Old 03-06-2012, 12:05 AM   #701
jbclassix
Junk Yartist
jbclassix's Avatar
Re: Finally starting my Longhorn 4x4 conversion
I've been watching all the guys on here who are shortening beds, studying how they blend in the body curves where they removed the sections... Its gonna be cool to see this bed go the OTHER way! Are you gonna weld the factory longhorn seams?
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 03-06-2012, 12:14 AM   #702
mcbassin
Still Learning
mcbassin's Avatar
Looks like some great progress on the Longhorn Ryan. Glad to see your's is coming togther.
mcbassin is offline   Reply With Quote
Old 03-06-2012, 12:48 AM   #703
ryanroo
ryanroo's Avatar
i was curious about this as well. personally i think leave it. its part of the longhorn thing
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 03-06-2012, 05:47 PM   #704
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I thought about welding it and smoothing it out. But I want it to look some what original. Most people probably wouldn't catch it beeing a Longhorn with out the seem. I like it there too. My luck, I'd weld it and that area would be the only place that body work would crack or I'd get hit there first.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 03-06-2012, 05:48 PM   #705
Dieselwrencher
Thanks Mike. It is slow going. How ever, I am working on the engine while I sleep. So maybe by the week's end I'll have it close to beeing ready to drop in.
Ryan
Old 03-07-2012, 10:23 AM   #706
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Nice progress Ryan.
How's the little one doing?
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 03-07-2012, 08:21 PM   #707
Dieselwrencher
Originally Posted by 72BlckButy View Post
Nice progress Ryan.
Thanks Nate. She's doing great! Almost walking, chatting away, and into everything. She's giving her mom a work out. Her little brother will be born soon...........................
Ryan
Old 03-07-2012, 09:40 PM   #708
72BlckButy
Tot Roddin'
72BlckButy's Avatar
You're kidding??? Congrats buddy!!
We just passed the big 1st b-day and man was it a blast.
-Nate
Old 03-08-2012, 11:50 AM   #709
mknittle
mknittle's Avatar
To delete the vacuum pumps can I pull the pumps and pushrods and make cover plates?
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 03-08-2012, 04:19 PM   #710
Dieselwrencher
Congrats Nate! Izzy's 1st was Jan 21. It was a blast for sure. Little bro's due date is April 14th, but the docs think it will be end of March. Maybe sooner, maybe later. They aren't sure. Imagine that.
Ryan
Old 03-08-2012, 04:20 PM   #711
Dieselwrencher
On the first gen vacuum pumps, yes you can. I did that on my corvette. I used the vacuum pump to drive the PS pump so I could run hydraboost brakes.
Ryan
Old 03-08-2012, 06:29 PM   #712
mknittle
mknittle's Avatar
Thanks Ryan,That's what I want to do.If I take them off it will be easy to move the enging back.
Mark
My GMC build.
Old 03-08-2012, 08:35 PM   #713
Dieselwrencher
You can get the newer style vacuum pump set up and then you won't have to go without a vac pump. 92-98 should be same vac pump. PS pumps, there are 2 different styles. A tear drop shape housing, and a round. Then there is a 1 return and a 2 return for hydra boost set ups.
Ryan
Old 03-08-2012, 09:04 PM   #714
mknittle
mknittle's Avatar
Thanks Ryan, that's good to know.i want to use a hydra boost I really like the one I used on my 42 jeep. clears the buick V 6 and has lots of power with a good solid feel.
a vacuum pump may be a good idea for the AC. Its sort of design by the seat of the pants.LOL
Gotta go to a bonsai club meeting Mark
Mark
My GMC build.
Old 03-19-2012, 03:41 PM   #715
Dieselwrencher
This weekend in between some other projects, I had some help and managed to get some box sides bolted on! Now I'll have to decide if the LH box side is going to be used. I think the one from my original bed is nicer. So we'll see. This metal floor swap isn't going to be as bad as I thought it was going to be!
Sorry about the mess. We've been cleaning up out side since it's been so nice and now it's supposed to rain all week so we had to shuffle stuff around the storage truck.
Here is the new phase of this truck. I don't have a common rail engine any more, and I want to get into tuning on EFI live. My brother happened upon a sweet deal a few weeks ago and now I'm going to build a common rail and put it in the Longhorn. Here are some misc. pics.
The thing in the plastic bags is my block. The turbo is a 76mm HT60 which will be my primary turbo in my compound turbos.
Right now I have most of the big pieces I need for it. Here's what I have for it right now.
05 Block with fresh hone and deck job.
12v crank
181/210 Hamilton cam
06 ECM
05 engine harness
05 CP3
05 injectors
04.5 donor engine for hard ware
12v connecting rods
4 good 05 pistons
What I'm lacking to get it together
Rings, and bearings
Gaskets and seals
2 05 pistons
100hp nozzles
Some misc wiring to get the engine running.
I plan on getting the stuff for it soon so I can try to get it running soon. I was going to buy new pistons for it, but the pistons I wanted were $1000. That's going to have to wait!
Ryan
Old 03-19-2012, 06:49 PM   #716
duallyjams
duallyjams's Avatar
I can here the turbos spooling up and see the black smoke already
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 03-19-2012, 07:21 PM   #717
Dieselwrencher
I'm going to try and keep it smoke free or close too it until the time comes!
Ryan
Old 03-19-2012, 07:35 PM   #718
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Hey ryan nice build Im not much into diesels but what is a common rail?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 03-19-2012, 10:25 PM   #719
ryanroo
ryanroo's Avatar
common rail refers to a pressurized fuel rail that is common to all injectors. the injectors are cycled by the computer instead of mechanically via fuel pressure. it has been the dodge system since 03. all current diesels run this type of injection now i believe, in light trucks anyhow.
so, you cutting me a good deal on the 24v with the p-pump swap? haha
ryan
72 K20 12v build
Old 03-19-2012, 10:26 PM   #720
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
They're trouble that's what they are! lol EFI live should be fun!
Haha no in 03 the common rails came out, they use a CP3 injector pump in which one line fuels a "rail" then the computer controls when the injectors open instead of pressure like on the mechanical systems.
Lookin good ryan! When you cut out a piece of bed floor from a donor are you going to just get the front 15"s or so, so you only have to weld up one seam?
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 03-20-2012, 12:42 AM   #721
6lcummins
ryan
Heavy duty on road diesels are "common rail" that I know of, Detroits might not be but we don't do much with newer ones.
1996 Dodge 2500 Ext Cab Long Bed P24V Cummins Turbo Diesel 5 speed 4x4
"STOCK"
ASSEMBLY THREAD
6lcummins is offline   Reply With Quote
Old 03-20-2012, 12:45 AM   #722
6lcummins
They are the DEBIL!!! But it's a debil we must embrace and test the limits of the dual disc in the truck and see what happens.
"STOCK"
ASSEMBLY THREAD
Old 03-20-2012, 02:32 AM   #723
watahyahknow
watahyahknow's Avatar
havent read a lot about aftermarked ecu's for them other than a re chipping the original computer , it would be nice to see a megasuirt setup working on a diesel
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 03-20-2012, 02:36 AM   #724
Dieselwrencher
ryan
It all depends what you consider a good deal.
Ryan
Old 03-20-2012, 02:39 AM   #725
Dieselwrencher
You're right on the money except there is no injection pump. Just a lift pump and a high pressure pump.
On the box I have a bed floor patch panel I'm going to use and section it in. I had a hard enough time finding this steel floor so finding a second may take a while.
Ryan
