09-09-2012, 10:03 AM | #51 |
Re: Maybellene 52 gmc
09-09-2012, 11:00 AM | #52 |
Thanks, it is a working truck and brakes down les than a lot of the newer ones. But like out smaller trucks it is constantly upgraded
09-11-2012, 07:22 PM | #53 |
after i got as far as i wanted {for now} to on the suspention i decided to fix the cab floor before my tubing became somthing else for the second time
mr 48chevy was kind enough to post the stock dementions for the front cab mounts. So Idid some measuring and shimming to get the cab wehr it is supposed to be. then I made a simple frame out of scrap 1" square tubing that used holes that were already in the cab. At the bottom of each leg I welded a piece of angle iron witha hole and anut welded toit for adjustment. On the lower lege I tacked a short piece of .5 tube to the seam at the bottom of the toe board. |
09-11-2012, 08:15 PM | #54 |
now the floor from the seat riser to the toe board could be cut out.I marked and cut about a 1/2 inch in front of the seat riser and just inside the rocker panel flanges then stright down at the floor were it meets the toe board.
next I cut out the cab mounts out. the floor at the rocker panelstuerned out to be a bit tougher than I thought at first, it turned out that the guy at the factory ran two to three spot welds together. So drilling wouldnt work.I ended up useing a 1/8" wide cutoff wheel but first I used the 4" sander at a 45degree angle on the 90degree brake where the molding goes for the windlace. |
11-08-2012, 11:24 PM | #55 |
Haven't seen a post for a while. You getting anything done? BTW that Pontiac looks good.
56 Chevy PU http://67-72chevytrucks.com/vboard/s...d.php?t=531955 Question: Know how to sell your truck for $50,000? Answer: Spend $100,000 building it. |
11-08-2012, 11:53 PM | #56 | |
I have a soft spot for those old pontiacs |
06-10-2013, 03:44 PM | #57 |
yawn... see mknittle's post above from last yr
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer Last edited by _Ogre; 06-10-2013 at 04:08 PM. |
06-11-2013, 08:44 AM | #58 |
OK I will try to get some pics up this afternoon
06-11-2013, 08:46 AM | #59 |
I have been meaning to post some but life got in the way
08-03-2014, 08:19 AM | #60 |
another year, no posts
11-17-2014, 11:01 PM | #61 |
Looks like a cool build. Any more progress?
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
