12-17-2013, 11:22 AM | #51 |
Re: 64 C10 Stepside "Jaybird"
Progress looks great. Thanks for the update on the sheet metal.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
12-17-2013, 08:30 PM | #52 | |
Thanks whippinsaw. Got my Roloc and some 36 grit discs in the mail today. Ordered it from Amazon while I was buying some of my wifes xmas presents. Somehow she still found out. LOL! Now I need a 90* Die grinder. Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955 |
12-18-2013, 09:22 AM | #53 |
little late reading up on your build but it looks like you're doing a great job. glad to see you put those beautiful www's away while doing the body work. sure don't want them messed up.
we're heading to south texas for christmas. have family in comfort, tx and it will hopefully be a little warmer there. hope you guys have a nice holiday and you can find some time for your truck. |
12-18-2013, 10:28 AM | #54 |
JYBIRD, i am really liking those wheels......
12-19-2013, 09:34 AM | #55 | |
Thanks Bret
01-02-2014, 08:04 PM | #56 |
Some progress. I pulled the engine and trans today with one of my new toys I mean tools I got for Xmas. I was going to pull them together have never done it before, but with the bell housing cross member still there I didn't think the trans would clear it with the engine on. So I pulled them separate.
The engine stand I'm using belonged to my Grandpa. He used to build them and sell them back in the early 70's at his shop. I have a cool photo of when he was making them. It has sat outside for many years at my dads place but I plan to blast it and repaint it. Another PO folly it looks like there is no oil pan gasket just RTV. Unless it was leaking all over and RTV was after it was assembled. Thanks for looking. Bret
01-02-2014, 09:52 PM | #57 |
I'm just glad to be here!
Nice looking stand!
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
01-02-2014, 10:27 PM | #58 |
Post Whore
AWW! I wish I had you shop!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
01-03-2014, 08:40 AM | #59 |
really like that old engine stand... hmmmm, i need to make one. its cool yours has family history and part of the cool factor is the wear. i'm one of those guys that typically restores everything but some stuff is best left as is. that thing is...
you got a great shop and some other interesting projects. |
01-03-2014, 04:50 PM | #60 | |
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
01-03-2014, 09:50 PM | #61 | |
Thank You. I have built quite a few engines on this stand.
Thank you TJ. I feel blessed to have a big space inside to work and keep all my junk and cars. I wish my father in law could have enjoyed though. Quote:
And yes my projects span different decades. The 79' Caprice is my first car and I have had it for 19 years. My parents bought it new. It has come along way from the 130hp 305 and 2.41 gears it came with from the factory. I plan to get it back roadworthy someday. LOL. The Camaro is my daily driver and the covered car is the 72' Cutlass. Thanks I went out to the garage tonight after work as I was dying to crack open the 350 and see if the PO owner did things right. After I removed all the bolts from the oil pan I realized they didn't use a gasket just RTV! Also I think this pan is from the original 283 with the drain plug in the bottom. Much to my surprise there was windage tray installed and it is a 4 bolt main. Finally something done right. I pulled the front cap and the bearings look good as well. Not sure if the crank is forged or cast. This puzzled me it appears there is RTV between the oil pump and the rear main. Not sure why. I don't recall ever doing this on any of the engines I built. If you look real close you can see the 4 bolt mains. Its starting to get bare. Can't wait to get the cab repaired and off the frame. Bret
01-05-2014, 01:15 PM | #62 |
Post Whore
350 looks to be in darn fair shape! I'm afraid to see what mine is gonna look like.
01-12-2014, 10:01 PM | #63 |
Well after having my new Air compressor for a month I finally got to see what it could do today. Spent about 6 hours sandblasting. It didn't even skip a beat. I can sandblast till my body hurts. Which it does tonight.
I got quite a few parts done. Not much but some progress. Both cowl pieces, all the gauge cluster parts, 1 radiator cover, radiator bracket, and the hood latch. And a quick coat of primer. It was awesome weather today for sandblasting. Overcast and 64* Tomorrow's plan more sandblasting. Bret
01-20-2014, 09:38 AM | #64 |
Not much done on the truck. Had to reset the garage as it was a mess with stuff laying everywhere. I had 6 rolls of insulation for the walls that has been in my way so I decided to finish the wiring on the back wall and hang all the insulation.
I also got a new air regulator/filter from HF. I paid $28 for it with my ITC membership and 25% off coupon. So far it works great. I didn't hard line it yet as I would have to redo it so I hooked it up with an old hose for now. I love the regulator on this it works so smooth. Bret
01-20-2014, 12:32 PM | #65 |
Post Whore
Always good to keep yer garage organized.
01-21-2014, 01:48 AM | #66 |
I just found your thread and I have to say Great work.
How are the patch panels coming along? |
01-21-2014, 07:38 AM | #67 | |
Thanks T.J>
Bret
01-23-2014, 09:00 PM | #68 | |
02-23-2014, 09:01 AM | #69 |
Well I have mostly been sandblasting and priming. The last 3 days I have spent replacing the oil pan gasket on my 02 Camaro. What fun that was. And after all of that work it is still leaking oil above the starter. So either the rear main is leaking or the OSPU.
My makeshift sandblasting booth Oil pan from Camaro Here you can see the K member is hanging down about 6" so I could get the pan on and off. This required unbolting a lot of things. I think the entire job took me about 16 hours. Bret
02-25-2014, 12:58 PM | #70 |
Your shop is looking good, I like your makeshift sandblasting booth. Do you just leave the one side open? I am going to make one and was wondering how well it worked.Thanks <W>
1963 Fleet Side cab, Converted Fleet Side Barden bumper, Step Side in the middle. |
02-26-2014, 07:57 AM | #71 | |
One good thing about the one side being open is you can sandblast bigger stuff such as a radiator support and bumpers. I generally blast for about 10-15 minutes before my pot runs out of media and it takes me about 20-30 minutes to pickup all the sand and sift and get the pot ready to go again. It works out because it gives my Air Compressor a chance to rest. Bret
02-26-2014, 02:54 PM | #72 |
I have an ATV Tent I plan on repurposing into a blast tent when I get it home and get settled.
I wish I had seen this sooner though, as a temp set up, this would be awesome !!
02-27-2014, 11:25 AM | #73 | |
Bret
02-27-2014, 04:12 PM | #74 | |
I had kind of envisioned a "Dexter" room with painters plastic inside the tent with some ventilation to suck or blow out the dust. I have a vacuum cleaner set up on my blast cabinet that does this and it works great.
02-28-2014, 12:45 PM | #75 |
Good progress and tool collection Brett.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
