD design here Chevrolet Division !) then the heater box to see yet MORE rust holes in the cab :
06-17-2013, 04:22 PM | #7211 |
Damn ! this crappy board won't allow me to add more pictures...
06-17-2013, 04:35 PM | #7212 |
Collector of Projects
Looks like I'm moving to Dallas, TX the end of July ... so I sent it to a board member near me that restores cars.... he's going to finish the job I don't have time for anymore... Sad but happy at the same time, I know it will be done now....
06-17-2013, 08:37 PM | #7213 |
72 C10 - Multicolor, 4.8 ls, NV3500. Sold 72 K5 - Under Construction |
06-18-2013, 01:33 AM | #7214 |
06-18-2013, 01:53 AM | #7215 | |
Re: Re : Saturday
this is a test
to answer your question after you attach files preview the post, then just below the preview you can make some changes to it look for where it says attach] you want to type after the last ] ( or see attached photo where I typed in "this is a test". I spend more time fixing relatives computer's then working on my truck, unfortunately it shows. |
06-18-2013, 01:59 AM | #7216 |
Started digging through my parts boxes looking for my interior screws. WHY didn't I keep things more organized!
06-18-2013, 02:49 AM | #7217 |
Zip-Lock bags are your friend....
06-18-2013, 05:13 AM | #7218 |
I keep medicine bottles for just such reasons, too.
06-18-2013, 07:35 AM | #7219 |
Vacuumed the carpet
06-18-2013, 08:41 AM | #7220 |
Washed it, wiped it down. Then it rained again!
I don't think we get smarter as we get older. We just run out of Stupid things to do. |
06-18-2013, 10:22 AM | #7221 |
Worked on replacing Rocker panels. Got old one cut out, and found rusted out A-pillar. Waiting on parts to finish.
06-18-2013, 11:11 AM | #7222 |
Re : Sat. 6/15/2013
O.K. , I'll try again :
There's NO PLACE to insert text anywhere except at the beginning of each message ! . GRrrrr...... This is the R.F. brakes showing leaky brake cylinder and paper thin shoes worn to the rivets , scored the crap outta the drum too .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH Last edited by VWNate1; 06-18-2013 at 11:12 AM. Reason: Trying to add text between the pictures ~ CAN'T BE DONE ! |
06-18-2013, 11:13 AM | #7223 |
Left front showing cracked linings clean through .
06-18-2013, 11:13 AM | #7224 |
All done :
06-18-2013, 11:18 AM | #7225 |
Re : Then :
I removed the right inner fender and discovered the bottom edge of the core support was rusted to junk , pix or of the leading edge of my old inner fender , the bottom of the core support looking up from the fender well , the bits of combined core support , leading edge of the inner fender and bolts , all this broke off in my hands =8-^
Last pic is of the typical So. Cal. Pick-A-Part $7.00 inner fender :
