06-13-2008, 08:11 PM | #1 |
Keep Your Nose Clean
Smooth firewall
I'm considering going with a vintage air set up and a new wiring harness for my 72. Can you folks post some pics of which holes I can cover up and which need to stay? Thanks. MisterE
06-13-2008, 08:50 PM | #2 |
Re: Smooth firewall
Is this kinda what yer looking for?
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. Last edited by OhioDan; 06-13-2008 at 08:54 PM. |
06-13-2008, 09:05 PM | #3 |
Official Site Guitar Shredder
Re: Smooth firewall
hows this........
06-13-2008, 09:16 PM | #4 |
Re: Smooth firewall
hers mine.
77 swb starting all over again. |
06-12-2009, 01:19 AM | #5 |
Re: Smooth firewall
Now that I know a 700R is going in and i'm going to run a aftermarket wiring harness with the vintage air, what can stay and can get covered up? Please add more pics or modify the existing one? Thanks MrE
06-12-2009, 01:40 AM | #6 |
Re: Smooth firewall
tomorrow i am very busy all day however I have a pic of a bunch of holes that i need to cover up and I am sure quite a few more also need to be covered up. But it is a good start. I am starting to grind, weld and do whatever to my cab and want to be sure I have it right.
Ill post pics tomorrow night |
06-12-2009, 09:10 AM | #7 |
Re: Smooth firewall
Here are some shots of mine, we ran my a/c lines (Classic Auto Air) thru the inside of the fender and there is nothing on the firewall but the manual booster (Cleaner look) throthel cable, wire harness (which I should had ran thru the floor)..
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
06-12-2009, 09:22 AM | #8 |
Next project: 1970 K10
Re: Smooth firewall
Same deal here, Was going to run an aftermarket A/C and wiring harness, so I only left open holes for throttle, e-brake, steering column, master cylinder and one hole above the throttle. All others will be drilled as needed/if needed.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
06-12-2009, 10:36 AM | #9 |
Re: Smooth firewall
Thanks BigAl for the pics. Enlighten me on how the harness can be run through the floor? Any pics of how that works?
06-12-2009, 11:25 AM | #10 |
Re: Smooth firewall
What we thought about was to put the fuse block under the seat, then plug the engine harness and extended all the way to the front. My assistant who did all the wiring in my truck wanted to but I chickened out as I did not want risk ruining a $475.00 of wire harness. He still extended the engine harness and ran all the wiring thru the chassis. In my truck you do not see any wires anywhere except for the plug on the firewall which is something I am going to have to live with and I am constantly reminded by him (you should of let me done it) my next project will be done that way..Look at the picture of under the dash after looking at it it was not that many wires to extend this part of it..then there is a pict of what the engine bay looks like. It is a learning process and there are a couple of things that I would had done different but, the next one will have those changes done (hopefully) because I am not into it at this moment I just want to drive the 71...
06-12-2009, 03:33 PM | #11 |
Re: Smooth firewall
Here is a close up pict of what the master cylinder area looks like, hope it helps.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild Last edited by big_al_71; 06-12-2009 at 03:35 PM. |
06-12-2009, 03:55 PM | #12 |
Re: Smooth firewall
Sooo Clean!!!!
Northern California Group Met list: Cyclone, KCJones, TranzAm, extd56, hotrodhomi, mnky30, Rokcrln, Brad, JerryJones, Petey-pablo, 72Subby |
06-12-2009, 04:14 PM | #13 |
Re: Smooth firewall
Pictures of mine....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-12-2009, 06:40 PM | #14 |
Re: Smooth firewall
Big Al everytime I see your truck the more I like it.
06-12-2009, 07:20 PM | #15 |
Re: Smooth firewall
thanks mike I appreciate it......
06-12-2009, 07:40 PM | #16 |
Re: Smooth firewall
This is probably a stupid question. Is there a way to keep the factory a/c and some how still cover the driver side firewall? In essence rerouting the evaporator somewhere else.
Dont really have the cash for a aftermarket a/c with everything else I am planning to do with my limited funds.
71 Chevy lwb Super Cheyenne - http://67-72chevytrucks.com/vboard/s...d.php?t=341907 |
06-12-2009, 07:40 PM | #17 |
Re: Smooth firewall
Here are pictures of my dad's '69 GMC. He put Hot Rod Air in his. The stock throttle linkage, wire harness, steering column, etc. were retained. He did reroute the wires to be hidden as much as possible.
06-12-2009, 07:44 PM | #18 | |
Re: Smooth firewall
06-15-2009, 01:52 AM | #19 |
Re: Smooth firewall
Just got mine together today. I plan on using the Vintage air set up. Thus drilling 4 holes for the hose block on the RHS. but other then that. nothing else is getting opened back up. Only Holes used are: Steering Column Throttle pedal Mounting holes (3) Hold for the throttle rod and Brake Master Cyl. Everything else was Welded up
There are two kinds of people, those who finish what they start and so on. 70 GMC Longhorn (A.K.A Money Bucket) 57 Chev 3100 05 Chevy LLY Dmax. 67 Chevy Camaro Dad's Budget Build 55 My Longhorn Build |
07-19-2009, 12:05 AM | #20 |
Re: Smooth firewall
I have heard on several builds that the Vintage Air universal kit will allow you direct the lines through the fender but if you purchase the "year specific" kit for our trucks it will be setup to go through the firewall in a stock location. I believe you can order the year specific kit but specify the universal main unit. That way it still connects to your in-dash controls. I hope that helps.
Ryan 84 SWB, C4 IFS Crossmember, C4 IRS, RE7 bags, WCC 3pc 22"s My reBuild: http://67-72chevytrucks.com/vboard/s...d.php?t=346328 |
07-19-2009, 10:28 AM | #21 | |
Re: Smooth firewall
1967 SWB C-10, BBC 454, T400, 3.73 posi, 20" Coys 1972 K5 Blazer, SBC 400, 4 spd, 3.73, 6" lift, 35" mud grapplers 2011 Sierra Denali HD, 6.6 L Duramax, RBP 96R rims, leveled and Nitto trail grapplers, 2009 Acura MDX |
07-19-2009, 10:47 AM | #22 |
Between Trucks...
Re: Smooth firewall
Thanks for the pics guys. Getting ready to do this mod. Ordered the patch panels from Infanti, just waiting for them to get here.
Beat it to fit, Paint it to match... |
07-19-2009, 12:46 PM | #23 | |
Re: Smooth firewall
Fuse box is mounted to the bottom of the dash, screws stick up inside the cowl instead of into the engine compartmane. Run out the side above the fresh air vent in the kick panel. down the fresh air duct and out the bottom of it on the fwd part it drops right into the engine bay. Then runs inside the drivers front fender to the core support. Along the bottom of the core support and splits back to the rail for engine wiring. Engine wiring comes up from the rail right by the Auto Trans Linkage along the back side of the motor. Hope that helps.. I can get you pics if you want. but its pretty hard to see whats really going on in them.
07-19-2009, 02:49 PM | #24 | |
Re: Smooth firewall
07-19-2009, 03:45 PM | #25 | |
Re: Smooth firewall
I just used a factory harness and cut and extended it where I wanted to. Or, I just ran a new wire for Water Temp, HEI (not in the factory harness anyway) Tach, Oil pressure and rear harness was a round 7 wire was ran all the way up and over at the front as well. All had to be done custom. However, I am not familiar with how long painless' harneses are either so it might work.
