02-25-2010, 09:03 PM | #1 |
Rear Ends
What kind (donor car) of rear end are you running on your truck? Posi or non posi? Disk brakes or drum?
02-25-2010, 09:23 PM | #2 |
Re: Rear Ends
ford explorer, 8.8 posi disk brakes e brake factory sway bars, and if you pick one up out of a mountineer you get factory traction bars. great rear ends, can be had for 150 bucks any day of the week wiht low miles
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway |
02-25-2010, 09:40 PM | #3 |
Re: Rear Ends
'79 Trans Am posi disc brakes... close to stock width
'56 truck (the never ending project) '06 Z/71 loaded (daily driver) '07 Mercedes-Benz C-Class (wife's driver) Gone: 72 SB, 67 CST, 57 BBW, 47 Panel streetrod, |
02-25-2010, 09:55 PM | #4 |
Re: Rear Ends
So any camaro rearend will fit?
02-25-2010, 10:37 PM | #5 |
Cancer Survivor in the making.
Re: Rear Ends
Which one?
My '55 1st GMC Suburban has the rear from a '73 Chevelle wagon. 10-bolt GM 62 inches WMS to WMS with 3.08 gears and drum brakes. I'd say its perfect for that truck. My '54 GMC 1-ton trailer puller has a GM 14-bolt with 3.42 gears and drum brakes. Its perfect for that truck. My '54 GMC 1/2-ton has an S-10 4x4 rear with drum brakes and I still don't know what gears. I hope its perfect.... Which of my trucks is closest to what you want yours to be? Choosing a rear, the right gear ratio and the right brakes is really determined by what you want to do with the truck.
'55 1st GMC Suburban - '54 GMC 1-ton trailer puller (in process) - '54 GMC 1-ton Hydra-Matic - '47 Chevy AD COE and lots more rusty old iron. Steve@OldSub.com OldSub.com . MaxwellGarage.com . OldGasTowRigs.com |
02-26-2010, 12:25 AM | #6 |
Re: Rear Ends
i have a 70 mustang rearend in my '57
02-26-2010, 12:26 AM | #7 |
Re: Rear Ends
every time i see that truck my jaw drops. never would have thought to paint one that color but i really like it!
02-26-2010, 12:28 AM | #8 |
Re: Rear Ends
Dang ! mixermike thats sweet !
"I feel the need for speed!"... as soon as I am done with my nap. |
02-26-2010, 08:56 AM | #9 |
Re: Rear Ends
02-26-2010, 08:07 PM | #10 |
Re: Rear Ends
i gotta BIGBLOCK under the hood brother
02-26-2010, 08:17 PM | #11 |
Re: Rear Ends
02-27-2010, 07:51 PM | #12 |
Re: Rear Ends
Will the rear end out of an 87 Camaro be a good replacement for my 1950 3100
02-28-2010, 03:50 AM | #13 |
Re: Rear Ends
98 ford exploder 8.8, 3.25 axle tubes, 31 spline axles, disk brakes, lim slip, usually 3.73 gears and theres tons of them at the wrecking yards.
02-28-2010, 04:08 AM | #14 |
Re: Rear Ends
Do the explorer rear ends come with posi
02-28-2010, 04:27 AM | #15 |
Re: Rear Ends
You asked, so I told you what I was using.
and the 7.5 i bought is getting rained on in the backyard since i picked up the 8.8 |
02-28-2010, 04:33 AM | #16 |
Re: Rear Ends
I started looking up the 8.8" and they look more readily available and since if replaced the 9" it shold be good. Does your 8.8 have posi
02-28-2010, 04:43 AM | #17 |
Re: Rear Ends
Pretty much, its a limited slip differential. Most of the explorers with 4 doors came with limited slip diffs. You can look on the tag, mine read L373 I believe(or somthing like that) the L is limited slip and it has 3.73 gears.
02-28-2010, 04:51 AM | #18 |
Re: Rear Ends
Well I can't run the 8.8 I looked and I have 5x4.75 bolt pattern for my front end and want to to keep it the same. I did find a website that says Gen 2 Camaro rear ends will work and 75-79 Novas
02-28-2010, 10:10 AM | #19 |
Re: Rear Ends
Chevy II Nova, non posi.
Robert C. 1950 3600 3600 re-do, shortening it up If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. |
02-28-2010, 11:24 AM | #20 | |
Re: Rear Ends
How hard was it to make fit under your truck I read that the 8.8 is offset to one side was this a problem when connecting the drive line to the trans? Is the bolt pattern still 4.5" or did you convert it to 4.75" |
02-28-2010, 02:03 PM | #21 |
Re: Rear Ends
Im not worried about the offset in the driveline even though I havent connected it yet. Iv asked all around and it shouldnt be a problem.
I actually went and bought 2 one inch spacer/adapter plates that convert the lug nut pattern to 5on4.75.($75) Im assuming your building an AD truck, if you havent already, go to TRUCKS tv dot com and look at the episodes of their classix project. Its an AD truck that they put an MII front end and 4 linked the rear with a 8.8 explorer axle. |
02-28-2010, 02:30 PM | #22 |
Re: Rear Ends
ive got the 8.8 under 3 of our rides. the offset makes zero difference. theres a u-joint in it for a reason. whats the difference if the drive shaft pivots up a touch from the axle to the tranny verses to the side a little?
you can either buy adapters or re drill your rotors to make it the chevy bolt pattern, or convert the front to ford.
02-28-2010, 05:45 PM | #23 |
Doin' it live!
Re: Rear Ends
I run a 74 Ponti Ventura 3.73 rear end in my '53 Panel truck. With my MII front end I just have one set of wheels with the same off set, they are double drilled of course for the two bolt patterns, but they work great and clear everything.
-Panelrodder 1953 GMC Panel truck - 'Curly' 1961 Chevy Suburban - 'Larry' - Sold 2005 Harley Sportster - 'Shemp' |
02-28-2010, 06:12 PM | #24 |
Addicted to Rust
Re: Rear Ends
68 c10 373 peg leg in my 48.
the 67-72 ford truck rear ends also work well
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
02-28-2010, 10:05 PM | #25 |
Re: Rear Ends
7.5 out of a 2003 S-10 Blazer, gutted and put a posi with 3:23 gears from a 2000 Trans Am.
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
