Old 10-12-2014, 04:09 PM   #51
chevy2tom
chevy2tom's Avatar
Re: C20 lowered pictures
I was rebuilding the front suspension & wanted to eventually bag the truck with drop spindles you still have the same travel with the stock spring, if you run drop springs you lose travel. Plus I have disc already so for you it would cost more to upgrade but worth it.
chevy2tom is offline   Reply With Quote
Old 10-12-2014, 04:55 PM   #52
bollybib
bollybib's Avatar
@northerngmc
The lower bolts (the ones in the trailing arms) were difficult to extract. They were rusted, the trailing arm hole was jammed with crud, and the bolts are 5 inches long so they don't want to just slide on out for you. I spent a lot of time soaking them with penetrant. I ended up cutting the bolt head off and coaxing them out of the hole with a two arm press until I could get the retainer and spring off. Then I used a nut and spacers on the thread end to slowly jack the bolt out. The uppers came off easy. Hopefully you won't have this problem but it's good to be aware of how hard these bolts can be to get out. I've seen other threads on this subject so it might be good to research some of them beforehand.
I put jack stands under the frame just forward of the rear wheel wells and jacked the truck up until I could drop the rear end far enough to unload the springs and then some. I had the pumpkin set on a floor jack most of the time which helped because I had to jockey the rear axle up and down a lot. I had another pair of jack stands to set the axle on as needed.
The new springs are a bit tricky to get started, there are a lot of parts moving around at first; springs, and two sets of nuts/bolts/retainer. The trailing arm is not parallel with the frame and everything wants to wander away from where you want it. You will probably have to experiment a little to find out what works best for you. Take pics of your original installation before you tear it apart and try to follow the same orientation of the parts when you put it all back together.
I replaced the springs over a period of about a week I guess. Since I've been retired I find I don't push so hard to get things done. I do as much as I'm comfortable with then come back fresh to do more.
It wasn't as easy to do as I thought it might be, but it came out OK and I like the way it looks and it rides a lot better. Good luck with yours.
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
Old 10-12-2014, 07:58 PM   #53
Stranny64
Stranny64's Avatar
Here is mine before...
Stranny64 is offline   Reply With Quote
Old 10-12-2014, 07:59 PM   #54
Stranny64
Stranny64's Avatar
And after with Paul's 4" rear and 2" front...
Old 10-12-2014, 11:23 PM   #55
northerngmc
northerngmc's Avatar
Originally Posted by bollybib View Post
@northerngmc
It wasn't as easy to do as I thought it might be, but it came out OK and I like the way it looks and rides a lot better. Good luck with yours.
Thanks, I really appreciate the feedback.
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 10-12-2014, 11:25 PM   #56
northerngmc
Very nice, I appreciate the photos. Great looking truck, is it an original survivor truck?
Blaine
Old 10-13-2014, 07:18 AM   #57
Stranny64
Stranny64's Avatar
Yes it is. All original truck out of Oregon. Good luck!!!
Old 01-09-2015, 04:00 PM   #58
1969Chev
1969Chev's Avatar
Here is mine. 3 inch lowering springs in front with a coio cut and 5 inch lowering springs in back with 1 1/2 inch blocks
1969 CST/20 396/TH400 Tach Posi
1969Chev is offline   Reply With Quote
Old 01-09-2015, 04:12 PM   #59
chevy2tom
chevy2tom's Avatar
Side shot
Old 01-09-2015, 04:24 PM   #60
markmdz
How far are you from the bumpstops, or are you riding on them now?
Originally Posted by chevy2tom View Post
Side shot
Nice. How'd you get that low?
markmdz is offline   Reply With Quote
Old 01-09-2015, 04:30 PM   #61
chevy2tom
chevy2tom's Avatar
Drop spindles in front. & drop springs in the rear
Old 03-16-2015, 04:01 AM   #62
BigBlockNBK
Chevy2tom where did you get those wheels and what size are they?
BigBlockNBK is offline   Reply With Quote
Old 03-16-2015, 07:06 AM   #63
chevy2tom
chevy2tom's Avatar
From a fellow board member a few years ago, they are centerline 16 x ? I'm going to look @ new tires today after work @ my local tire shop. I'm looking for something wider for the back & skinnier for the front also shorter profile.
Old 03-16-2015, 01:00 PM   #64
1969Chev
1969Chev's Avatar
[QUOTE=markmdz;6992832]How far are you from the bumpstops, or are you riding on them now?
I cut the bump stops out all the way around. the only thing i need really is a front shock relocation or just shorter shocks. They sometimes bottom out when i go too fast they sometimes bottom out.
Old 04-01-2015, 08:57 PM   #65
dukkie
My Spoon Is Too Big
dukkie's Avatar
Has anyone done the c20 western chassis drop leaves from summit racing (with pic)
1972 C20, 03-14-10 Build Thread
2000 Silverado 4.8L, 11-04-13 (Currently Parting)
1999 Silverado 5.3L, 07-07-14. (Engine Donor)
2015 Ram 05-20-15 (Daily Driver)
dukkie is offline   Reply With Quote
Old 04-21-2015, 10:26 AM   #66
Smith & Sons
Originally Posted by Jacfourteen View Post
here are some pictures of mine. I lowered it the cheap way, cut coils in front and pulled 4 leaves in back. This combo got me down 3" in front and 4" in rear. I still can haul with it but anything over a ton in the bed and I'm on the bumpstops (most I've hauled since drop is 3500#'s of gravel). More details here.
BEFORE (Sorry about the crappy pic, it was my cell phone but you get the idea.)
AFTER
Smith & Sons is offline   Reply With Quote
Old 04-21-2015, 10:28 AM   #67
Smith & Sons
How much did you cut the front coils & when did the front bottom out.Just getting ready to do our 69 C20.Thanks for taking the time,Doug
Old 04-21-2015, 11:42 AM   #68
SWB
Active Member
SWB's Avatar
My 72 C20
*K10 SWB. Orange/White
*69 Ford F100 21K Actual Miles, 2nd owner in family since new
*67 Chevy II RestoMod, Wilwood all around,
Heights Pro G front sub,, Shockwave Air Ride, 383cu in etc..
SWB is offline   Reply With Quote
Old 04-21-2015, 11:45 AM   #69
northerngmc
Originally Posted by SWB View Post
My 72 C20
Very nice, can you give us some details? How much is it lowered and how? What size of tires are those?
Blaine
Old 04-24-2015, 04:03 PM   #70
SWB
Active Member
SWB's Avatar
Mine is lowered about 4-5" with springs and tire size is P265/50R20. Rides nice with no tire rub, but has a rattle up front from time to time do to the firm spring in the pocket. Steve
Old 04-24-2015, 05:26 PM   #71
northerngmc
Coils or leafs in the rear?
Blaine
Old 04-24-2015, 07:50 PM   #72
SWB
Active Member
SWB's Avatar
Coils.....
Old 06-10-2015, 02:33 PM   #73
northerngmc
So for those of you with a 2"/4" drop, did you change the panhard bar?
Does anyone make a C20 adjustable panhard bar?
I am giving up on getting C20 springs sent to Canada so I am going with C10 drop springs and shocks. But what about the panhard bar?
Blaine
Old 06-11-2015, 06:56 AM   #74
chevy2tom
chevy2tom's Avatar
Try a Porterbuilt panhard bar
Old 07-19-2015, 11:49 AM   #75
Billyburban
Mine's static dropped now(2 1/2 drop spindles front & 4" drop springs out back) & going to bag it soon!
So all you have is drop spindles in the front stock coil an shock ?
Billyburban is offline   Reply With Quote
