Old 08-10-2009, 03:24 PM   #51
sgaylord
Project collector
sgaylord's Avatar
Re: Project "Jezabel"
UPDATE :::::
After taking a little time off from the truck to settle my life down, I have jumped back in the saddle again.
I welded in the cowl shell and seam sealed in a few places. Now the cowl is all welded in. I still need to go back and grind down the welds to pretty them up but she's in there for good...
I also cut the section of the firewall out where the heater core mounts and welded in a solid sheet of 20 gauge sheet metal to smooth it out. I have a few more holes to fill, then I will weld it back in and start on the lower "A" pillars, kick panel patches and floors.
I don't expect my progress to be that fast as I have a few irons in the fire, but at least I have some time to do a few things....
69 CST-10 SWB (disguised as a 67) 383/700r4 Jezebel
Jezebel 3.0 NEW!!!
2020 GMC 3500 Denali Duramax
2016 Harley Street Glide CVO
Roll Tide!
sgaylord is offline   Reply With Quote
Old 08-11-2009, 03:46 PM   #52
sgaylord
Project collector
sgaylord's Avatar
Here is one of the reasons I have not had much progress on Jezebel. I built this just to do initial cam break-in and to check for leaks and so forth when firing a new engine. It is not intended for engine break-in to seal the rings as I know more load needs to be on the engine for that. It's works great so far.
Jezebel 3.0 NEW!!!
Roll Tide!
Old 12-02-2009, 06:05 PM   #53
sgaylord
Project collector
sgaylord's Avatar
I'm back on this build. I have been working on this. So all my time has been taken with that. Now that the burb is in better shape, momma's happy, so now I can get back on my truck. We not completely I still have to do the disk brake conversion on the burb. My plans are to try and switch between the two and see how I can get it all done.
Here are some pics of the latest progress on Jezebel. I have the upper and lower cowl welded in, seam sealed and por15'd. Here are some pics of that.
Plans are to smooth out everything possible on the firewall. I just need to figure out which holes are needed and which ones need to be filled. I know I saw that somewhere on the site. It shouldn't be hard to find again.
Jezebel 3.0 NEW!!!
Roll Tide!
Old 12-02-2009, 11:13 PM   #54
bgood70
bgood70's Avatar
Great Work. Here is a thread I recently came across on Smooth Firewalls it may give you some ideas.
http://67-72chevytrucks.com/vboard/s...d.php?t=295546
70 C-10 SWB 350/700r4 Good 70 SWB Build
72 GMC Sprint SP Custom 350/Turbo300
bgood70 is offline   Reply With Quote
Old 12-03-2009, 12:23 AM   #55
oldblue72c10
LIGHT' EM UP!!!!!!!!!!
oldblue72c10's Avatar
Sweet build and the engine stand is sweet too be careful with a fan that engine it will drive away lol
BONDO IS YOUR FRIEND WOULD YOU EVER USE YOUR FRIEND
1972 custom 10 longbed
current 360 building a racing 355
oldblue72c10 is offline   Reply With Quote
Old 12-03-2009, 11:02 AM   #56
sgaylord
Project collector
sgaylord's Avatar
bgood70
Re: Project "Jezebel"
Thanks Brad for the link. It will come in handy.
oldblue72c10
Thanks OldBlue. That is what we do for fun around here. I just start that 383 up and take bets that I can out run any kid on a skate board...
Jezebel 3.0 NEW!!!
Roll Tide!
Old 12-09-2009, 11:10 AM   #57
sgaylord
Project collector
sgaylord's Avatar
Next step of the "firewall smooth out" was to cap the hole for the blower and to round off the corner of the firewall. Here are some pics of that being done.
I don't have pics of patching the blower hold. I ended up cutting a large almost rectangle patch due to some inner rust that was keeping me from getting a good weld while attempting to weld the standard round patch. After cutting back to good metal, the semi-rectangle patch worked well. You can see in the pics below the blower patch in the background.
This is the patch for the corner of the firewall.
Patch held in with magnets
Patch tacked in
Finish welded from the back side. I will work out the shape during the next step.
The next step will be to burn in the firewall.
Jezebel 3.0 NEW!!!
Roll Tide!
Old 12-09-2009, 04:22 PM   #58
VA72C10
VA72C10
VA72C10's Avatar
Looking good
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 12-19-2009, 01:01 PM   #59
brian69longbed
brian69longbed's Avatar
man the whole firewall! looking great, nice camaro by the way. keep up the good work!
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
http://www.67-72chevytrucks.com/vboa...d.php?t=354115
brian69longbed is offline   Reply With Quote
Old 12-19-2009, 09:20 PM   #60
sgaylord
Project collector
sgaylord's Avatar
12-09-2009 03:22 PM
VA72C10
Looking good
Thanks VA72C10
brian69longbed
Thanks brian69longbed. I'm nuts for not replacing this cab. I am the epitome of the male stereotype. It gets personal and I refuse to let it beat me....
Jezebel 3.0 NEW!!!
Roll Tide!
Old 12-19-2009, 10:09 PM   #61
sgaylord
Project collector
sgaylord's Avatar
Re: Project "Jezaebel"
I decided to repair the floors before completing the firewall. This way I will have a little more room to lay in the floor pans and replace the front braces. At least that is my theory.
Originally I wanted to try and remove the rockers in one piece because they had been replaced by someone not too long ago and are still in good shape. Well after spending about an hour trying to remove it in one piece, it became obvious that this rocker was not going to make it. So..... out comes the plasma and zip, zip and it was gone.....
Originally I though the area behind and around the rockers wouldn't be too bad and wouldn't need to be replaced. Well, remember this truck's name is Jezebel, and once it again, it's a fitting name.
Not too bad except for the area along the bottom of the inner rocker and the two obvious holes in the middle.
Your normal rusted area where the "A" pillar meets the floor. But wait, what is that black lump to the left? Yep, if you remember the cowl area you will know that that is. Our friend roofing tar....
What the roofing tar was hiding.
Cab corner
Jezebel 3.0 NEW!!!
Roll Tide!
Old 12-19-2009, 10:23 PM   #62
1956cameo
1956cameo's Avatar
I just bought a blazer project that has similiar rust issues as your truck. Very interested in seeing your progress. The progress and quality of work on your build is looking great so far!
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends.
'72 blazer 2wd build
67-72 Factory Big Block Registry
1956cameo is offline   Reply With Quote
Old 12-20-2009, 12:46 PM   #63
VA72C10
VA72C10
VA72C10's Avatar
You're making good progress....sorry for the continued unwanted finds, but judging by your work so far you'll have these problems whipped in no time.
Old 12-20-2009, 02:30 PM   #64
brn agn
brn agn's Avatar
Great work on the cab! I understand wanting to save something that is in such bad shape. It will be worth it in the end!
1969 C10 SWB Project Charity Case AKA "Roscoe"
1971 Cheyenne Super A Combined Effort
The Service Station-A practical ministry for those in need
brn agn is offline   Reply With Quote
Old 01-06-2010, 05:01 PM   #65
sgaylord
Project collector
sgaylord's Avatar
Here are the pics from the passenger floor demo.
Floor removed exposing the braces
Jezebel 3.0 NEW!!!
Roll Tide!
Old 01-06-2010, 05:44 PM   #66
sgaylord
Project collector
sgaylord's Avatar
More Demo
This gave me a clean slate to start from. I have misplaced the other pics from the passenger side but here is the same process from the Dr side.
Jezebel 3.0 NEW!!!
Roll Tide!
Old 01-06-2010, 05:55 PM   #67
sgaylord
Project collector
sgaylord's Avatar
Here is the brace and floor going in. The thought here was to be careful to make sure the brace was at the correct angle to attach to the "A" pillar. I needed to trim the brace a little on the small end to make it fit (1/4"). But all went into place after that. I was a little worried that the "A" pillar patch was in too far causing this but it appeared to be strait when I used a strait edge next to it.
The floor is in now. I will post pics of that later.
Jezebel 3.0 NEW!!!
Roll Tide!
Old 01-06-2010, 06:44 PM   #68
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Wow thats a lot of work
I know you want this under your belt but, why didnt you just use the other cab ???
Sad thing is, you prolly coulda sold it like it was when you got it & had enough money to put together a really good truck without all the rust repair... but hind sight is....
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 01-06-2010, 06:56 PM   #69
sgaylord
Project collector
sgaylord's Avatar
Yep, I could have done that and probably should have. I don't always follow easy path.... :-)
Jezebel 3.0 NEW!!!
Roll Tide!
Old 01-06-2010, 07:29 PM   #70
lks dcvn
lks dcvn's Avatar
I have to admit - you are saving that thing from the crusher and from the looks of it - it will be around for some time thanks to your dedication to 'doing it right the first time'.
Fantastic work so far...
lks dcvn is offline   Reply With Quote
Old 01-06-2010, 07:50 PM   #71
VA72C10
VA72C10
VA72C10's Avatar
I agree....great job saving it!!!
Old 01-07-2010, 11:41 AM   #72
sgaylord
Project collector
sgaylord's Avatar
Here are the pics of the dr floor and inner rocker. Still a little more work with the flapper wheel and then I will start working on the firewall.
Jezebel 3.0 NEW!!!
Roll Tide!
Old 01-07-2010, 12:15 PM   #73
LooseCannon
Your dedication is inspirational. Very nice work!
LooseCannon is offline   Reply With Quote
Old 01-08-2010, 10:57 AM   #74
sgaylord
Project collector
sgaylord's Avatar
lks dcvn
VA72C10
LooseCannon
Thanks guys. I really appreciate the positive comments. It's keeping me going. The way I look at it, by doing all this work, it will fulfil my quest for a rust free truck.
Steve
Jezebel 3.0 NEW!!!
Roll Tide!
Old 01-14-2010, 06:03 PM   #75
sgaylord
Project collector
sgaylord's Avatar
The latest dose of project Jezebel:
I attached the firewall with some klekos along the cowl and some clamps along the floor. As you can see from the pics the firewall off the parts truck lined up pretty well. I did all this so I could remove the cab for better access to the cab corners.
I needed to build a tool to remove the cab because I expect I will be removing and installing the cab multiple times. I didn't want to keep bothering my buddies to constantly help me lift it on and off. Anyway, to do this I built a cab lift for my engine hoist. The one "Solver" shared in a post of his a while back and it worked like a charm (Thanks Solver ).
So work will continue on Jezebel now. I am starting to see light at the end of the tunnel. (And not through the rusted cowl..... )
Jezebel 3.0 NEW!!!
Roll Tide!
