Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 02-01-2010, 11:55 PM   #51
70 beast
Certified Hobbiest
70 beast's Avatar
Re: jimmy build
well the intake and carb swap is all done! got the carb for 30 bucks from my dads co-worker (any cons to edlebrock carbs???)
took it for a spin, it needs a new booster (old ones stealing vacuum and leaking) but runs real strong!
so all thats left is:
1. get a new booster
2. buy and install shocks
3. install new power steering box
and a million other small items
my jimmy build
http://67-72chevytrucks.com/vboard/s...d.php?t=352536
70 beast is offline   Reply With Quote
Old 02-02-2010, 12:18 AM   #52
onlyifihadachevy
Re: jimmy build
Nice set up.
72 gmc 2500 2wd drive convert
My 72 thread
http://67-72chevytrucks.com/vboard/s...d.php?t=346712
THe other truck, wheeler 69 1/2 4x4, yellow and rusty.
http://67-72chevytrucks.com/vboard/s...d.php?t=350300
onlyifihadachevy is offline   Reply With Quote
Old 02-02-2010, 11:00 AM   #53
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: jimmy build
Looks like a good setup. So you notice a nice change in power?
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 02-02-2010, 11:53 AM   #54
70 beast
Certified Hobbiest
70 beast's Avatar
Re: jimmy build
i did notice when i took it around the block, that it had a better response. with the 2 barrel, it seemed sluggish and the vacuum leak was substantial enough to prevent it from driving half way decent.
with the new set up not only was i able to drive it around the block, it didn't seem like the vacuum leak hindered the performance of the carb and truck as a whole.
all in all, it was a great change.
my jimmy build
Old 02-26-2010, 12:39 PM   #55
70 beast
Certified Hobbiest
70 beast's Avatar
Re: jimmy build
update time!
ok, since i got the carb on i have been fighting the brakes tooth and nail. ended up replace the brake booster, master cylinder (3x..2 previous were faulty), proportioning valve, front calipers, and now brake pads (front only)...damn haha. but all was worth it. stops really good now. im looking into going to hydro-boost. have a buddy that runs it and says its one of the best mods hes done yet.
all i need to do now is get shocks for all 4 corners, maybe a new 4 core radiator, door locks, air filter, and re-gear the front axle to 4.56 to match the Eaton...and ofcourse register it and insurance
i do have a few questions on re-gearing.
Situation: i have the original d44 from this truck. it has 3.08 gears and i want to re-gear it to 4.56. ive been reading that if i go with a "thin cut" gear set ill need a new carrier. then i read about "thick cut gears".
now the questions
1. is there any downsides to thick cut?
2. can i really use my existing carrier?
3. is there any downsides to running a used (but in good shape) ring and pinion set (given its a thick cut set)
i really want to try and re-gear it myself (ive read ALOT so im pretty familiar with the procedure but reading and doing are two separate issues). there is a gear shop that can do it for a good price. (d44 is just a housing and gears, so eassy install i suppose)should i try and re-gear it myself for just take it to the shop?
ill post pics as soon as i get home. now i get to look orward to 4 hours of physics....yay
my jimmy build
Old 02-28-2010, 02:18 AM   #56
Chevymaniac
Re: jimmy build
You've done an awesome job in breathing new life into the K5. I wish i had one, but i have to be satisfied with my truck.
Keep up the good work.
Chevymaniac is offline   Reply With Quote
Old 02-28-2010, 10:52 PM   #57
dccarpenter
Re: jimmy build
Try and regear it yourself, you've demonstrated your mechanical competence in all the other photos you've shown. If you get that gauge that shows the depth rather than using the marking compound method it is not that impossible. I'm not a good mechanic and I managed it.
The Jimmy looks great by the way, I'd probably be one of the fools asking if it was for sale.
dccarpenter is offline   Reply With Quote
Old 03-01-2010, 06:36 AM   #58
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Re: jimmy build
Nice looks good all cleaned up with them goodies. I have never done re-gearing but have a lot of people tell me if your mechanically inclined its not all that bad at all!
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 03-01-2010, 11:58 PM   #59
70 beast
Certified Hobbiest
70 beast's Avatar
Re: jimmy build
well finally got around to posting up some pics. also got to take her for a quick spin with my women to get her opinion on how our trucks turned out. she loves it
got rid of all the red except for the tailgate. just wasnt feeling the red. i really want to repaint it primer gray or try and find a blue primer but we will see. the lady friend wants to take it straight to paint but i think thats later down the road.
and the new booster and master for the brakes.
thanks for all the compliments and i think im going to try and regear it myself . ill need to get a dial indicator but that shouldnt be a problem. so it theres any advice you guys have, im more that appreciative to hear it.
my jimmy build
Old 03-02-2010, 12:04 AM   #60
onlyifihadachevy
Re: jimmy build
Are you going to coat the master in something because mine looks rusty and is only a few months old.
My 72 thread
Old 03-02-2010, 12:20 AM   #61
70 beast
Certified Hobbiest
70 beast's Avatar
Re: jimmy build
heres ashot of the motor all buttoned up and a video of a test run
my jimmy build
Old 03-02-2010, 12:25 AM   #62
70 beast
Certified Hobbiest
70 beast's Avatar
Re: jimmy build
not sure yet. if i do ill just hit it with some black paint
my jimmy build
Old 03-08-2010, 01:58 AM   #63
70 beast
Certified Hobbiest
70 beast's Avatar
Re: jimmy build
i was looking through all my pictures and found an artsy kinda photo
also the one year of this truck is coming up...so stoked on how the trucks coming along
my jimmy build
Old 03-08-2010, 03:35 PM   #64
Rollinsqrbdy
Rollinsqrbdy's Avatar
Re: jimmy build
Man i really like ur blazer. I got a question though, What are you using for bumpers?
Its Kool to be a square
2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's
1985 C-10 ......My dream truck (under construction)
1984 k 10 Silverado...6" lift with 38.5 super swampers
New Mexico Member
--- Member of the Square Body Club---
Rollinsqrbdy is offline   Reply With Quote
Old 03-08-2010, 07:49 PM   #65
70 beast
Certified Hobbiest
70 beast's Avatar
Re: jimmy build
for the front bumper im going to alter the stock one until i can build my own front tube bumper and im going do the same for the rear also
my jimmy build
Old 03-30-2010, 01:07 AM   #66
Eturnit3
Bloodied Knuckles
Eturnit3's Avatar
Re: jimmy build
Ive always liked the original bumpers with the winch hidden behind the plate. Your build has come along way since the last time i looked. Kinda bums me out to see how fast everyone's moving along Whats up with the front driveshaft? How far down the line is this truggy build? Keep up the good work!!
Eturnit3 is offline   Reply With Quote
Old 03-30-2010, 11:03 AM   #67
70 beast
Certified Hobbiest
70 beast's Avatar
Re: jimmy build
ive got the front shaft waiting but i need to re gear the front before i can use it haha
i agree the hidden winch look is killer, but im not sure what i want to do for the bumper now. theres a winch bumper similar to yours at a local pick n pull that i was thinking about altering and using that cuz the original bumper idea i had didn't quite turn out like i had hoped.
my jimmy build
Old 04-21-2010, 10:55 PM   #68
70 beast
Certified Hobbiest
70 beast's Avatar
Re: jimmy build
finally got my shocks!
ordered up some pro-comp es3000 shocks
also forgot to mention i picked up a cherry grill bout a month ago. no dents, dings or folds like the last one for 30 bucks!!!!!
my jimmy build
Old 04-23-2010, 09:26 PM   #69
70 beast
Certified Hobbiest
70 beast's Avatar
Re: jimmy build
got the shocks on today
not much else. hung out with my parents n older sis.
on to pics
and a comparison of my grills
old
new
my jimmy build
Old 04-24-2010, 04:11 AM   #70
milled
milled's Avatar
Re: jimmy build
nice work dude! nice upgrades!
1970 k20 350 4speed hd44 14b
Circumventing the language filter is against site rules
milled is offline   Reply With Quote
Old 05-28-2010, 10:00 AM   #71
70 beast
Certified Hobbiest
70 beast's Avatar
Re: jimmy build
pick n pull was having a 50% off sale this weekend
so i went and got a 4 core radiator out of a 2wd 1 ton that was in great shape....$30
man i love 50% off sales.
my jimmy build
Old 06-01-2010, 10:06 AM   #72
70 beast
Certified Hobbiest
70 beast's Avatar
Re: jimmy build
finally decided on a color for paint.
wasnt feeling the flat black too much. almost went with a primer grey, but chose to see what a certain blue would look like and its the color.
going to get a few more cans from work and finish it up, and hopefully be driving it by mid june....hopefully
and my pops finally got his truck road worthy. had to get this going since he had to park his 62 nova for repairs.
my jimmy build
Old 06-01-2010, 08:48 PM   #73
Mike C
Mike C's Avatar
Re: jimmy build
You can buy a Dana 44 front case for 4.10 and up gears and you can swap the internals from yours into it. Probably cost $100. Or thick gears work fine. I had a set on my 12 bolt for years on the original 3.08 case.
If you are wanting some sort of traction device on the front, a TruTrac is ideal and can be had for $350 if you shop around. Also, a TrakLok will only set you back $200 and for the front is a pretty good option as well.
If it was me, I would buy the $100 pinion depth checker that ProForm makes (you may be able to get a knockoff on eBay even cheaper) which comes with a dial indicator. This will give you the ability to measure pinion depth as well as check backlash with the addition of a cheap magnetic indicator base.
You may be able to buddy up with someone who has a press to help you swap carrier bearings and to work with the pinion depth. Dana axles are a little more difficult to set backlash on because shims are behind side gears. To really pull it off you need a carrier bearing puller, but it is possible without.
Good resources on www.pirate4x4.com
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-01-2010, 11:04 PM   #74
70 beast
Certified Hobbiest
70 beast's Avatar
Re: jimmy build
thanks mike,
im always on pirate, reading. ill only post if its on my buddy's build. a little too much drama for my liking. but the tech it has is very helpful.
once i get the funds together i think ill look into that depth checker you suggested. and im gonna go with a thick cut set so i dont have to get another case. and as for a locker, i think ill keep it open
my jimmy build
Old 06-02-2010, 01:11 PM   #75
scottsdaleowner75
Re: jimmy build
What is that blue color called and who makes it? Is it a primer or paint?
scottsdaleowner75 is offline   Reply With Quote
