04-25-2009, 09:18 AM | #51 |
Re: 1967 Chevrolet K20 "The BEAST"
mike
thanks but I can get the complete harness out of a lo mile 6 cyl truck the K5 has a 72 headlight harness in it and i want to go to gauges.. .. but i could use a long speedo cable if u have a spare.... wish i could go to Carlisle but its 5 hrs away..and i have enuff schtuff to keep me very busy up here..but as soon as the cab fabrication (metal) is done im gonna tackle installing the 292 and buy a gallon of Featherlite.... and start trowelling the bondo.... trowel sand trowel sand.... and sand and sand......
67/68 K/20 "The BEAST" 68 K15 V6 LWB. 73 K20 GMC Burb "The Bomber" 74 K/5 74 K20 Custom Deluxe 86 K10 Shorty 92 K2500 Burb 95 K2500 GMC Life is what you make it Live each day like it was your last Old GM Trucks never go out of style |
04-25-2009, 09:36 AM | #52 |
make sure the harness is for a gauge truck.. you can buy a speedo cable at autozone for $15 or so... Plastic shell but it works...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
04-25-2009, 12:08 PM | #53 |
never thought about autozone... dont know why.... thanks musta beena brain fart
It is a gauge harness thats why i want it.... 100% complete... NO cuts... all the retainers n clips too
04-26-2009, 09:13 AM | #54 |
Post Whore
You sure are doing a great job!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
04-26-2009, 09:24 AM | #55 |
thanks.... you folks keep me going and the fact i want it done so I can move onto the K5
04-26-2009, 09:55 PM | #56 |
got my other clip today for the blazer.. http://67-72chevytrucks.com/vboard/s...9&goto=newpost
05-18-2009, 06:09 AM | #57 |
On Saturday after picking up some junk laying around and organizing just a bit.... I started a "half hour job" to remove V8 crossmember and install 292 crossmember.... got it 3/4 way unbolted only to find the PO had welded the lower PS portion... apparently he either lost the bolts or couldnt get the holes to line up.... needless to say i had to grind and drill and grind some more ( no torch here) it took 3 hrs.....
and of course had to spend a lil money on a handy shop cart too.... Hey I cant sink all of my cash into trucks...
05-18-2009, 06:17 AM | #58 |
Sunday finished up most of my welding and fabrications...
fimished the welding on the DS rocker and ground the "spot" welds and completed my PS vent box reconstruction..... only thing left to do now welding / fab wise on the cab is... the bottom of the DS vent box Next step finish dent removal and troweling and sanding....
05-23-2009, 05:40 PM | #59 |
scored this and a decent set of 68 chevy eye brows and some headlight bezels from a local fella today.... the only one of the bezelsis decent but hey cant beat the price.... $60 the gate is rust free but had some dents but it will be great for my 70 K5 which currently has a gate with NO bottom on it the bottom trimis attached with 2 sided tape.... its a real 67 68 gate....
05-23-2009, 05:45 PM | #60 |
ok i posted this same question in the main forum..can any one help?
ok Stupid request.. could you get me some pictures of the engine mounts specifically how they are attached to themotor thru the cross memeber and to the block mount? the PO had taken the motor out and the one I got was already out of the truck with the c shaped rubber mount and the small square rubber and bolts already set aside.. I may be missing something or just having a brain fart but i want to get the motor in my truck with all the mounts properly installed
05-23-2009, 10:20 PM | #61 |
That looks like the rubber for the tranny mounts... should be two of them..
05-27-2009, 04:48 PM | #62 |
Hey Dan, way to go man that thing is a "BEAST" and it looks good now. I just tossed a 67 cab with some rust in the cowl but the floor was perfect, I was going to cut the bottom of the cab off, but didn't it has been sitting for about 2 years and I haven't touched it so off it went!! I hope to get my 72 Burb home this weekend?! Let's see more, and especially my err I mean YOUR Blazer?!
05-27-2009, 04:50 PM | #63 |
Oh and the motor mount just sits on that pad and a bolt from the backside goes into the mount. The C shaped mount is as Mike says the trans mount, C down and the square comes up from bottom to bolt into trans/transfer case mount.
05-27-2009, 05:07 PM | #64 |
thanks Mike
I cant wait to get the cab on the chassis.... here is the motor...Just ordered the Engine mounts from NAPA today will have them a new clutch kit and seals and gaskets by the weekend.... then the motor becomes chevy red compliments of POR 15
05-27-2009, 05:09 PM | #65 |
figured that out tanks to other board members thanks GUYS! nice to have all the pieces... now comes the fun...assembling it all... and finding an exhaust..the book at napa had alot of N/As on the diagram
05-27-2009, 05:13 PM | #66 |
dont tell me the woes of life in the desert southwest and how you toss out cabs cause of minor rust...ship em up here!!!! LOL
still thinking im gonna grab that 70 2WD blazer chassis and swap the 70 K/5 tub to it.... already have a nice K/5 might as well make a "C/5" and trick it out with a LT1/ 4L60E and 3.23 gears for LONG legs
05-27-2009, 05:15 PM | #67 |
Any half decent exhaust shop should be able to bend up a system, be sure to pony up the extra $$$ for stainless pipe if you can then the rust gremlins will stay away for a while longer?! How's the K5 look with the 72 nose job?? I was thinking of you when I bought a cherry 68 clip with original paint on it still, I said man I wish I had the clip from the Blazer (both as the 2wd I sold has a cherry clip from a GMC as well)!!
05-27-2009, 05:29 PM | #68 |
you kill me man! I gotta strip those puppies (68 fenders) and re smooth them and make a small rot repair on the PS wheel house under the battery.... should be pickin up the torsion boxes next week when i head east for work NICE! then its TOP off summer cruisin even if it is in primer still
05-27-2009, 06:28 PM | #69 |
I am jelous though I have no more Blazers to go topless in!! I sat in the 2wd when I swapped tops (no motor or trans, so I was sitin' in the driveway makin' motors sounds with my mouth!!) it was too cool to have nothing obstruct your view except the vent windows and windshield frame?? Maybe I'll make the burb topless?, NAH!
BTW I offered that 67 cab to someone on the board for free, but the trip was going to be too spendy for him to get it?? I tried?! Last edited by 70rs/ss; 05-27-2009 at 06:30 PM. |
05-27-2009, 06:46 PM | #70 |
Zoom zoom! or maybe I should be making raspberry noises ///LOL
did you get any slobber on the windsheld?
05-28-2009, 03:59 AM | #71 | |
Chevy 6 Cyl Blue--p/n 51617 ZP. Heat resistant to 650* but $33 bucks a quart. Not necessarily vintage- concours d'elegance- period correct, but might look nice set in the engine bay of a light blue/white two-tone fleetside.
06-01-2009, 07:23 AM | #72 |
my compressor decided to take a dump yesterday.. so not much progress till i can get a piston rod and fan for the craftsman compressor.... so much for oil less...LOL the piston rod decided it had enuff work....
any how i got the block painted with POR 15 chevy red.. (which looked more pinkish) so i hit it with Plastikote universal red... its looking good.. cleaned out the oil pan and removed a couple dents... same with the valve cover... going outta town over night to Albany for work so Im gonna pick up Torsion Boxes for the K5...from a member . not a bad way to make a work road trip profit my endeavour
06-01-2009, 07:29 AM | #73 |
OK call me simple..but im going to go look at a 68 C30 flat bed this week... 250 I6 4 speed... the price it right Ive been scoping this unit out for a year suddenly its for sale... .. Ill let yall know
06-14-2009, 06:27 PM | #74 |
some setbacks and trolling junk yards to find the right stuff for the PS setup..its almost complete! turns out i had the needed double pulleys for the alt and pump in my collection of crap.... but i needed a different bracket....
I can get it to work...anyhow here are some pics of a clean painted 292 and the mock-up of the PS setup... also scored another 68 grille the missing DS headlight bezel and a decent 72 grille off the same truck that donated the un molested wiring harness... and of course the last pic is of some of my Fleet..loading pics as I enjoy some Joe Walsh . "There Goes the Neighborhood"
06-14-2009, 06:37 PM | #75 |
hey Mike
how did you do the remove n replace of the pilot bearing???? I remember seeing it ..just cant find it thanks
