Old 03-07-2010, 01:42 AM   #51
hotrodrookie
hotrodrookie's Avatar
Re: Rear Ends
Mine were bent too, I bent them over with a BFH. If yours are that far gone, your better off going back to the wrecking yard. Got any pics?
hotrodrookie is offline   Reply With Quote
Old 03-07-2010, 01:58 AM   #52
blackdiesel
blackdiesel's Avatar
Re: Rear Ends
all that we've gotten were really bad. like HRR said, beat em with a hammer
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 03-07-2010, 02:05 AM   #53
Laid_Out_50
Laid_Out_50's Avatar
Re: Rear Ends
I'll try bending them back I'll take same pics tomorrow
We got it out from under the car in 20 minutes would of been faster but we only had one socket set. Next time I go I'm taking a rattle gun and be done in 5 minutes
Laid_Out_50 is offline   Reply With Quote
Old 03-08-2010, 04:45 PM   #54
Laid_Out_50
Re: Rear Ends
Do I really need the splash shields
Old 03-08-2010, 05:02 PM   #55
blackdiesel
Re: Rear Ends
Not necessaraly, but its easier to straighten them than to take them off
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 03-08-2010, 05:06 PM   #56
Laid_Out_50
Re: Rear Ends
i have to take the axles off anyways so I might just take them off if i dont need them
Old 03-08-2010, 05:08 PM   #57
blackdiesel
Re: Rear Ends
Well i can't think of a good reason that would make you need them. they just protect the back of the rotor from debris and water. looks better with them than without IMO
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 03-09-2010, 11:57 AM   #58
56ClassicTruck
Re: Rear Ends
I just picket up a ford 8.8 of a 1998 explorer with posi and disk brakes on craigslist for $100...my splash guards were not that bad... I had a question on the part that connect to the drive shaft U joints? its got a round part on the end not a not for u joints how do you do the condition??
1996 Dodge 3500 4x4
1977 F250 Camper specal 4x4
1956 Chevy 3100 truck
56ClassicTruck is offline   Reply With Quote
Old 03-09-2010, 12:00 PM   #59
Laid_Out_50
Re: Rear Ends
Not to sure how I'm gonna fix that part yet. Hey did your axle come with a little connector pin that's on top of the housing. Anyone know what this is for
Old 03-09-2010, 12:30 PM   #60
56ClassicTruck
Re: Rear Ends
Not sure it was getting dark last night but I will be out playing with my new toy today I'll take a look...
1996 Dodge 3500 4x4
Old 03-09-2010, 01:15 PM   #61
hotrodrookie
Re: Rear Ends
The electrical connection? Thats a diff sensor Im pretty sure, dont worry about it.
Old 03-09-2010, 01:28 PM   #62
Laid_Out_50
Re: Rear Ends
Can I remove it and cover the hole up
Old 03-09-2010, 02:26 PM   #63
blackdiesel
Re: Rear Ends
It has a yoke with a flange that bolts to it. 10x better than a regular old school chevy yoke that just has straps over the caps IMO, this way the caps cant fall off and lose all the needle bearings when you drop the drive shaft
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 03-09-2010, 02:28 PM   #64
blackdiesel
Re: Rear Ends
i reckon you can do what ever you set your mind too. are you going to put a tilt bed on it? otherwise you wont be able to see and admire all of your hard work
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 03-09-2010, 10:17 PM   #65
56ClassicTruck
Re: Rear Ends
Well I was told it was for the ABS??.................Hey how you ID this 8.8 there where no tags? in front by yoke it has a #5048..............15W
fotw-4025-AA
on ring gear#372 E47W AA 11 41 5AC
I was told it was a 3.50 gear posi.... Do this number tell???? I no I was told you count the ring gear wish is 41 and pinton gear wish is 11 and divid it..So would that make it a 3.72 gear??
1996 Dodge 3500 4x4
Old 03-09-2010, 10:22 PM   #66
hotrodrookie
Re: Rear Ends
fotw-4025-AA
I was told it was a 3.50 gear posi.... Do this number tell???? I no I was told you count the ring gear wish is 41 and pinton gear wish is 11 and divid it..So would that make it a 3.72 gear??[/QUOTE]
That 372 # on the ring gear sounds promising but dont quote me. Cant you just put chalk marks on the brake rotor and the yoke and count them?
Old 03-09-2010, 10:24 PM   #67
blackdiesel
Re: Rear Ends
sounds like 3.73's. thats all i've ever seen these in personally
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 03-09-2010, 11:40 PM   #68
Laid_Out_50
Re: Rear Ends
Do i really need to run an E-Brake on my 8.8" rearend or can I just do away with it.
Old 03-09-2010, 11:53 PM   #69
blackdiesel
Re: Rear Ends
Some states you have to have a e-brake. I think having one is a good idea, but it's up to you. the truck will run just fine without it.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
