Old 05-11-2011, 01:52 PM   #51
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Re: 1966 SBBW pro street
Thats the truck sitting behind in the background .....
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline   Reply With Quote
Old 05-11-2011, 01:58 PM   #52
wutnxt
So once both boxes were off and sitting on dollies we guessed how long it would take :
So from the time we measured the boxes.....cut all 4 sides inners and outers......swapped them out and had them "tacked" them in place was less then 2 hours
Old 05-11-2011, 03:35 PM   #53
SulphuriousSam
SulphuriousSam's Avatar
Comin together. Gonna Haul A$$ when your done! Subscribed cuz i gotta see how it turns out
1966 C10 LWB, 283, 3 on the tree (lots of work to do!) http://67-72chevytrucks.com/vboard/s...d.php?t=471348
2001 Suburban daily driver
2008 HHR (wife's ride)
SulphuriousSam is offline   Reply With Quote
Old 05-11-2011, 03:47 PM   #54
wutnxt
Thanks alot it's nice to get some good feed back
Well with any luck it's going to finish for the 1st week of july......Here is to luck being on my side Just picking out the colors for the truck this week...and start putting things together for a change
Old 05-11-2011, 05:36 PM   #55
LeftCoast32
Custom Builder
LeftCoast32's Avatar
Killer Build!! It should be real fast with a BBC and traction!!
LeftCoast32 is offline   Reply With Quote
Old 05-11-2011, 05:52 PM   #56
wutnxt
Hey thanks guy's for all the support.....
Just called the machine shop and looks like everything is going in the right direction. Decided to have him do a freshen up...it's out...might as well do the bearings,hone it and replace all of the gaskets....cringes....it's only money
Old 05-11-2011, 09:22 PM   #57
chad64chevy
chad64chevy's Avatar
i just read the whole thread and have to say this truck is gonna be awesome!! you said something about painting it green and white then you got the bedsides from a green and white truck, thats funny!! i know what you mean about bondo, i had 1/4" - 3/4" bondo on the back corners of the bed on my truck and some spots up to an inch on the tailgate before hammered it out and cut it out!! i love the prostreet and pro tour looking trucks!! good job man keep it up!!
chad64chevy is offline   Reply With Quote
Old 05-11-2011, 09:38 PM   #58
wutnxt
Thanks for reading it all and giving me some feed back....everyone
Today's questions :
Trying to decide what to do with the tailgate .....considering blanking it out and putting a mural on it, but i really like the stock look too. I was thinking about leaving the chains on the tailgate for looks but weld them to make them look like they work and open but they move with the gate.Then put a remote lock on the inside for function. The way my fuel cell sits in the back and the way the floor in the box is all... bead rolled,once it's painted I can't see anything going back in there.
Then I need a 4" cowl hood....should i put a fiberglass one on a hood ?...I found a steel cowl piece we could put on.......but maybe we should make a cowl for the hood that has the factory lines in it ...use a old hood cut it out of the center graph it onto a good hood or bead roll it in?....I guess we could even bead roll in some flames or something.....
So many questions so many choices....any ideas or thoughts ?
Old 05-11-2011, 10:18 PM   #59
shortbed70
shortbed70's Avatar
Check my gate in signature. Last page shows a pic.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 05-11-2011, 10:52 PM   #60
chad64chevy
i like the factory v in the hoods!! i have a old hood i'm gonna cut up to make a cowl hood i'm only gonna go with a 2in.-2.5in. cowl but real wide like 3ft. something like the mustangs! i think it would fit the hood lines better then the z28 cowl! i've seen one with the factory v in the hood in classic truck mag. looks real nice, can't remember what issue i'll have to look!!
Old 05-11-2011, 11:11 PM   #61
wutnxt
I have to go 4" to get air to pass through the hood area and get the big block to let a little heat out. I haven't seen a cowl with the lines in it but i think it would look good.....but you never know until you actually get to see what it looks like....but the more i think about it...the more i like the idea....I would love to see the picture if you find it
Old 05-11-2011, 11:37 PM   #62
chad64chevy
http://www.classictrucks.com/feature...964/index.html i hope i'm doing this right! go to kevins keepsake it the blue truck! i hope this helps! i thought of doing this long before i seen it! i'm just learning as i go to fab. up the things on my truck! its hard to see but i hope you get the idea
Old 06-13-2011, 05:24 PM   #63
wutnxt
Well it's been a bad couple of weeks.....the body shop and i had a wee disagreement....and i pulled 3 trucks out of the shop and it went to some otherrrrrrr place...but it's on track now and i will get some new pictures soon
Old 06-13-2011, 06:21 PM   #64
chad64chevy
did you ever get to look at that thread i sent you about the hood scoop? i like that blue and white truck you did! big change! wish i still lived it cali, my brother says theres about 2-3 shortwides big and small windows he sees on his way to work that are just parted!
Old 06-13-2011, 06:24 PM   #65
Dinos63
chevy only
Dinos63's Avatar
brotha just read the hole thread ,thats slick how you did the bed killer work , and i am stoked to see your build !!! sucks about the bodyshop but shhhh-t happens
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 06-13-2011, 08:39 PM   #66
wutnxt
Chad...
Ya i checked it and we are getting close to putting it together the cowl hood now. Thanks for that link by the way.....and hey try living in Canada ....everything comes pre-rusted.
Dino
Ya ain't that the truth shhhhhht happens.. but it's how ya wipe up the mess that counts...back on track no looking back. Hey thanks for checking my build out...you have mad skills dude you do great work. If ya ever get up to canada bring your wrenches and I will buy the beer...lol
Old 06-17-2011, 04:02 PM   #67
wutnxt
Okay well
I know you all want picture updates but here is the new schedule..
- The tranny is completed they just called and it's ready to go ...Trans brake set up is all good to go .....just need to get the right torque converter.
-Engine will be ready to go for next week.....
-Front end is out and been reblasted....
-Frame has been blasted again
-Tossed the cab " groans " and had to take one of my other big back window cabs and send it for mock up
- it's all in a big pile sitting and waiting for mock up "again" so we can set the ride height up...we have a plan to use a air set up to make it drop down after thats completed I will send the frame and all the pieces out for powder coating.
Once we get some powder coating completed I will start posting some more pictures...
Old 06-21-2011, 10:53 PM   #68
wutnxt
okay not the best pictures.......
But we have really managed to get it down in the weeds.....so far the front horn on the frame is just under 5" off the ground.....Should look evil down low with those tires sticking out back.....what do you think ?
Old 06-22-2011, 10:04 AM   #69
CdM
CdM's Avatar
I cant believe im saying this but that is the best looking ford i have ever seen!!
Build Thread 66 custom cab lwb http://67-72chevytrucks.com/vboard/s...d.php?t=465726
66 fleet lwb- In process
64 k10 10inch lift 38.5's- In process
92k1500 400hp on 38.5-parts truck now 8(
CdM is offline   Reply With Quote
Old 06-22-2011, 10:10 AM   #70
wutnxt
CdM
Re Best looking ford you have ever seen.....
Hey I know friends don't let friends drive fords but to clarify.....that ford isn't mine...lol...it's my friends. But it's his company truck and they bought the gas to haul all my chevy parts and i have since converted him to a slammed body dragging 52 chevy truck.....lol
Old 06-22-2011, 01:23 PM   #71
shortbed70
shortbed70's Avatar
That thing is going to look sick!!!
Troy
Big Red Dog build
Old 06-23-2011, 01:51 AM   #72
CdM
CdM's Avatar
If it supplying parts for a chevy rebuild as nice as yours,
its ok in my book
Old 06-23-2011, 05:32 AM   #73
fryer1979
Redneck Hillbilly
fryer1979's Avatar
I love me a good pro-street build. Signing up for the adventure. I just had my first trip into Canada a month or so ago, went into Victoria by way of ferry from Seattle. Spent a couple days there, and I was actually suprised to see quite a bit more Classics on the road there than most places I go here in the US.....any idea why? Either way, I'm looking forward to a chance to go back into BC and have more time to look around, maybe by way of Vancouver this time. Cool build so far bud.
fryer1979 is offline   Reply With Quote
Old 06-24-2011, 11:32 AM   #74
wutnxt
fryer1979 Re: 1966 SBBW pro street
Hey thanks
I have never gone the ferry from seattle to victoria but heard it's nice. I have gone the vancouver to victoria ferry many times....For the amount of time it rains here we have a awsome car culture here, and if your here when it's sunny everyone drives what sits in the garage. So my guess is you hit a sunny day that everyone was waiting for.....lol
Old 06-24-2011, 12:14 PM   #75
wutnxt
Should have more pictures soon.....
Changed plans slightly,and after looking at the way the truck sits have decided to drop the body down another 3" on the chassis. It's not going to lay rocker or anything like that but it should sit down about 3" off the ground. The rear tires at that point are only a couple inches below the top of the box. So i plan to look around and see what ideas I can come up with to finish off the inside of the box today.....If I were to do this build again would i ever rethink some of the choices i have made so far.
