Old 08-22-2012, 10:17 AM   #51
laynrockers
laynrockers's Avatar
Re: Help with fuel system design for LS1 install
Thanks for the info guys
laynrockers is offline   Reply With Quote
Old 09-03-2012, 08:20 PM   #52
hector93888
i got one question i got my set up used the adpters on fuel rail and filter all to 6an fittings my question is i got a some black braided hoses at work it say 5/16 on it is that the same thing a s 6an hose would i be able to use this hose or would i need to buy a 6an hose would hate to do that got free 20 feet of this hose.lol
hector93888 is offline   Reply With Quote
Old 09-03-2012, 09:26 PM   #53
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
that kit should do it with 20'...I would think...with a few more fittings for more terminations. There would be 3 or 4 sections depending on design.
Maybe this has been asked.....but I see some pics of systems with and some without a fuel filter before the pump. I'd be afraid of pump damage due to debris w/o a filter before the pump...then to the vette reg/filter (or just reg. or filter, or nothing) behind the pump. With a new tank one might get lucky, but with an old fuel tank...look out!
Thoughts?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 09-03-2012, 11:37 PM   #54
brossow
Amateur Rust Fighter
brossow's Avatar
Just because it has a "braided" outer cover on it doesn't mean that it's pressure rated for fuel injection. Be sure to find out what pressure it can handle before you just assume that it's up to the task. It could be low-pressure rubber fuel line with a fancy braided cover for show. A burst fuel line could destroy your project in seconds -- not worth the risk just to save a few bucks, so check it out before you make a decision.
Brent
'72 Chevy SWB stepside - [ Build Thread ]
'79 ChevMC SWB fleetside - [ Build Thread ]
'64 Chevy SWB fleetside & '66 Chevy SWB stepside (waiting in the wings...)
brossow is offline   Reply With Quote
Old 09-03-2012, 11:37 PM   #55
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Running a pre-filter is fine, but because of the amount of pressure we run (pressure actually being suction when before the pump) there is a tendency for pre-filters not to have a large enough pass-through and cause restrictions. You can get a large-mesh pre filter to keep rust or in-tank garbage from getting to your pump, although most fine debris that would get in a tank would pass through the impellers on the pump and do no real damage.
You'd have to have something the size of a BB or so to actually damage the impeller.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-23-2012, 05:30 PM   #56
High ho silverado
High ho silverado's Avatar
I'm curious about the sender attachment that was asked earlier, on the older senders how are the hoses being attached, I was thinking of flaring the lines and using an fittings to braided hose, haven't seen any picks of this and was jus curious, ill b using a factory sending unit for an 87 tank with my pump, jus curious how others are doing this, glock didn't cover that in his section, jus that he used 87 tanks, also curious what pumps he used in that set up too. Thanks for any help.
Dan G
Lift it, fat chicks cant jump!
83 Chevy shortbed 4x4: 6.0 ls powered
97 Chevy 3/4 ton ex cab 454: work horse
00 Chevy camaro: daily driver
83 Chevy 3/4 ton: dads old rig
High ho silverado is offline   Reply With Quote
Old 09-23-2012, 06:04 PM   #57
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
As far as attaching the fuel line and the return lines to the sending unit, I just used regular fuel injection rated hose clamps. I used them in the fuel filter/regulator too.
I used an 87 sending unit, which is already fuel injected, so the in-tank pump I used was just a simple R&R. The pump part # is listed in my thread..... somewhere. Lol. It's an OEM AC Delco pump. And those OEM pumps have been working fine with zero issues.
Now, if you are using 86 and earlier sending units, you will be better off using an external pump.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 09-23-2012, 06:35 PM   #58
High ho silverado
It's an 87 sender, I swapped the truck to tbi when I first put it together and put a brand new 87 tank and sender in it. I didn't think the stock 87 fuel pump would put out the 60 psi I would need for the 6.0, I was gona see if walbro made a direct fit that put out enuff pressure, I had figured that's what u were using, also not to sidetrack the thread but I realy need to find longtubes that will work on a four wheel drive other than dt's. Thanks for the help by the way and I followed ur Fred build very closely, it is really close to what I'm planning only in a four wheel drive. Great tips keep up the great work.
Dan G
Old 09-23-2012, 06:44 PM   #59
glock35ipsc
The 87 pump won't, but the oem pump I used does. I don't remember the part number right off, EP-241 or something like that. $60 or so. Look back through my thread, there is a full list of parts and numbers and where I bought everything from.
Bob
Old 09-23-2012, 07:15 PM   #60
High ho silverado
Thanks bob, another useful tip, ur the man. When I get every part figured out I'm gona start a thread, I'm even gona do my own wiring harness, possibly do my own ecm if I can figure out which program to run, I'm trying to get the hptuners thing going but I haven't had enuff time to get it done yet. Don't know how many people would be interested in it but we will c. Again thanks for all the info!
Dan G
Old 03-12-2013, 12:57 AM   #61
yossarian19
What are people doing as far as vent / rollover valves?
I'm retro-ing a Camaro LS1 pump into a 1970 Mustang tank, not sure what I need to do to keep air moving appropriately in / out of the tank.
yossarian19 is offline   Reply With Quote
Old 03-12-2013, 12:20 PM   #62
68GMCCustom
for an older tank a vented cap?
those that have new custom tanks generally have a vent/roll over valve installed from the tank builder....least mine did.
Kurt -
Old 03-17-2013, 04:03 PM   #63
Roostboy102
Roostboy102's Avatar
What filter are you people running with the return style system? Am I thinking right to use a 97 Vette filter?
72 C10 - Multicolor, 4.8 ls, NV3500. Sold
72 K5 - Under Construction
Roostboy102 is offline   Reply With Quote
Old 03-17-2013, 04:32 PM   #64
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Earls in-line -8AN fuel filter. Just make sure whatever you get is rated for fuel injection levels of pressure.
Old 03-17-2013, 05:34 PM   #65
Roostboy102
I saw there's an earls with a max psi of 80 with barbed fittings which is what I'm looking for... Or that vette one...
Old 07-29-2013, 12:45 PM   #66
TypeSL2
I am moving my fuel tank from the cab to under the bed and plan to do a 6.0 Swap later on down the road. I have a lot of stuff to do the swap, but not all of it. My question is, do I need to do anything to the tank to prep it for the LQ swap, or can I run it like it comes. I need to know very soon because I am swapping the tanks out very soon and want to do it right the first time. I really don't want to have to take the tank out later if I don't have to.
James
TypeSL2 is offline   Reply With Quote
Old 07-29-2013, 01:09 PM   #67
ChevyCruizer
17's too small
ChevyCruizer's Avatar
What tank do you have? Is the pump an internal or external? Is your tank set up for EFI (does it have baffles). After that it will come down to fuel supply and return lines designed for the higher pressure. The tank I got was just a carb version and it has not been hard, but just extra work to get it set up for a LSx motor. If I would do it again I would just get the tank designed for EFI with the proper pump in the tank.
James
68 C10 SWB SS 5 lug power disc brake conversion 2.5 inch drop spindles van tilt column Air Ride Technologies Cool Ride air bag kits Performance Online tubular upper control arms and shock relocator kits ECE super track panhard bar 1 piece side windows
ChevyCruizer is offline   Reply With Quote
Old 07-29-2013, 01:12 PM   #68
yossarian19
James
There are a few factors involved here. I'll try and cover all the bases, but I haven't finished my coffee yet...
The 6.0 (or any LS) swap takes either a factory style pump that lives in-tank or a Walbro external that will give you 60 psi at the rails.
The Walbro external pump can suck fuel from the bottom of the tank, no mods needed. It is cheaper than a (new) factory style fuel sender, doesn't come with a level sender, is easier to replace and will not generally live as long as a fuel pump that is submerged in fuel. Heat is the main reason for that, vibration possibly another, quality also possible. OEM = King for reliability, most of the time.
The factory style basket pump will need a hole cut in the top of the tank & adapter ring welded to the tank to bolt it down. Vetteworks makes pump adapter kits that run around 75 bucks shipped and use the readily-available LS1 camaro fuel sender. Now for the catch: depending on tank depth, you may not be able to run the Camaro fuel module (pump + gauge sender) on less than 1/2 or 1/4 a tank of gas. It's about a 10" tall sender, so check that against your tank & see what's going to work.
Another consideration in your fuel setup is whether your motor will have a return line at the fuel rail or not. I think up until 2004 the truck motors all had a return line at the rail. After that, the returns were closer to the tank. Location of the return line is going to dictate your filter setup - camaro LS1 or 2004 Corvette "C5" filter. Either way, you'll need a return line on top of the tank.
A lot of guys, including me, use the '71 Mustang 22 gallon tank. Honestly, I wouldn't reccomend it. Any money I saved has long gone out the window in chopping on my frame to make it fit & fiddling with spacers & **** to mount it. I have long wished I'd gone with a custom for-the-truck-I'm-putting-it-in tank for $400, drilled 4 holes & been done with it. I'd have a filler on the rear fender, a more-stock frame & been done with that part of it.
Anyway, you've got options. One of them is to get a return line on top of the tank before you install it, put a line on the return that you can reach, tape it off & connect it when you get to the 6.0 swap, using a Walbro thats taking fuel off the bottom of the tank same as your carb. Just make sure you update fuel lines to handle the increased pressure.
Old 07-29-2013, 01:25 PM   #69
TypeSL2
That is great info yossarian. That sounds very similar with what I had gathered so far. I need to measure the height of my TBSS pump module and see if I can get that to work. I don't remember off the top of my head if the fuel rail I have has the return or not. Something I can find out tonight. I am going to bookmark this page so I have all of that. Thanks for the quick answer. Hopefully that will help other people also along the way.
James
Old 08-20-2013, 09:57 AM   #70
brossow
brossow's Avatar
Dragging out an old thread of mine....
Was just reading a thread on another site about electric fuel pumps and everyone there is saying that electric pumps MUST be located below the level of the fuel tank. As you can see in the picture below, mine is nearly at the top of the tank. There's a picture of a similar setup early in this thread where the pump is also mounted in the frame rail like mine, and I've seen similar elsewhere as well, so I want to assume that they're working fine, but this other thread has me needing to at least double-check. In the thread I was reading I think they were talking about carbureted setups rather than FI; not sure if that makes a different since FI will always be pressurized. What do you all think? Thanks to circumstances beyond my control, my '72 project is on hold but I want to be sure that I'm not doing something stupid when I get back to it.
Thanks,
Brent
Originally Posted by brossow View Post
You can see and read about what I ended up doing about halfway down page 12 in my build thread, starting at post 292 (link). Here are a few pics from that thread:
Brent
Old 08-20-2013, 12:09 PM   #71
mcmlxix
Collector of Projects
mcmlxix's Avatar
Thanks,
Brent
I believe the basic premise is that your pump is designed to PUSH fuel, not PULL it... While it may work, it may have a slightly decreased life expectancy if it needs to prime the pump each time. By prime, I mean to pull the fuel from the bottom of the tank up to the height of the pump...
Rich
1972 K5 Blazer CST Click HERE
Old 08-20-2013, 02:20 PM   #72
68GMCCustom
Mines had a carb pump and now efi pump...mounted on the frame...no issues so far.
Kurt -
Old 09-24-2013, 05:38 PM   #73
WickedDirtBag
WickedDirtBag is offline   Reply With Quote
Old 09-26-2013, 02:27 AM   #74
solidaxel
solidaxel's Avatar
Originally Posted by chevy72blu View Post
Just put in an order for (hopefully) all of my stuff. Man these fittings get pricey. Im sure that I am missing a few items, but I wanted to get the bulk of it and buy more fittings locally as I need them. Im running a 98 LS1 with returnless rail
Heres my list so far:
WIX-33737 regulator/filter
Summit SUM-PUMPKIT1 -6AN kit (20ft, includes 3 adapters, 2 straight, 1 90 and clamps)
Summit SUM-230406 -4AN 6 ft kit (for return)
SUM-220490 straight end (-4an for return)
RUS-660060 3/8 NPT to -4AN (for return)
(2) SUM-220690 straight ends
(2) SUM-220687 90 ends
RUS-644123 for vette filter
RUS-644113 for vette filter
RUS-640940 for vette filter
RUS-640850 for fuel rail
Anyone see any problems?
Does anyone have the cost of these items listed above.
I need to add the 87 fuel tank & sender along with the fuel pump for a 97 to this total for my 78
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 09-26-2013, 07:55 AM   #75
brossow
brossow's Avatar
Those are all Summit part numbers. Should be easy to look up.
Brent
