Old 02-05-2011, 07:55 AM   #51
73gmc454
73gmc454's Avatar
Re: 77 yellow gmc swb
I got some soild stainless lugnuts from ebay,its looks like they kicked them from Fl to Oh so I put them in the lathe and tuned em up ! I like everything that can be stainless be stainless! I searched for stainless tire valve stems for a long time never found em with a .453" hole ,the only bad part with stainless, you must use some sort of thread lube,I use megalock sealer it has a bit of teflon in it , Jamie
73gmc454 is offline   Reply With Quote
Old 02-14-2011, 09:43 PM   #52
73gmc454
73gmc454's Avatar
I finally got back to making some progress, I made up the parts for a new fan shroud , I'll be mounting two 14" fans in it, got it all ready for welding tomorrow,
my build 77 gmc shortbed big block, http://67-72chevytrucks.com/vboard/s...d.php?t=438237
Old 02-15-2011, 08:05 PM   #53
mooseknuckles
mooseknuckles's Avatar
thats some nice work man!.....love the bbc, it should be a handfull!
mooseknuckles is offline   Reply With Quote
Old 02-15-2011, 08:12 PM   #54
baclay9
Looks so good man. I wish I was that far along. Can't wait to see it done!
baclay9 is offline   Reply With Quote
Old 02-15-2011, 10:42 PM   #55
baclay9
What spark plug wires did you get? Were they advertised as bellow the header or what? I want to make sure I get some that can be run nice and neat like yours. Also, where did you get the plug wire holders you have? Thanks man!
Old 02-16-2011, 09:11 PM   #56
73gmc454
73gmc454's Avatar
Thanks, Yep they are under header 409 taylors , I made the holders from solid alm 3/4"x 1/2" drilling 11mm holes and then cut them in half , when I first put it together I had the 502 style valve covers so I made a spacer to clear the roller rockers so I welded the holders to the spacer , then I got the bigger cover that I like better , but my wires were hooked to the spacers so I left them on , I made the spacers using 3/4" aluminum round stock with a 1/4 hole in the middle bolted them to an old head then made connecting parts using 1/4 x 1 " flat stocks bending the ends to match the head ,then welded the whole mess together , I got my fans today, more pics !
Old 02-17-2011, 12:35 PM   #57
Gordonr1973
Home Built '87
Gordonr1973's Avatar
This is an incredible build....looks awesome!!
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 02-17-2011, 12:59 PM   #58
baclay9
Don't mean to beat a dead horse but I have another question about your plug wires. Did you get the "universal fit"? It looks like they only have red and blue wires in the custom fit but they also have black in universal.
Old 02-17-2011, 01:35 PM   #59
73gmc454
73gmc454's Avatar
Thanks guys I've been tryin to get somin done, finally some nice weather ,No problem, I bought the wires a couple years back when they offered them in black, they were assembled , I believe that they are the same wires as these but black , http://www.summitracing.com/parts/TAY-79202/ , I just got rid of the box about 2 weeks ago !
Old 02-17-2011, 02:03 PM   #60
baclay9
From what I can tell you can still get them black but they are the Thundervolt 50 series now. Was there plenty of length to them or is it a pretty tight stretch?
Old 02-17-2011, 02:24 PM   #61
watahyahknow
watahyahknow's Avatar
verry nice build , looking intoo turbocharging a pickup with a remote system , from the look on the pics they might fit in place of the gastanks under the cab along with the filters and water to air intercoolers , wish would mean they could be mounted straight to the normal headers with andapter with T4 flange and a smal bend the tanks can go behind the rearaxle
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 02-17-2011, 06:23 PM   #62
73gmc454
73gmc454's Avatar
Oh yea I forgot about the thundervolt 50's , Yep they fit good there was a couple that I even shortened up,
Got the holes cut in the fan shroud and its all welded up , now hopfully I can get the holes drilled and it mounted up tonight , I got the heater plugged in so it will be ready to fire up ! gotta see if they work !
Old 02-17-2011, 09:33 PM   #63
73gmc454
73gmc454's Avatar
Yea I think the filters and tanks would fit in there theres a bunch of room in there ! the tanks are about 34" long 11"wide 10"tall
Old 02-17-2011, 09:44 PM   #64
73gmc454
73gmc454's Avatar
Got my fans on ,so I fired it up but the fans never came on till after I shut it off , I need a lower degree thermal switch or maybe mount it in a different location in the head/intake ? cant remember where the switch even came from but I thought it was a 180. also found out when they did come on the shoud neads some trimming around the fan holes , try again tomorrow !
Old 02-20-2011, 11:20 PM   #65
mooseknuckles
nice setup!
Old 02-22-2011, 09:25 PM   #66
73gmc454
73gmc454's Avatar
thanks, I'm tryin, the fan rubbing was because of a broken blade,the seller has a new 1 in the way ! been too cold out to test the temp switch but almost positive its a 220.I ran it up till the temp gauge said 205-210 , then after being off for about 5 min. the temp gauge said 215-220 when the fans kicked on ,looks like a trip to Summit !
Old 02-22-2011, 11:09 PM   #67
my4by2
my4by2's Avatar
Very nice build man - keep the pics coming!!!
my4by2 is offline   Reply With Quote
Old 02-26-2011, 04:20 PM   #68
jdurant
Just wanted to subscribe. Awesome build. I really like some of the choices you made. Seems like in every pic the color looks different. I know it's colonial yellow, but is it like a bright yellow, or pale, or like a mustard color in the outside pics?
Joseph
87 Turbo Buick
92 5.0 Mustang coupe
87 GMC Sierra SWB
82 Chevy K5 Blazer 2wd
jdurant is offline   Reply With Quote
Old 02-26-2011, 04:31 PM   #69
watahyahknow
i think that has more to do with how digital camara's pick up colours
like under fluoresent lighting it will be more green
Old 02-27-2011, 04:17 AM   #70
Abdul
Excellent job
Abdul is offline   Reply With Quote
Old 02-27-2011, 10:06 AM   #71
73gmc454
73gmc454's Avatar
Thanks guys ,glad ya think I'm heading in the right direction, the color is a creamy mustard yellow ?? The painter said it had lots of white in it , Its so shiny its really hard to tell ! I think it looks different from the factory because theres 4 coats of paint with clear on top, I saved the old glove box door , it was hard to get anything to come out in a pics but it does look like the old door is a shade brighter,
Old 02-27-2011, 05:06 PM   #72
77BBGMC
77BBGMC's Avatar
Looking good!
77BBGMC is offline   Reply With Quote
Old 02-27-2011, 08:35 PM   #73
73gmc454
73gmc454's Avatar
Ok got somin done today , first off I got the box for my air controls drilled and mounted up , them I changed the location of the thermal fan switch from the intake to the head , that worked great fans came on bout 180 and the temp never went over 185, I ran it about 1/2 hr, I'm feelin good !
Old 03-04-2011, 07:33 PM   #74
73gmc454
73gmc454's Avatar
Next up is makin a radiator overflow tank , washer fluid tank and a vacuum can, I started with some 4 " tube and some endcaps, need to install the inner fenders to see where and how they will be mounted , I also got a pic for you LS guys , somin we got in for a show car at the shop ,
Old 03-05-2011, 12:56 AM   #75
watahyahknow
i pitty the fool that needs to keep that engine shiny , it does look fantastic though
