02-12-2011, 12:46 PM | #51 |
Happy to be here
Re: Bolt in steering rack
How hard would it be to make a set? Could a more common pulley be used if someone stepped up and fabbed the brackets?
02-12-2011, 01:00 PM | #52 | |
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! |
02-12-2011, 01:08 PM | #53 | |
67-72 parts collector,…
A cool serpentine set-up would be cool also.
02-12-2011, 01:11 PM | #54 |
well guys this is interesting and I will keep watching this.
so far I have built and installed an ls motor did this before it was popular so i built my own mounts so it is in a different spot than all else. I have also cut and built coil over setup for mine. the rack and pinion would be a welcome addition however with what was said about teh engine mounts I am wondering if this will work for me? I will watch wish i was closer to california, well no I dont lol i wish u guys were closer to Missouri... Thanks and keep us updated as you are. Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
02-12-2011, 06:44 PM | #55 | |
Hollister Road Co.
02-22-2011, 01:18 PM | #56 |
bring this back up as I am interested to see what will be available and when. Like I said before my setup is way different than most as I have built what I needed to make my truck what it is but this looks like a neat option.
Dave
02-23-2011, 12:29 AM | #57 |
don't worry, I'm still working on it.
03-03-2011, 08:00 AM | #58 |
update?
03-03-2011, 04:36 PM | #59 |
We are now driving, and testing. Also, we have to work with a rack manufacturer, to get them the way we want, so that is still in negotiations. I should know more next week.
03-03-2011, 05:25 PM | #60 |
Just out of curiosity, how is the clearance between the engine and the rack? I've got my engine set as low and as far back as I could get it without major cutting and there is barely an 1/8" of clearance between my crank pulley and my center drag link.
Pro Touring 1964 C10-Under Construction http://67-72chevytrucks.com/vboard/s...d.php?t=441627 Project '65 Short Step Daily Driver http://67-72chevytrucks.com/vboard/s...d.php?t=661948 |
03-03-2011, 08:19 PM | #61 |
I think it will be OK, top of the rack body is 3/8" lower than the top of the stock drag link
03-04-2011, 11:59 AM | #62 |
Cool, any ballpark guesses when you'll have it ready for market?
03-04-2011, 04:18 PM | #63 |
Well, in typical No Limit style, it may take a few months. I'd say July is a safe bet. I can't, in good conscious, sell a new part that we have'nt beat on for at least 5k miles, then dis-assembled and tested. After all, these are steering parts, and we would hate to kill someone. , but i will keep everyone up to date. Thanks for the interest.
03-10-2011, 05:04 PM | #64 |
Any pics?
03-26-2011, 11:49 AM | #65 |
Here's a few spy shots. The new mounting does not require any cutting or welding to the crossmember. Just drill five mounting holes. A small notch is needed to clear the steering. This unit is mounted on the JT, and will be in Del-Mar next week. We are now moving into the production phase.
03-26-2011, 12:02 PM | #66 |
Put me down for the first unit! This falls into what I have been going for on project cod fish! Old school look with modern technology. I am very excited to see this come about thanks for all you guys do to make our trucks better!
03-26-2011, 01:19 PM | #67 |
Hey Rob,
Any pics of the driver side motor mount/rack clearance?
1967 GMC shorty Parts Pile: NoLimit, Accu Air, Kore 3, Matts Classic Bowtie, March Performance, Lokar, ScottsHot Rods, Vintage Air, American Auto Wire, Circle D, Accu Air, Borla, Budnik, Ididit, One Piece Windows, Doug Thorley, Pypes, AutoLoc, Porterbuilt, CPP, Dynamat, Dakota Digital, Fesler 1968 Chevy c10 shorty Stepper (Patina LS project) 1967 gmc custom Long Box (Farm Truck Project) |
03-26-2011, 02:58 PM | #68 |
Looks good Rob Just curious, is it set up for optimum bumpsteer with stock caster, or is it set up for arms with increased caster?
03-26-2011, 03:10 PM | #69 |
Let's us know when they are available for purchase ill take one. Thanks for keep us posted
Posted via Mobile Device |
03-26-2011, 07:54 PM | #70 |
Mech77, It is a tunable set up. The new tie rod end sits under the steering arm using a high-misalignment rod end. With stock arms, (and 2 or 3 deg of caster) use no spacers, then add 1/8" spacer for each 3* of increased caster.
03-26-2011, 08:29 PM | #71 |
Hey Rob, Ive been following your threads with drool running, You once stated the lower and further back the better, sooo. How about ten inches back and four inches lower. Ill have some pictures later.
03-26-2011, 10:26 PM | #72 |
I guess that's not with a stock firewall , Is oil pan clearance an issue? Love to see it.
03-26-2011, 11:35 PM | #73 |
Awesome....still looking at $600-$700 for the kit? Also, any closer guess on when it will be available?
03-28-2011, 06:59 PM | #74 |
I like the spy pics. glad this is commong along. thanks for the updates:
03-28-2011, 07:28 PM | #75 |
Garage wrench
I assume this set-up will work with the 73-87 GM trucks, maybe with a different outer tie rod end? Or, does it use the stock outer tie rod end?
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... Last edited by SBTork; 03-28-2011 at 07:28 PM. |
