Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 08-02-2011, 11:44 AM   #51
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
Re: Bullet proof GM 12 bolt.
It all depends on how much money you want to spend. What you plan on doing with it and what lug pattern you want.
427 SBC 683HP & 590ftlbsTRQ @ fly wheel.
60'-1.38 1/4-10.43 MPH-124.6
New ET current 4/2019
AKA MEAN GREEN.
68 C-10 KID is offline   Reply With Quote
Old 08-02-2011, 12:05 PM   #52
nxtruck
nxtruck's Avatar
Wow Mike! That stinks. Were you launching with a trans-brake or off of the footbrake?
Chris
1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas
7.02 @ 95.8, 1.45 60'
1965 Chevy C10 LWB, 355 sbc, TH350, daily driver
nxtruck is offline   Reply With Quote
Old 08-02-2011, 02:38 PM   #53
68 C-10 KID
Mean Green
Chris that was trans brake launch @3600 RPM with 11 psi in tires.
AKA MEAN GREEN.
Old 08-02-2011, 04:16 PM   #54
nxtruck
nxtruck's Avatar
Well, at least it was hooking!! Seriously though, I hope you get it put back together quickly so that you can thrash that new combo some more before the end of the year.
Chris
Old 07-25-2014, 10:58 AM   #55
70blackfish
whatever happen to this truck? was it ok??
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 07-25-2014, 12:40 PM   #56
68 C-10 KID
Mean Green
Everything is great. I hade the tubes welded up. Installed moser axles studs for main caps. It's lived far. I have even turned off 2 step and launched at 4600 and the thing lives.
AKA MEAN GREEN.
Old 07-26-2014, 12:13 PM   #57
BossHogg69
motor exploder
BossHogg69's Avatar
I don't know if mine will be bulletproof or not but here's the setup on my yet to be driven '69 C10 w/12 bolt rear:
Moser #7950 Ford Housing ends (bye bye c-clips)
Moser 30 spline axles
Moser aluminum diff cover
Detroit Truetrac diff
Richmond 3.73's
Welded axle tubes to the center section
1350 Pinion yoke
given my luck, it will probably explode backing out of the driveway on it's maiden voyage...
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 07-26-2014, 05:41 PM   #58
68 C-10 KID
Mean Green
That sound like my luck.
AKA MEAN GREEN.
Old 12-14-2014, 02:26 AM   #59
!970C10540
Originally Posted by djracer View Post
I personally don't understand why anyone would run anything other than a 9 inch in a street or strip ride.
Because a true Chevy Man will never run afford product like a rear end, transmission, or a motor from a lowly ford the bestt thing they make is electric fans. 12 bolts are superior to 9inches and Dana 60s for the fact that they have less parasitic power lose than the two off brands.
!970C10540 is offline   Reply With Quote
Old 12-15-2014, 09:34 AM   #60
regan wilson
regan wilson's Avatar
I will let you build me one and we will see how long it takes me to make spaghetti out of it.
NHRA Super Street 469C
It only runs 10.90 at 156 mph
regan wilson is offline   Reply With Quote
Old 12-15-2014, 09:44 PM   #61
Marv D
Registered Truck Offender
Marv D's Avatar
Yup,, I gotta agree with Regan 1000%.
I bleed CHevy Orange! But Anything I own that is faster than a 11 second street toy has a bit more beef to it than a 12bolt. But honestly it may be 'based' on the 9",,,, but does not have one single 'ford' part to it.
So does that make it OK??? LOL
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 12-16-2014, 12:07 AM   #62
71Dragtruck
71Dragtruck's Avatar
I wasted time and money beefing up my 12 bolt, once it went into the low 11's it ate parts, now its a Fab 9, like Marv said same applies, not a Ford part in it.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 12-16-2014, 01:00 AM   #63
Ozzy2013
Ozzy2013's Avatar
Are the GMC dana 44 rears any good?My 68 has a dana44
Ozzy2013 is offline   Reply With Quote
Old 12-17-2014, 12:33 PM   #64
Marv D
Marv D's Avatar
Richmond 3.73's
1350 Pinion yoke
Think of this all as an endurance test and a question of what IS the next weakest link.
Here's a set of Strange 31 spline axles that came out of the truck when it was dead hooking and only 580HP
Old 12-17-2014, 06:49 PM   #65
regan wilson
Dang Marv that is ugly. It almost looks like it could have been a bad forging. Knock on wood but my old heavy a** Dana 60 has probably 1000 passes on it. I've knocked three sets of gears out of it but it still has the same 40 spline Mark Williams axles in it.
Old 12-17-2014, 08:40 PM   #66
hotrod 80
mini truck racer
hotrod 80's Avatar
If your dead set on GM parts . Take a late model 2500 van Dana 60 semi float and ad ford style ends with wedding ring style bearings and a 35 spline center . Narrow it to fit and weld on perches at the needed pinion angle Should be good to go .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 12-18-2014, 11:40 AM   #67
Wasted Income
Boosted Member
Wasted Income's Avatar
There is no set rule to how fast is "too fast" for a 12 bolt.
71Dragtruck was having problems at low 11s. Mine has made some low 11 sec passes at the track, and is beat on the street like a mouthy hooker at least 3-4 times per week, and as of right now it's holding up.
I'd have to assume that even though my truck is 4500 lbs race weight, my power is applied a lot less violently and I can thank that for a working rear axle.
Stock 12 bolt truck housing, stock 40+ year old axle shafts, auburn LSD, Yukon Gears, and a forged 4340 yoke.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 12-18-2014, 06:01 PM   #68
hotrod 80
mini truck racer
hotrod 80's Avatar
Another important question .... What trans ? Is this a foot brake truck ? Trans brake ? I leave at 4000 of the brake . In a fullsize this would require a substainial rear axle . Footbraking at 2500 would be alot easier on parts
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 12-19-2014, 10:08 AM   #69
Wasted Income
Boosted Member
If you're asking me, it's a 4L80E, with a 3600 stall, footbrake on the 2 step to build boost, leaving at about 7 psi.
I agree, there are a lot of variables that affect the longevity of a rear axle, with weight and shock load at the go the two biggest.
Mine is heavy, but leaves soft compared to you guys.
Turbo diesel
Old 01-03-2015, 04:46 PM   #70
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
I bought a moser 35 spline bolt in unit. And yes it bolted right up no issues.
I know the 12 bolt guys love to tell you how great they work and it only broke once .. But if you add up the cost to build it once and the fix it you could have bought a much stronger rear diff unit.
I have run 12 bolts and have had decent luck broke some others I did not. But I hate doing stuff twice. Lifetime warranty of the wave trac unit rated to handle 1500+ and cost was not to bad I do not recall the price but look it up on the site.
I leave now at 3750 on the cushion ( it will go 4100 on the vert) on the brake and hit the first gun for 100 ( tuning) dead out the hole and the next kit is coming on shortly after
GMR-PERFORMANCE is offline   Reply With Quote
Old 01-05-2015, 10:50 AM   #71
Wasted Income
Boosted Member
I lust after a moser bolt-in 9" setup for my rig.
When my 12 bolt finally bites it, there's no question that's what is going back in it's place.
Turbo diesel
Old 01-05-2015, 11:58 AM   #72
GMR-PERFORMANCE
I can say that I really like the simple set up with mine and knowing that it is overkill for my set up. No big deal if I really build a 1000+ engine. In the event I ever sell it maybe the next guy is the LS twin 72 MM type. No big deal easy to go pretty far with the unit. I have a muscle kit the fab 9 housing is larger in my case I think it would have hit the fuel tank , and I would have had to start over with moving things around.
I love the vid of the 5.3 with a little convertor and some gear mad street truck. Not to say its not moving I am more into the snap your neck when I turn it loose type guy HA HA
Old 01-05-2015, 10:18 PM   #73
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
anyone running this bolt in 9" setup from Speedway? I'm wondering if 62" is too wide...considering I want to mini tub my truck so I can run my 315/60-15 d/r's or similar/wider and get them up inside the fender. anyway.....would this $425 housing be a tough enough setup w/o going the fab9/etc route? Looks like the axle tubes are already welded? Axle length? it doesn't mention.
http://www.speedwaymotors.com/Bolt-I...cks,80935.html
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 01-05-2015, 10:29 PM   #74
68GMCCustom
I hear about Winters quick changes quite a bit....how tough are they?
is this a deal with disc brakes, a spool, and 4.86 gears for $1800 complete?
http://www.speedwaymotors.com/Winter...-End,8517.html
Kurt -
Old 01-06-2015, 12:35 AM   #75
Captainfab
60-66 Nut
A WMS to WMS of 62" is the width of a stock truck 12 bolt from '63 to early '70.
