Old 08-18-2011, 08:54 PM   #51
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: Pics and specs of lifted blazers
Originally Posted by ol' yeller 72 View Post
yeah i cut my fenders. i took painters tape and lined it up with the bottom of the grill and follow it with the body lines, then i took off the grill and used a die grinder with a cut off wheel to trim the fender cups off. its easier to take the grill off so you can make a clean straight cut on the back side of the fender.
Does it still attach to the core support? I looked at mine and thought it would end up unsupported.... nothing to hold it from moving around...
Rich
1972 K5 Blazer CST Click HERE
Old 08-19-2011, 01:53 AM   #52
ol' yeller 72
ol' yeller 72's Avatar
No that section of the fender does not attach to the core support.the upper and middle sections of the fender will support the core support and keep it from moving around on you.
'70 K/5 350/TH350/NP205
ol' yeller 72 is offline   Reply With Quote
Old 01-22-2012, 04:29 PM   #53
1tuff71
1tuff71's Avatar
71 Blazer with 6" susp. 3" body and 38's on 15x12 wheels Name:  P1210007.jpg
1tuff71 is offline   Reply With Quote
Old 01-22-2012, 04:39 PM   #54
Kurt L
Kurt L's Avatar
johnnywagon i use to have two copilots that age years ago,i had a coupla blazers years ago couldn't go any where with out my two copilots.great times
Kurt L is offline   Reply With Quote
Old 01-29-2012, 09:58 PM   #55
ol' yeller 72
*****update*****
7" lift on 35x12.50r15 bfg km2
Old 01-30-2012, 10:50 AM   #56
SamMargritz00
SamMargritz00's Avatar
4 inch lift. 33x18x12.5
SamMargritz00 is offline   Reply With Quote
Old 01-30-2012, 11:07 AM   #57
Burt4x4
Burt4x4's Avatar
Ok I'll play again...my other post is full of red xx
4" Rancho up front
5.5" Superlift "SuperRide" rear
3" Bodylift
1Ton Locked
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 01-31-2012, 12:02 AM   #58
Amitucky72
Amitucky72's Avatar
6" Superlift with 35" Old School BFG Mud TAs
Amitucky72 is offline   Reply With Quote
Old 01-31-2012, 06:32 AM   #59
mustardjimmy71
toys'r'us
mustardjimmy71's Avatar
hey burt, any Sheet metal cracking due to the body lift and flexing? Ive heard of 80s k5s having the problem in the door jams
71 jimmy bone stock 350 sm465 33x12.5 rallies
79 caprice landau full load crate350 th350 lowered 20"wires
00 f150 reg cab sb 4x4 5.4L
mustardjimmy71 is offline   Reply With Quote
Old 01-31-2012, 11:24 AM   #60
Burt4x4
Burt4x4's Avatar
Nope, never seen any cracking ~ I have poly body bushings and all 12 of my mounts are in good shape/solid.
Keep in mind I do wheel the rig perrty hard so the body and doors are no longer straight or lined up that well and my rockers have been replaced with steel sliders.
Old 01-31-2012, 02:23 PM   #61
rjsdad
rjsdad's Avatar
Looks great! I'm not too far from you. Where do you wheel at?
rjsdad is offline   Reply With Quote
Old 01-31-2012, 04:47 PM   #62
Amitucky72
Amitucky72's Avatar
Mostly in the coast range above McMinnville, Sheridan, and Willamina.
Old 04-10-2013, 10:13 AM   #63
Comerz
Got the lift on my 1985 K5 blazer last night, 4-5 inch spring lift on front, 3-4 inch block lift on back... Also replaced all the bushings on it last night also, hard job but drives like a pup now!![ATTACH][/ATTACH]
Comerz is offline   Reply With Quote
Old 04-11-2013, 09:10 AM   #64
RLONG
RLONG's Avatar
6" with 39.5x15
RLONG is offline   Reply With Quote
Old 04-11-2013, 09:44 PM   #65
GMC-YA68
GMC-YA68's Avatar
Is it just me or do some of the 4" lifts look the same height as some of the 6" lifts??
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 04-12-2013, 10:22 AM   #66
Comerz
Your exactly right GMC-YA68. Except the 6 inch is about $150 more. And harder on your engine, tranny, universal joint, etc. the 4 inch is perfect for height, money, and also so you dont have to replace a part on your truck every other month.
Old 03-29-2014, 07:22 PM   #67
jim harig
jim harig's Avatar
8 inch skyjacker soft ride Springs. 37x13.50x18 mud grapplers.
jim harig is offline   Reply With Quote
Old 04-26-2016, 01:22 PM   #68
preciador6
NICE
preciador6 is offline   Reply With Quote
Old 04-26-2016, 02:00 PM   #69
A1971Blazer
A1971Blazer's Avatar
'70 CST
The lift was on this truck already.....I got the part# off the BDS spring...
it says 4" on a 69-72 but it specs it as a 6" on later models...?
Looks like 6" to me but I'll have to ask my wife.......
35 x 12.50 x 15 Mikey Thompson Baja Claw on Level 8 15 x 10 wheels...
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 09-24-2016, 01:51 PM   #70
rjstorm
3 .5 rough country lift $339 on eBay with shocks tire is bfg ko2 33 x 1250 15 wheels 15x12 acloa
rjstorm is offline   Reply With Quote
Old 09-26-2016, 06:26 PM   #71
1972 Jimmy
1972 Jimmy's Avatar
Cool pics!!! Looks like silver lake....? Love taking my family up there as well. Nice ride!! Enjoy it!!
1972 Jimmy is offline   Reply With Quote
Old 12-30-2018, 04:51 PM   #72
BIG BLOCK JIMMY
BIG BLOCK JIMMY's Avatar
'72 Jimmy 4x4 with 4" lift, 35" tires and a 454 to get all moving. This was before the new lift (Same height). The old springs were sagging. I will add the new pics once I finish the other upgrades and get her rolling again.
72' JIMMY 454
BIG BLOCK JIMMY is offline   Reply With Quote
Old 12-30-2018, 09:00 PM   #73
A1971Blazer
2½" lift.... 33 x 12.50...on 15x8 rallys
1967 C10 Step side
1968 C10 Step side
Old 01-13-2019, 11:34 PM   #74
OldCreek
OldCreek's Avatar
71 Chevy
4" all spring lift
35 x 12.5 R16.5 Parnelli Jones on American Wheel 16.5 x 8.25 hurricanes.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 01-14-2019, 12:17 AM   #75
Landondale
Pretty sure it’s 6” with 35x12.50R15 1972
Landondale is offline   Reply With Quote
