Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 07-11-2007, 01:21 PM   #51
1969k10stepside
Re: ex-Navy 68 K10 build thread
You could get power steering on the 68 and older 4wds.They,like the 2wds were ram assist.The steering box on it now is a 69 and up power steering box added by someone at one point.Probably when they added the np205 t-case in place of the Rockwell too.
The project is looking good.I remember back when I was back in that stage of the build...
1969k10stepside is offline   Reply With Quote
Old 07-11-2007, 01:25 PM   #52
Spanky_Pete
Too many trucks? Nah...
Spanky_Pete's Avatar
Those cracks make me want to go examine the frame on my '68 a little closer. It has power steering as well.
Could be worse though, the next body style GM 4x4s had a bad habit of breaking the frame right behind the motor mounts.
Spanky_Pete is offline   Reply With Quote
Old 07-16-2007, 02:33 PM   #53
kyoung
Progress 7/16/2007
I started cleaning up the frame for priming and painting. Initially I thought about getting the frame sandblasted but decided I wasn't in a hurry and would just clean it myself. I wanted a rotisserie so I could turn the frame for cleaning and painting but didn't have the room to store one while it was not being used. So I decided to make one out of engine stands.
I already had one engine stand and bought a second one for less than $40 at Harbor Freight. Then with a couple pieces of angle iron I was in business.
kyoung is offline   Reply With Quote
Old 07-16-2007, 02:36 PM   #54
kyoung
Here are more pictures of the stands and a couple of the cleaning effort.
Old 07-16-2007, 02:38 PM   #55
Chevy_Man
Tightwad
Chevy_Man's Avatar
I like that idea on the holding of the frame and being able to rotate it to do some work.....
Eric
56 Chevy custom cab step side under construction
55 Chevy 210
68 SWB Stepside back burner under construction
72 Chevy LWB
84 CJ 7
05 Chevy 1500 Crew Cab
30X40 DOGHOUSE(shop) with many add ons
Chevy_Man is offline   Reply With Quote
Old 07-16-2007, 05:23 PM   #56
surf200010345287
surf200010345287's Avatar
I had the idea of looking for a truck through DRMO but I didnt find anything other then some 2 ton trucks. Was the navy selling or did you get it from another owner?
surf200010345287 is offline   Reply With Quote
Old 07-16-2007, 06:17 PM   #57
Spanky_Pete
I had nearly the same idea for a rotisserie setup, how hard was it to turn? Those three legged engine stands aren't overly stable from my past experiences.
Old 07-16-2007, 09:42 PM   #58
kyoung
I bought the truck from an individual. I saw it in a Truck Trader magazine and pretty much bought it over the phone without seeing it in person. It was a six hour round trip to pick it up and I trailered it home. My wife got a good laugh when she saw it. She said " at least the tires are good". The next morning it had a flat!!!!
Old 07-16-2007, 09:49 PM   #59
kyoung
It is pretty hard to turn with just one person. I hooked my cherry picker up to one side of the frame and lifted it to where I wanted it. Then I put the locking pins in place on the motor stands. For safty reasons I leave the cherry picker attached to the frame (with tension) when it is in a tilted position. This is working out OK.
Old 07-16-2007, 10:29 PM   #60
msgross
msgross's Avatar
I really couldn't turn my rotisserie by myself either... Mind if I ask what the truck cost you?
Frame is looking good...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 07-17-2007, 09:08 AM   #61
kyoung
I paid $1500 for it. (owner was asking $2000)
The truck was running when I bought it but was very unsafe to drive. It had drums on the front and when you applied the brakes the right front locked up and wanted to put you in the ditch. I drove it around the block one time after I got it home and was happy to get it back in the driveway without getting myself hurt.
The engine ran good but smoked a little. I have decided to put a new crate engine in it.
The transmission and transfer case seem fine but leak, I'm sending them out to a transmission shop to be looked over and repaired as needed.
I am shopping for axles now and want to get the frame, drive train and brakes in good condition before starting on the sheet metal.
Old 09-26-2007, 10:09 PM   #62
sergio rios
are you going back with green paint............
meloyelo
sergio rios is offline   Reply With Quote
Old 09-27-2007, 09:32 AM   #63
kyoung
I have thought about paint color a good bit and have decided to go silver with a black interior.
Old 09-30-2007, 07:50 AM   #64
earl87gta
earl87gta's Avatar
Cool project when your ready for a disk break front PM me I know were one is cheap.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 09-30-2007, 10:00 AM   #65
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Looks like a neat project keep it progress rolling. Is it me or does the frame lack some crossmembers?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 10-28-2007, 10:26 AM   #66
kyoung
Finally some progress...
Between my full-time job and a part-time lawn business I've had to put the project on the back burner. Now that the lawn business is slowing down, hopefully I can get some truck work done.
Used this primer and paint.
www.nomorerust.com
Thanks to member "msgross" for pointing me towards this product. The primer and paint was brushed on with a foam brush.
Old 10-28-2007, 10:44 AM   #67
Shock_Me
Shock_Me's Avatar
Wow! Nothing quite like a fresh frame. How did you like the No more rust product? Was it easy to apply? Does it show brush strokes?
Looks fantastic!
Pete
Shock_Me is offline   Reply With Quote
Old 10-28-2007, 10:54 AM   #68
kyoung
Looks fantastic!
Pete
The primer went on great with no brush strokes showing (if you put it thick). The paint probably does not look as good a a quality spray job but for my project it turned out fine. The paint is thick and is more like a coating than just typical paint. It reminds me of that stuff that you can dip tools in and it coats the handles.
Old 10-28-2007, 11:14 AM   #69
Shock_Me
Shock_Me's Avatar
The result looks very smooth. Did you sandblast or wire brush?
Pete
Old 10-28-2007, 11:18 AM   #70
Shock_Me
Shock_Me's Avatar
sorry, just re-read your post. Looks like you wire-brushed. nice job by the way.
Pete
Old 10-28-2007, 11:41 AM   #71
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Looking good.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 10-28-2007, 02:34 PM   #72
ColoradoK5
ColoradoK5's Avatar
Nice truck witha good story behind it. The fram came along nice,if i ever do a frame i will use your engine hoist idea! keep up the good work.
ColoradoK5 is offline   Reply With Quote
Old 07-21-2008, 01:25 AM   #73
navybear70
hometown heroes!
navybear70's Avatar
TTT... justed stumbled on this, how is the project going? Retired Navy here, I love these old military trucks. I used to blow them up at a bombing range in FL. Had to follow orders...sigh.
2009 Silverado 2wd, 121k as of 04APR13. I love my truck 29 days out of the month. The payment is due on the 30th...
Do your duty in all things. You cannot do more, you should never wish to do less. -Robert E. Lee
"Never give up ground you've already taken." -Unknown
navybear70 is offline   Reply With Quote
Old 12-05-2010, 10:39 AM   #74
jevonniespapi
NICE! Never seen a motor pulled like that!
jevonniespapi is offline   Reply With Quote
Old 12-15-2010, 10:40 AM   #75
spike38
spike38's Avatar
I saw in a classified section, where you said you put it back together.
Do you have any pics of it together? it would be great to see them
Spike
spike38 is offline   Reply With Quote
