07-14-2018, 01:35 PM | #701 |
Re: What did you do to your truck today part IV
This isn't really what I did to my truck but rather what I did for my truck. Still waiting on the great state of IL to process the title so I can hopefully pick up my new project soon, so I figured I would go ahead and start harvesting parts. The truck in the picture was purchased new by my dad in 1973 and runs great but the body was mostly rust at this point. The truck Im waiting on has a locked up I6. I will clean up this engine and get it ready to drop in.
07-15-2018, 01:21 AM | #702 |
I finally finished my air ride suspension install: dual Viair 444c compressors, cupped lower control arms, 5 gallon tank, HD c-notch, and manual paddle valves. I also swapped in a rear diff with posi. A lot of time spent, but it will be worth it.
07-15-2018, 02:45 AM | #703 |
Took 64’ C20 front brake spindles and backing plates apart for rebuild.
Les |
07-15-2018, 10:57 AM | #704 |
It's Better With Nitro
With the bed back on the chassis, I was able to test the tail light harness and air suspension...
07-15-2018, 09:30 PM | #705 |
Installed the new clutch, pressure plate, throw out bearing & extra long bushing in crankshaft. I used the bread method to remove the bushing from the crankshaft. Used 1 hot dog roll & 11 mm craftsman socket.
07-16-2018, 12:05 AM | #706 |
The bread method? Do tell.
1961 GMC half ton, short step, Canadian model. Just starting work on it. |
07-16-2018, 07:58 AM | #707 |
By placing the bread in the hole and then pressing or driving a socket or a steel rod in the hole like a piston forces the bushing out I have also seen this done with grease
07-16-2018, 10:56 AM | #708 |
Interesting.
07-16-2018, 11:20 AM | #709 |
Didn't they do that on Road Kill with mustard or some other kind of condiment?
07-16-2018, 02:56 PM | #710 |
It’s called hydraulics mustard hotdog catchup hotdog bun sounds like like launch
07-16-2018, 06:58 PM | #711 |
You need some cheap white bread & a socket or pin that fits snugly in the bushing. You roll up 1/2" balls of bread and pack the bread into the bearing. You will fill the bearing a couple of times. When you can't stuff in any more bread with your finger, start using your socket to pack the bearing. Keep packing until the bearing pops out. I used just 1 hot dog bun and even snuck a bite. |
07-16-2018, 10:15 PM | #712 |
Does the bread squish out the hole in the socket?
07-17-2018, 12:03 AM | #713 |
Finished up my lt1 swap and fired it up. Test drive tomorrow!
07-17-2018, 08:35 PM | #714 |
07-18-2018, 01:54 AM | #715 |
I finally got the idea! Thanks a lot - will come in handy when I get to that point.
07-19-2018, 03:43 PM | #716 |
Post Whore
Been out wire wheeling today....finally finished the hood. Now onto the fenders.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
07-20-2018, 07:29 PM | #717 |
Installed 3 inch drop spindals. Rolled her outside and gave her a bath. Then rolled her back into her cave. Lol! One of these days!
07-20-2018, 10:28 PM | #718 |
07-21-2018, 01:24 AM | #719 |
stretched her legs a bit (300 miles or so) unfortunately, too late to get a soda, but now I am determined to get some paint on there and at least looking whole.
07-21-2018, 06:37 AM | #720 |
Moderator
I just looked it up that store looks just like the one heading to Nevada outside of Bishop, CA. or maybe it just reminds me of it.
07-21-2018, 10:43 AM | #721 |
07-21-2018, 03:40 PM | #722 |
I picked up my new truck today. Let the fun begin.
07-22-2018, 12:57 PM | #723 |
Cleaned out the bed for the stepside swap.
Romans 10:9 - The Truth |
07-29-2018, 01:34 PM | #724 |
Post Whore
Grill panel is in paint and done.
07-29-2018, 05:47 PM | #725 |
Installed a new muffler, washed and waxed cab, installed a tachometer in my 1961 C30 dually. 13k original miles, everything original (for now).
