Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevrolet & GMC Pickups Message Board > Projects and Builds
Old 05-24-2006, 12:57 AM   #1
Hart_Rod
**Boomer Sooner!**
Hart_Rod's Avatar
1969 Burb build-up (Bagged, blown, rust repair, 5.3/4L60E, repaint, interior....)
*** 1/1/10 Painting is complete!!! Time to reassemble,
I put this here because most of the modifications/upgrades apply to trucks as well. The first picture is of the truck when I bought it. It was an original California black plate truck. It had minimal rust, most do to a leaky windshield and the exhaust exiting out the sides. The next picture is a rendering of what I envision it looking like when I'm done (rendering by Zumo graphics).
List of work completed:
Front: ART bags, ART StrongArms, CPP 13" drilled and slotted rotors with dual piston calipers and modular 2" dropped spindle.
http://67-72chevytrucks.com/vboard/s...d.php?t=174330
Rear: ART bags, Porterbuilt 2" dropped tubular trailing arms, CPP C-Notch, ECE Super track bar, shock relocation kit, 5 lug conversion axles, hidden hitch, and flip down tag. CPP 12" rear disc brake conversion with drilled and slotted rotors.
http://67-72chevytrucks.com/vboard/s...d.php?t=162718
http://67-72chevytrucks.com/vboard/s...d.php?t=162641
Build sheet:
Accuair load leveling setup (3/8" lines, 3 gal tank, viar compressor)
ART StrongArms
ART Bags
CPP 2" modular dropped spindles
CPP 5 lug conversion kit with 13" drilled/slotted rotors and dual piston calipers
PorterBuilt tubular trailing arms with built in 2" drop
ECE Super track bar
ECE Shock Relocation Kit
ECE 5 lug axles
ECE hidden hitch and flip down tag
PST sway bar & ECE lowered sway bar brackets
Misc parts from board members (drag link, brake pedal....)
CPP C-Notch
New 3.73 Gears
New Eaton posi unit
Energy Suspension polyurethane body mount kit
Body work:
Replaced/repaired inner and outer rockers, lower inner kickpanel, partial floorborard, and doglegs on both sides (Goodmark parts from Ed at MotherTruckers)
Welded holes in firewall including heater box
Welded in new rear quarters
Removed stock upper suburban trim and filled holes
Welded in 5 1/2" remote gas filler lid from 80's Nissan Sentra car
Welded up holes in dash installed by PO
Welded up factory suburban barn door holes
New Goodmark parts: Doors, fenders, inner fenders, core support, cowl induction hood, 72 GM inner and outer grill, 72 bumpers
Converted manual liftgate extensions to gas struts
http://67-72chevytrucks.com/vboard/s...d.php?t=220511
Removed tailgate scissors and replaced with cables.
Welded in truck bed ends for truck tail lights.
Bottom of body has been sprayed with SpeedyLiner undercoating
Engine:
5.3/4L60E w/ throttle by wire (only 10 miles, 2006 Tahoe)
Radix Magna Supercharger (BIGTEX)
EFI harness - Speartech
Doug Thorley headers!!!!! (JAMIE)
http://www.truckinweb.com/tech/engin.../photo_01.html
Cadillac CTsV oil pan
ECE motor & tranny mounts
ECE 27 gallon Stainless Steel EFI fuel tank
http://www.earlyclassic.com/catalog.aspx
Custom fuel line setup using Corvette fuel/pressure regulator (Thanks Shifty, BowTieOgre and PCMCobra!)
Interior
Autometer gauges (Putter)
http://67-72chevytrucks.com/vboard/s...d.php?t=110613
http://67-72chevytrucks.com/vboard/s...ghlight=gauges
Custom Buddy Bucket seats (B&W houndstooth)
Flaming River Steering column (PICKMUP)
Vintage Air
Rob
As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17
69 SuperBurb - "My grandpa used to have a Suburban exactly like that."
http://67-72chevytrucks.com/vboard/s...d.php?t=200387
67 SWB 4 Door CrewCab - aka DONKEY (5.3/4L60E)
http://67-72chevytrucks.com/vboard/s...d.php?t=226302
6T8 ZZZZ - Farm truck... original paint, slammed, tubbed, stroked, blown and "Bad 2 da Bone"!
http://67-72chevytrucks.com/vboard/s...d.php?t=358692
Motor info: http://67-72chevytrucks.com/vboard/s...d.php?t=370973
Hart_Rod is offline   Reply With Quote
Old 05-24-2006, 01:00 AM   #2
Hart_Rod
**Boomer Sooner!**
Hart_Rod's Avatar
Re: 1969 Burb build-up (Bags, 5.3/4L60E, repaint, interior....)
More pics of the tear-down... Made a nice mess on the floor also, forgot to put something in the end of the transmission, DOH!!!
Rob
Old 05-24-2006, 01:04 AM   #3
Hart_Rod
**Boomer Sooner!**
Hart_Rod's Avatar
OK, the hard part is done (not!). While the engine is out of the way, I plan on smoothing the firewall, redoing the front brake lines, redoing the front airlines, clean and paint. Then on to the fun stuff......
Rob
Old 05-24-2006, 01:23 AM   #4
AesC10s
Chevy truck addict
AesC10s's Avatar
lookin great man....keep up the good work
AesC10s is offline   Reply With Quote
Old 05-24-2006, 02:52 AM   #5
Frizzle Fry
It's only metal
Frizzle Fry's Avatar
Gotta love that. Good thing mine's a daily driver or it would be in pieces too! Keep the progress pics rollin!!!
Frizzle Fry is offline   Reply With Quote
Old 05-24-2006, 01:47 PM   #6
Jebb1978
Jebb1978's Avatar
I have been wanting to see your burb for a while (since the PS thread) and didn't know where to look. It looks sweet! NICE WORK! I love those burbs!!!
1967 Chevy K-10 Daily Driver
1959 GMC Subframed hotrod project
Jebb1978 is offline   Reply With Quote
Old 05-24-2006, 02:29 PM   #7
5150
Drive Topless
5150's Avatar
Looks good, hope my new one will look half as good one day.
Bryan
"I'm not fat, I'm hard to kidnap."
"You think of me as narcissistic when actually I'm just oblivious to other people."
- Drew Hastings on Himself
Tennessee Classic Truck Owners Click Here
First Annual Southeastern Truck Nationals in White House, Tennessee July 17th
5150 is online now   Reply With Quote
Old 05-24-2006, 04:46 PM   #8
blazerboy72
Are you going to use the stock exhaust manifolds or headers? I have been trying to get my stock manifolds to work but both sides are hitting the frame. I have heard that big block headers will work if you use LS1 flanges on them. I will be trying that soon.
blazerboy72 is offline   Reply With Quote
Old 05-24-2006, 05:10 PM   #9
Hart_Rod
**Boomer Sooner!**
Hart_Rod's Avatar
I wanted to use the stock ones, however if you're having problems, I may have to try something else. I think I remember Shifty of GenIII say something about the camaro/corvette stock manifolds would work. I'll try to do some research on that one.
Rob
Rob
Old 05-24-2006, 05:26 PM   #10
bouncytruck
I draw pictures all day
bouncytruck's Avatar
You can drop it off at my house when your done
bouncytruck
bouncytruck is offline   Reply With Quote
Old 05-24-2006, 05:36 PM   #11
LUV2XCLR8
Doesn't Play Well With Others
LUV2XCLR8's Avatar
Sweeeeeeeeeeeeeeeeeeeeet
PROJECT: "YFTSB" 1972 BLAZER 2WD
TOY: "GLACIER" 1981 BLAZER 2WD
LUV2XCLR8 is offline   Reply With Quote
Old 05-24-2006, 06:05 PM   #12
shifty
Finally out of debt
shifty's Avatar
can i drive down there in the fall so we can bag my truck next?!
DO YOU KNOW '80s-'90s KAWASAKI BIKES? HELP ME!!!
1968 C10 step - LS1/T56 swap in progress!
LS1 swap thread (@LS1tech): http://www.ls1tech.com/forums/showthread.php?t=370781 (please don't message me about it, thx!)
shifty is offline   Reply With Quote
Old 05-24-2006, 06:23 PM   #13
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
What are you using for motor mounts?
I ran into this problem on my 73 pickup when I was using ECE's motor mounts on my 6.0L/4L80E documented here:
http://67-72chevytrucks.com/vboard/s...d.php?t=193657
This is with ECE mounts on my '73 frame:
I am selling those now...
This past weekend I replaced the ECE mounts (which posistions the SBC about 3" forward of a normal SBC) and put S&P motor plates on it (which mounts it back in the same position that a SBC would mount. I expected grinding on the port above to clearance it and was told 00-02 F-body manifolds would work, but I believe I have it to where I can use the factory Truck manifolds.
I
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD)
Captkaos Customs
Old 05-24-2006, 06:39 PM   #14
72Chevrolet
72Chevrolet's Avatar
Looks great, keep it up!
72Chevrolet is offline   Reply With Quote
Old 05-24-2006, 06:45 PM   #15
Nightrider
Maximus Afflatus
Keep Building! Looks good! I have a very similar swap I'm working on, a 2003 Avalanche 4wd running chassis with a 71 burb on top. yikes! good luck
] : - 71' 4x4 Blazer
71' burb,5.3,4wd
83' GMC 1-ton,diesel
00' F250-powerstroke
00' Roadstar
84' Eagle model 10
06' Ford Focus
Nightrider is offline   Reply With Quote
Old 05-24-2006, 08:10 PM   #16
blazerboy72
I
Thats the same problem I am having and I am using the S&P plates also. Summit has big block headers for $99 and the flanges are $16 I am going to try that route and maybe I can help us all. Sorry to hijack your thread.
Old 05-24-2006, 10:35 PM   #17
Hart_Rod
**Boomer Sooner!**
Hart_Rod's Avatar
Shifty - come on down!!!
I'm using the ECE motor mounts. I was hoping to be able to use the stock manifolds, but looks like that might not work. A buddy of mine has an 02 LS1, I'll borrow his and see how it works. Oh, well not quite there yet. Spent half the day cleaning (still not done) and started working on fill the holes in the firewall. I also have some rust repair to do, but pretty minimal. After that I will be moving to the rockers and and a small amount of rust on the floors/kickpanels. Here are some more pics, the old burb is definitely at parade rest now.
Rob
Old 05-24-2006, 10:42 PM   #18
Hart_Rod
**Boomer Sooner!**
Hart_Rod's Avatar
I also gutted all the engine & dash wiring. I enjoyed this quite a bit, since PO had cut and spliced into every wire on the truck. I found many melted or burnt wires as I was doing this. Also, cut the firewall to accept a new painless wiring harness.
Rob
Old 05-24-2006, 10:58 PM   #19
Hart_Rod
**Boomer Sooner!**
Hart_Rod's Avatar
Chris (CaptKaos),
Just read your build post, nice job BTW. I know ECE designed their motor mount kit for the 67-72. Could this be the problem with the exhaust in your truck? I don't know what the differences are in the frames. Also, do you have some pics and descriptions of your fuel system. What tank, fuel pump, type of lines.....????
Rob
Old 05-24-2006, 11:57 PM   #20
Hart_Rod
**Boomer Sooner!**
Hart_Rod's Avatar
pictures and links to the gauge build by Putter and the one in FAQ by Ron Woodgeard.
Rob
Old 05-25-2006, 12:16 AM   #21
Man you are getting that thing going. I'll be plugging those same firewall holes here very soon. It is really looking nice.
70 Chevy SWB Step to Fleet (350/T350)
02 Chevy Silverado 1500 SWB W/T
Home Page
My Build Thread
CarDomain Page
Board Vendors
Old 05-25-2006, 03:59 AM   #22
Canadian694x4
Born To Lose Club
Canadian694x4's Avatar
Looking Great! Keep up the Sweet Progress
Brian Smith - "Born To Lose"
1969 Chevrolet K10 LWB Fleetside - O.S.C.: "Ontario Summer Cruiser!" 1 of 208 Built & Sold In Canada!
- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's.
2007.5 GMC Sierra SLE 2500HD 4x4 - A.D.D.: "Alberta Daily Driver!" 1 of Thousands Built In Pontiac, Michigan!
- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Toyo Open Country MT's.
HELP SUPPORT THE BOARD
Canadian694x4 is offline   Reply With Quote
Old 05-25-2006, 04:10 AM   #23
sixty8c10
MY EX DRIVES A BROOM
sixty8c10's Avatar
looking good
They say nobody's perfect.
I'm a nobody, so I must be perfect.
Building Nemo
sixty8c10 is offline   Reply With Quote
Old 05-25-2006, 05:32 AM   #24
local13hutch
MEMBER
local13hutch's Avatar
Lookin great. And perfect timing for me I just started on my sub yesterday and you have already saved me some grief. Thank-you and keep the pics comin....PLEAZE....
86 sub 4x4, 1 1/2 ton, duallie, big block
72 c10 short fleet, pro street
71 K2 blazer, almost stock
72 3/4 ton sub 4x4
61 morris minor pickup, chevy 4.3 v6
03 escalade, 24" momo's
93 chevy 454, 1 1/2 ton motorhome
96 2wd 2door tahoe
67 2wd suburban
72 4wd k5 99 votrec 14bolt/d60 205/th400
local13hutch is offline   Reply With Quote
Old 05-25-2006, 08:36 AM   #25
Putter
More Cowbell....
Putter's Avatar
Holy crap...that gauge cluster is AWESOME. Where did you ever find something like that???? (**wink**)
Hey, if you are running 2700 rpm and have 0 oil pressure, you better shut'er down (see gauges)
Rob, glad to see you got all the parts home safe & sound. We had a great time at the cook out and really enjoyed meeting you and your family.
Oh, I just remembered you wanted the door hinges. You still need them? Shoot me a PM with address if you do...it's pretty dry out there for a change!! Maybe after we get this house done I will come over and you can help me do MY bags!
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Click Here For
Putter's House Progress
or
Putter's Shirts & Stuff
or
COWBELL SOUNDBOARD
Putter is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright 1997-2009 67-72chevytrucks.com
