Old 09-11-2007, 12:58 AM   #51
fastbagged68
fastbagged68's Avatar
Re: Getting Started
I have an Oasis also. Mine fills 10 gallons of air in no time. I have a 180psi switch too. With a 5 gallon tank the thing will hardly run.
fastbagged68 is offline   Reply With Quote
Old 09-11-2007, 03:47 PM   #52
L0WRIDE
L0WRIDE's Avatar
Re: Getting Started
nice!! these drop members are really a visual symphony there just great
49 CHEVROLET 1/2 TON, 52 CHEVROLET SEDAN
62 HARDTOP NOVA
65 CHEVROLET BB LWB FLEETSIDE
90 CHEVROLET EXTRA CAB
CHEVY ONLY - NZ Chapter
http://67-72chevytrucks.com/vboard/s...d.php?t=137984
L0WRIDE is offline   Reply With Quote
Old 10-19-2007, 11:50 PM   #53
BigShoe24
True Addiction
BigShoe24's Avatar
Re: Getting Started
Well, I took a break on the truck, last semester in college is getting a bit tough. I did get the cab on, and replaced some cab corners, inner & outer rockers. I have to say I hat rust! Its very time consumming when you've never done it. I do need some help on the next issue. I can't seem to figure a way to run a panhard bar, there just doesn't seem to be room. I have a ford 9" which makes the center "pumpkin" staggered. I was thinking I could run a watts link. The problem is, the left link would be 11 & 5/8", while the right side would be 15 & 3/8". Would this be a problem? Any suggestions would help. Thanks
-Ben
BigShoe24 is offline   Reply With Quote
Old 10-25-2007, 04:26 PM   #54
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
Re: Getting Started
Rock A Wishbone
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 12-10-2007, 02:28 AM   #55
BigShoe24
True Addiction
BigShoe24's Avatar
Re: Getting Started
Well I got that issue fixed. Suspension is done except for air managment. Who do you guys recommend for new bed sides, and possible a new front clip. Does anyone have better fitment? Thank, BB
Old 01-31-2008, 02:47 PM   #56
BigShoe24
True Addiction
BigShoe24's Avatar
Re: Getting Started
Well, I finally did a bit of work, Sorry the pics are pretty poor quality. The red truck is a friend of mines. He just bought it last week. Just thought I would share. Hopefully mine will look similar when it's all said and done.
Old 01-31-2008, 02:50 PM   #57
BigShoe24
True Addiction
BigShoe24's Avatar
Re: Getting Started
Here is a few more, It's originally from Oregon I believe. Anyone know who built it. Much Props, It's clean as F$%!
Old 02-01-2008, 06:57 AM   #58
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Getting Started
Nice to see some sheetmetal hangin'. Talked your buddy into baggin' it yet?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 02-01-2008, 02:35 PM   #59
Dinos63
chevy only
Dinos63's Avatar
Re: Getting Started
looks killer and even with the stockers ,i bet you can hardly wait to drive it. nice work
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 02-01-2008, 03:09 PM   #60
SanitysBane
Re: Getting Started
Trucks look sick. Call me crazy but I love thoes stock rims.
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 02-08-2008, 12:13 PM   #61
BigShoe24
True Addiction
BigShoe24's Avatar
Re: Getting Started
Thanks for the compliments. My Next Step is to get a new steering column. I was leaning towards the Ididit retrofit Column shift? I have the PorterBuilt Dropmember, with the R&P. Anyone have any suggestion. I was not sure what shafts, joints, etc, I would need. Any help is always appreciated. Thanks
Ben
Old 02-08-2008, 01:30 PM   #62
PBFAB.COM
PBFAB.COM's Avatar
Re: Getting Started
Ben
Ben-
Just let me know what the output shaft is on the column you get and I will let you know which joints you're going to need.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 02-27-2008, 02:56 AM   #63
BigShoe24
True Addiction
BigShoe24's Avatar
Re: Getting Started
Quick question, I just received my chromes pieces for my grille. It's a 67-68, so there are two small pieces running the width of the front end. They came with these small funky flip's and I really cant get them to work. Any suggestions??? Thanks
Old 05-15-2008, 04:40 PM   #64
BigShoe24
True Addiction
BigShoe24's Avatar
Re: Getting Started
This is a bit of a repeat question, but I talked to the guys at Ididit, and they quoted me $815 for the retro-fit chrome column shift Part # 1140657020. I was wondering if anyone could tell me where I might get a better price (particular dealer) , or perhaps maybe an alternative column. Thanks as always.
Old 08-18-2008, 07:40 PM   #65
BigShoe24
True Addiction
BigShoe24's Avatar
Re: Getting Started
Ok guys, I know I'm probably taking the easy route by asking, instead of digging through the forums, but I cant help it. As I stated before, I have the "One & Only" PB Dropmember, which runs the R&P unisteer. I plan to order the Retro-fit Column shift steering column from Ididit and need a little direction before I drop over a G. First, where can I get the best deal on the Column, and does anyone have a list of additional parts I will need to make it work. Thanks, and again sorry for reposting.
Old 08-18-2008, 07:48 PM   #66
Riveted1
Tasty Cakes!
Riveted1's Avatar
Re: Getting Started
Sorry, can't help u on the steering, but the truck is lookin good! You're buddy's truck is nice too.
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 12-04-2008, 03:27 PM   #67
BigShoe24
True Addiction
BigShoe24's Avatar
Re: Getting Started
Any suggestions on the Steering Column? Anything?
when they ask what type of box, do I say It's a R&P ?
RCC
Old 12-04-2008, 03:33 PM   #68
Shane
Shane's Avatar
Re: Getting Started
Have you tried dropping Nathan a PM? He is VERY responsive when it comes to customer service.
Shane is offline   Reply With Quote
Old 02-11-2009, 08:12 PM   #69
BigShoe24
True Addiction
BigShoe24's Avatar
Re: Getting Started
Well, I got the steering figured out finally. I'm moving on to finishing the brake components so I can order wheels! I made the mistake and order the CPP drop spindle, with 12" drilled rotors that come with single piston calibers. I am wanting to run a better looking caliper on the rear which is a bare ford 9" so I can pretty much do anything (brembo, ssbc, wilwood). I was wondering if anyone could offer any insight on what I could do so they match? The spindle, hole mounts (were the caliper mounts) appear to be 7" apart. However, there is only room for 5 3/8" caliper to slide in between the mounts. So, does anyone know of a caliper that would fit the shoe? Thanks for the help
RCC
Old 02-24-2009, 02:20 PM   #70
BigShoe24
True Addiction
BigShoe24's Avatar
Re: Getting Started
Well, I'm getting a little closer.
Can someone help me move this thread over to the "build & projects" Thanks
RCC
Old 02-25-2009, 09:17 PM   #71
BigShoe24
True Addiction
BigShoe24's Avatar
Re: Getting Started
Anyone care to suggest who makes the most affordable three piece or billet wheels? I need different width's and offsets from front to back. Thanks
RCC
Old 03-21-2009, 08:40 PM   #72
BigShoe24
True Addiction
BigShoe24's Avatar
Re: Getting Started
Once again Nathan @ PB comes through. These are the motor mounts for an LS block that bolt directly to the DM. Everyone likes bolt-on. (when it bolt up right )
Thanks Nate
RCC
Old 03-21-2009, 10:45 PM   #73
jlaird
jlaird's Avatar
Re: Getting Started
Hey, where did you get that wilwood setup? Are those rotors really black?
jlaird is offline   Reply With Quote
Old 03-22-2009, 12:02 AM   #74
BigShoe24
True Addiction
BigShoe24's Avatar
Re: Getting Started
Jlaird, I know! They are from wilwood. I haven't mounted the rotors because my wheels aren't in yet. (they won't fit) They're just coated and when the rotors, pads are on, the friction zone will clean it's self. BTW, it's a 9" ford rear end.
RCC
Old 03-22-2009, 12:07 AM   #75
BigShoe24
True Addiction
BigShoe24's Avatar
Smile Re: Getting Started
Here are a few more pics.
Any comments? Suggestions?
RCC
