Old 02-03-2012, 10:31 AM   #51
youngrodder
youngrodder's Avatar
Re: 48 5 Window air ride driver
Its funny because I hate the look of mine when it sits in the garage on jack stands when I'm working on it. It always looks so much nicer aired out..
Nice choice in wheels. It coming together nicely. What are you doing for a paint color?
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 02-03-2012, 10:57 AM   #52
1 bootlegger
1 bootlegger's Avatar
Looks great, good luck on your goal of making it to The Power Tour.
1 bootlegger is offline   Reply With Quote
Old 02-06-2012, 05:04 PM   #53
oldnslow
Old Guy
oldnslow's Avatar
Got the steering column (68 GMC) mounted and hooked up, Vintage Air heat / AC unit installed and the front fender lip "rolled" for tire clearance.
oldnslow is offline   Reply With Quote
Old 02-08-2012, 10:25 AM   #54
oldnslow
Old Guy
oldnslow's Avatar
My buddy Terry added filler pieces in front of the front stake pockets on the sides of the bed, lengthened the round rails and added a flange on top of the front bed rail that follows the contour of the back of the cab. It sure is good to have a second pair of eyes on your stuff during construction, his fabrication skills don't hurt either!
Old 02-08-2012, 10:36 AM   #55
youngrodder
Looks good. Everything is fitting like a glove..
Marc
Old 02-08-2012, 10:55 AM   #56
Larry Lindley
Love the fitment of bed to cab,fire wall looks great also.May have to use the bed ideal.
Larry Lindley is offline   Reply With Quote
Old 02-08-2012, 11:22 AM   #57
xpickup
xpickup's Avatar
oldnslow, everything looks great. When I build the bed for my 54 I want to do the front rail like that. Keep up the great work.
Shannon
xpickup is offline   Reply With Quote
Old 02-08-2012, 11:28 AM   #58
OC 72
OC 72's Avatar
Looking good Oldnslow!
OC 72 is offline   Reply With Quote
Old 02-08-2012, 08:49 PM   #59
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Here's an inspirational pic for you!
ChuckDriver is offline   Reply With Quote
Old 02-09-2012, 04:46 PM   #60
oldnslow
Old Guy
oldnslow's Avatar
Very nice, what year truck is it in?
Old 02-10-2012, 07:07 PM   #61
ChuckDriver
Looks like a 54.
Old 02-20-2012, 10:17 AM   #62
oldnslow
Old Guy
oldnslow's Avatar
Finally finished fab work on the bed, the 5 gallon air tank, 2 Viair 400 compressors, the Big Red valve and the battery all fit in the compartment under the bed floor. We also added the Danchuck A/C vents to the 55 Chevy dash. I hope to get the bed sandblasted and primed this week, remove the cab and start plumbing brake lines.
Old 02-20-2012, 10:23 AM   #63
youngrodder
The progress look great. The bed looks very well made...
Marc
Old 02-28-2012, 10:37 AM   #64
oldnslow
Old Guy
oldnslow's Avatar
The truck is stripped down to a rolling chassis, the bed is getting blasted and primered and we are starting to plumb the brakes and fuel lines. The list is getting shorter, 13 weeks until Power Tour!
Old 03-05-2012, 10:39 AM   #65
oldnslow
Old Guy
oldnslow's Avatar
Got the brake lines and transmission cooling lines plumbed this week end. Here is a picture of the Griffin radiator with the modified Lincoln Mark 8 fan attached.
Old 03-15-2012, 06:08 PM   #66
oldnslow
Old Guy
oldnslow's Avatar
I had to shorten and change the collector angle on the drivers side header due to clearence issues. The exhaust is done back to the mufflers, the tailpipes will be added when the truck has been assembled further. The bed is back from blasting and has a light coat of DP50 to protect it during bodywork which will begin tonight. There was a comment a while back regarding body clearence for the large C notch that was added to the center crossmember on the frame, as this picture shows, that notch was cut out and a smaller one was added as the body bottomed out on it, good eye, I wish that I would have noticed it first!
Old 03-15-2012, 06:12 PM   #67
av8tr33337
av8tr33337's Avatar
I really like that shade of green on the motor. Really nice build. I wish I could count down my build in weeks. I have to count it down in years ....
av8tr33337
AKA Bartman Email av8tr33337@yahoo.com
Bartman's Ad-S10 Chassis Swap
http://67-72chevytrucks.com/vboard/s...d.php?t=415418
My First Youtube Video
http://www.youtube.com/watch?v=B6hSt...eature=channel
More Pics of the 51 Project
http://s668.photobucket.com/albums/v...hassis%20Swap/
1951 3100 Pickup
av8tr33337 is offline   Reply With Quote
Old 03-15-2012, 08:16 PM   #68
Larry Lindley
good job keep at it.
Old 03-16-2012, 12:16 AM   #69
oldnslow
Old Guy
oldnslow's Avatar
We put the bed back on tonight to begin straightning the sheetmetal, the fabbed bed came out good but lots of welding equals lots of warpage, and sandblasting adds even more fun, But the louvers in the box where the air ride system hides under the bed floor makes me grin.
Old 03-31-2012, 10:38 PM   #70
oldnslow
Old Guy
oldnslow's Avatar
The truck was going to be the original dark green, but after looking at the engine finished in that color for a while, I decided to go with red instead. We have taken it down to the bare frame to touch up the paint where tabs and brackets were added as well as some modifications that were made. After the frame is re-shot, we can begin assembley. Power Tour is in a couple months and although it's in a bunch of pieces now, it's starting to feel like we can make it. It looks like DP50 light grey epoxy primer will be the color for the maiden voyage.
Old 04-07-2012, 04:53 PM   #71
oldnslow
Old Guy
oldnslow's Avatar
My buddy Terry re-sprayed the frame last Sunday (using it as a jig to scratch build the bed was sorta brutal on the paint) and Monday we began assembley. Here's the progress so far.
Old 04-07-2012, 05:03 PM   #72
oldnslow
Old Guy
oldnslow's Avatar
Here's a couple more
Old 04-07-2012, 08:22 PM   #73
ChuckDriver
Very nice!
Old 04-07-2012, 08:29 PM   #74
Rednek13x
Rednek13x's Avatar
great work, keep it up
Rednek13x is offline   Reply With Quote
Old 04-07-2012, 08:42 PM   #75
Larry Lindley
looks very good,where are you locating the rear air bags front of axle or rear of axle?
