Old 10-02-2009, 03:20 PM   #51
CWT
Re: HOW TO: Split the brake lines (many have asked)
I also used a 69 Corvette M/C with my rear disc setup. Works great. Cost around $35.
CWT is offline   Reply With Quote
Old 10-03-2009, 06:58 AM   #52
ljackson
ljackson's Avatar
Thanks Chief, any help is greatly appreciated.
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate.
Maintenance, repairs and upgrades on his dime now.
http://zacks64longfleet.shutterfly.com/
Higher res. photos in my gallery.
ljackson is offline   Reply With Quote
Old 10-03-2009, 07:22 AM   #53
ljackson
ljackson's Avatar
Here is some info on the MC I think I will use. I think the Pic is at the bottom. The my MC came from orielly;s part number 10-1339 the pic on their site shows a different MC
Fenco Reman / Master Cylinder (Brake System)
For your 1967 Chevrolet Truck C10 1/2 ton P/U 2WD 4.6L 2BL OHV 8cyl PREVIOUS
Price:$14.99
Core*Core value is the used part that manufacturers use for rebuilding. AutoZone charges the core value to customers because manufacturers include it in their prices. When you return your core to AutoZone, we'll refund your core charge.: $9.00
Total:$23.99AVAILABILITY: SEND TO STORE LISTAVAILABLENormally stocked at your local store.
SHIP TO HOMEAVAILABLEShips within 2 business days.
Part Number: M1505
Weight: 8.75 lbs
Warranty: LLT
Application: With front drum brakes
Notes: - installer warning - unit must be bench bled. If you experience any installation problems, call toll free: USA 1-866-787-5132 can 1-800-293-0760
Reservoir: With Reservoir - Built In
Bore Size: 1"
Cylinder Honing: Never Honed
New Sleeved Bore: Yes
Special Installation Notes Included: Yes
Primary - Hole Size and Location: 9/16"-18 Fender Side
Secondary - Hole Size and Location: 1/2"-20 Fender Side
Features & Benefits:
100% : New Sleeved Bore, New Epdm (Ethylene Propylene Diene M) Seals & O Rings, Computerized Multi Stage Tested. Push Rods On All Manual Applications, Includes Part Specific Bleeder Kit
Old 12-23-2009, 09:07 PM   #54
NF65Fleetside
NF65Fleetside's Avatar
dug this one up cause I really want to do this. Question though, can I just buy new pre-bent lines from the Truck shop and make it a full on bolt in affair? I dont mind spending the extra cash since I dont have the time/space to fab up the lines myself.
NF65Fleetside is offline   Reply With Quote
Old 12-24-2009, 09:11 AM   #55
Byronic
The Beach Cruiser
Byronic's Avatar
QUOTE: The push rod was also modified for this MC.
Any more info on this. I feel the need for a dual MC for safety reasons.
Nice work and write up.
1999 Silverado DD
1966 Panel Truck
2003 Harley Road Glide
1967 Schwinn Tandem Single Speed
Byronic is offline   Reply With Quote
Old 12-24-2009, 02:41 PM   #56
Chuck78
the lines are real easy to bend, in fact, if just keeping the 4 whl drums, you don't even need to cut and flare the lines if you buy the right lengths, see my posts on this and it probably gives you the lengths I used. When doing discs up front, you will need a lot more plumbing for the prop valve and all.
Chuck in Ohio
*1962 GMC 1000 Panel Truck - 305D/Saginaw 4sp soon: 351C V6 + AX15 5sp OD trans, & 75-87/91 disc brake front end
*1988 Suzuki Samurai 4x4 project, VW 1.9L mTDI, Toyota R151F transmission & Toyota full floater axles, LWB body tub stretch project
*Many 1977-1979 Suzuki GS motorcycles, Kawasaki KDX220R, '77 Suzuki PE250, etc
Chuck78 is offline   Reply With Quote
Old 01-04-2010, 05:43 PM   #57
rain_man
rain_man's Avatar
i have a 61 c10 and i think i have every thing i need to complete the master swap. im useing a master i bought from autozone for $15 bucks it is from a 67 c10.
just have a few questions first thanks
1. do i have to drill new holes for this master
2. what mods are needed for push rod(pics please)
3.what is everyone useing for brake lines (they said n/a at auto zone) mine are a little soft.
thanks for all the info
61 step/long bed SBW(SOLD)
NEED A NEW PROJECT
rain_man is offline   Reply With Quote
Old 01-05-2010, 09:38 AM   #58
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
1) No holes need to be drilled...it'll bolt right up.
2) The push rod had to be extended. I sold my black truck, and for some reason never got pics of the rod. I cut the stock rod in half, then welded more rod between the two. I still retained the adjuster part of the rod. Once the master is installed, and the pedal is in it's released position (check your bump stops too) you want the tip of the rod to be about 1/16" to 1/8" max away from the piston.
3) I purchased some straight pieces of line from my local fittings store (or a speed shop).....it came with ends. Bent them and double flared them myself.
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 01-06-2010, 01:00 AM   #59
Captainfab
60-66 Nut
On the '60-'62's you will need to drill holes to bolt up a '63 and newer master cylinder
Old 01-07-2010, 07:55 AM   #60
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Oooops...thanks Cap, I didn't catch the year.
Keep assuming people have the 63 and up...
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 03-06-2010, 06:35 PM   #61
astrochimp
Has anyone done this, and have a parts list, and what modification the push rod needs (adjusted or welded) and length for the brake line?
If going from the 63 MC to a 67 C10 MC the bore diam is smaller 1-1/8 vs 1" from the numbers on line. IIRC this would require more peddle travel fro the same brake force?
David
astrochimp is offline   Reply With Quote
Old 03-10-2010, 07:33 PM   #62
jsinor1956
John
Got my 1964 with a new master cylinder in the plastic bag on the seat not installed looks like he one you used.Is there a way to tell difference in drum/drum master and a drum/disk master? Is there a proportion valve for a drum/drum set up? Thank you
Jim
jsinor1956 is offline   Reply With Quote
Old 03-10-2010, 07:47 PM   #63
jsinor1956
John
I have another question after reviewing, My old truck has the original master on and also has a power brake booster from a 84 C-10 on it. The power brakes seem to work OK but !!!?? The power brake rod was modified. All this has me confused I need your advice what direction do I go?
Jim
Old 04-22-2011, 08:44 PM   #64
firefighter736
firefighter736's Avatar
Don't know if it's cool to bring this back up but I'm thinking that I really want to do this when I put my truck back together in a week or two. I get the concept with blocking off the one T and the split but where I'm lost is the push rod... anybody have clever ideas on how to make a good pushrod? Would a pushrod like this work? Any thoughts on where to get the parts it does?
Thanks!
Barry
firefighter736 is offline   Reply With Quote
Old 04-22-2011, 10:03 PM   #65
slepysal
slepysal's Avatar
You can use your old master cylinder's push rod. If it is addjustable then addjust it out,if it is not you can have some one cut it and weld it. Or you can get an addustable one from speedway or a used one from the wreckers.
The push rod that is in the link will not work I used that type on my clutch master it had a pushrod with a threded end.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 04-22-2011, 11:30 PM   #66
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
It was very cool to bring this back up ...
Man, haven't seen this thread in YEARS !!
Whats up SAL !!!!
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 04-22-2011, 11:51 PM   #67
slepysal
slepysal's Avatar
John !!! Hows life in the country ? Hope all is well
Old 04-23-2011, 12:34 AM   #68
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
We are good .... Ive been going a serious of bad luck, but Im bouncing back slowly !!
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 04-23-2011, 09:34 AM   #69
Str8axle
Str8axle's Avatar
Would the pushrod from a 67-70 non-power truck work for those who don't have an adjustable one? Just a thought...
Ray
All my life, I've been told I'm a "Bad Influence"
Str8axle is offline   Reply With Quote
Old 04-23-2011, 10:54 AM   #70
Rich 5150 69
Rich 5150 69's Avatar
I ran across and old post a while back in the 67-72 section, this might help as well ...
http://67-72chevytrucks.com/vboard/s...d.php?t=456859
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 04-23-2011, 12:20 PM   #71
slepysal
slepysal's Avatar
you are not alone on that if it isnt one thing it is another. Hang in there
Back to the original post: my oe push rod was about 1/4 to short when fully addjusted due to the fact that I used an adapter for the master cylinder as a 60 used a 3 bolt set up and not 2. I ordered an addustable push rod from speedway it was 3/8 thred ,I used the part off of my old clutch master that attaches to the pedal, worked perfect !
Check to see if your push rod is addjustable it may work as is .
Old 04-23-2011, 02:23 PM   #72
A.T. RockDriller
A.T. RockDriller's Avatar
Wonderful thread, ChiefRocka.....
As far as the tough times go.....I sure know how that works.
I'll bet it gets better.....Remember...
" Pain is just weakness leaving the body "
We should be pretty strong when all the crap blows over.
I thought I'd add a little info on my own brake upgrades.
A different twist....the K-1000......4X4 mods.
I swapped my stock frt. & rear diffs for late model Dana 44 & 12 bolt corp. respectively....
Because I wanted to add the Hydro-Boost set-up eventually, I used the down-time to take care of it all at once.
With the new disc brakes and larger rear wheel cyl.s, I thought it wise to add the brake proportioning valve along with new brake lines.
I didn't do near as good a job with the camera as you did, but I did take a few.
I hid the new valve inside the frame-rail just under the driver-side firewall, and split the lines from there in the same order as you explained.
I also took the slide-on spring style tubing shield what-ya-call-its off of the doner 1-ton and used them coming off the master cyl and again in high abrasion or vibration areas like across the cross member, near the rear wheel cyls, etc. I slid them onto the line after the bend, before the fitting and flare work.
Here's the few pic's that show a little of what I did.
I could take a pic of the proportioning valve if anyone wants to see it.
As far as the twin master cylinder set-up that's stock for the '63....the clutch MC sure is a different story. More on that if you're interested on my build thread..."Rockdrillers '63 K1000".
After reviewing the photos, I can't say that I showed you much.
I'll take a few good shots of my work and post them a bit later, as I'm sure this thread will circulate around for some time, being the best reference for brake-line work that I've seen so far
Nice job, Chief.
Les Hunter
'59 3803 someday to be 3853
'63 GMC K1000...351E, TH400 Daily
'66 GMC 4000...351C, 5&2
A.T. RockDriller is offline   Reply With Quote
Old 04-29-2011, 09:31 PM   #73
jocko
jocko's Avatar
It looks like this one....I also have the Matco double flaring kit.
Using a drum/drum master (two port Impala) you do not need a prop valve.
Chief or anyone - is there an easy way to tell a drum/drum master from a disk/drum by looking at it. I ordered a 67 C10 dual res mc from oreilly's - but there was no way of ordering a "drum/drum" vs "disk/drum". It just was what it was, only one option. (or did 67's not even have a disk brake option? - if no, then any mc ordered for a 67 would be drum/drum by default?)
Happy to show my lack of 67-72 knowledge in order to find an answer!
thanks.
jocko
Old 04-29-2011, 09:41 PM   #74
Str8axle
Str8axle's Avatar
Disc/drum master has one bowl smaller than the other. Disc/disc and drum/drum both bowls are the same size.
And no disc brakes til '71
Ray
Old 04-29-2011, 10:41 PM   #75
jocko
jocko's Avatar
Awesome! Thanks Str8!
