Old 03-10-2014, 09:11 PM   #51
Spblack
Spblack's Avatar
Re: 1959 fleetside build
tire clears the air bag...whew...might fab something up to prevent a blowout from hitting my bag.
1959 Chevy Apache (sold)
1958 Fleetside Current
My builds:
http://67-72chevytrucks.com/vboard/s...d.php?t=606412
http://67-72chevytrucks.com/vboard/s...=1#post7560906
Spblack is offline   Reply With Quote
Old 03-10-2014, 09:43 PM   #52
pbeguy
pbeguy's Avatar
It is coming together great.
Rather than fabbing a shield, keep a spare bag with you. You will be jacking it up to change the tire anyway...
Get some of the cheap center bullets ($4) and cone lugs from Summit to dress it up.
pbeguy is offline   Reply With Quote
Old 03-11-2014, 01:24 AM   #53
Ratpin
Ratpin's Avatar
Did you shave the tires or do you have a shop that offers the shaving service? No local shops will do it for me.
Ratpin is offline   Reply With Quote
Old 03-11-2014, 10:19 AM   #54
Kim57
Kim57's Avatar
Looks real slick.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 03-11-2014, 11:09 AM   #55
dubie
dubie's Avatar
I'm Lovin' it!!
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 03-11-2014, 01:25 PM   #56
Spblack
Spblack's Avatar
thanks guys,tomorrow I am going put the motor and trans in it. hopefully everything fits.
after that, ill throw the front clip on to make sure everything sits right, maybe even the bed.
My builds:
Old 03-13-2014, 06:33 PM   #57
Spblack
Spblack's Avatar
Ran across a problem today while installing the 5.3 motor and trans. the motor mounts didn't line up with existing rubber mounts. after beating my head for a few hours, I decided to go get new rubber mounts and clam shell brackts. as you can see in the photos, im about an inch off on the drivers side hole. after I got the new mounts, everything lined up. I don't know what mounts were on there before, but they were not 350. now I just have to figure out the alignment of the trans since im going with a 4l60e...any tips would help...
passenger side
driver side
with new mounts
decided to throw the front clip on there.
I bought a muscle performance oil pan from summit. it sits an inch below my subframe. not sure if I like how low it is with all the air out.
so...any tips on lining up that trans. I bought a universal crossmember, but not quite sure the right angle the motor and trans should sit with the axle.
My builds:
Old 03-13-2014, 11:03 PM   #58
Kim57
Kim57's Avatar
Looking good.
The pan looks a little low for my taste.
I ended up raising my engine up so my pan wouldn't be below my cross member.
Kim
My build thread
Old 03-13-2014, 11:12 PM   #59
Spblack
Spblack's Avatar
Originally Posted by Kim57 View Post
Looking good.
Kim
yeah, that's all the way down. Im thinking about some different motor mounts to raise it some. are you running the same setup?
My builds:
Old 03-14-2014, 09:57 AM   #60
Kim57
Kim57's Avatar
No.
I have a 67 Chevelle clip on mine without bags. I also used the Cadillac CTS-V pan.
I don't think it hangs as low as yours does.
This page has the dimensions of different pans for the LS.
http://ls1tech.com/forums/conversion...-oil-pans.html
Kim
My build thread
Old 03-15-2014, 12:34 PM   #61
made2drag
made2drag's Avatar
awesome build!
made2drag is offline   Reply With Quote
Old 03-18-2014, 09:53 PM   #62
Spblack
Spblack's Avatar
chrome ididit steering column came in along with firewall brake booster and hooker headers. had to throw the bed on the truck to get an idea on what it looked like, it was killing me..
front clip,cab, and bed are just laying on there to see how it all flows.
I need a shop. my garage is really killing my motivation.
My builds:
Old 03-18-2014, 10:28 PM   #63
LSXapache
LSXapache's Avatar
I used universal motor mounts from speedway but the engine ended up roughly in the same place as if I'd used clamshell mounts(oh well didn't know before hand). My 4l60e just barely kissed the trans inspection hole opening so I had to trim a minute amount there also using the 4 speed trans cover which has a hump that helps clear the 4l60e. For the time being I modded the original Camaro trans mount to work, I'll build some thing nicer after its driving and all the kinks are worked out. Also an f body oil pan will cure your low hanging oil pan problems.
LSXapache is offline   Reply With Quote
Old 03-18-2014, 11:31 PM   #64
Kim57
Kim57's Avatar
Looks good.
Kim
My build thread
Old 03-19-2014, 12:24 PM   #65
dubie
dubie's Avatar
MAN this truck is KILLER!!!
Old 03-24-2014, 07:02 AM   #66
Spblack
Spblack's Avatar
started fabbing up the raised bed floor and fuel cell mounting.
My builds:
Old 03-24-2014, 07:27 AM   #67
98Murray
98Murray's Avatar
Super nice truck!
98Murray is offline   Reply With Quote
Old 03-24-2014, 08:38 AM   #68
Kim57
Kim57's Avatar
Looks good.
Kim
My build thread
Old 03-26-2014, 09:13 PM   #69
Spblack
Spblack's Avatar
had a little time today to get the fuel cell mount almost done. im gonna pick up some strapping material from home depot tomorrow and finish it. heres my mount
I added angle brackets to the side to keep it from shifting side to side.
https://flic.kr/p/mtpQpa
https://flic.kr/p/mtpQRT
My builds:
Old 03-26-2014, 09:20 PM   #70
Spblack
Spblack's Avatar
anyone know whats going on with flickr? I cant find the bbc code to share now.
My builds:
Old 03-26-2014, 09:23 PM   #71
Spblack
Spblack's Avatar
side mounts
My builds:
Old 03-26-2014, 11:42 PM   #72
Kim57
Kim57's Avatar
Looks good.
Kim
My build thread
Old 04-02-2014, 10:23 PM   #73
Spblack
Spblack's Avatar
thanks kim,
heres where I am at now. deciding the route to take for hinges for the center of the bed to open up so I have access to fuel cell and air ride management system.
My builds:
Old 04-03-2014, 07:19 AM   #74
dubie
dubie's Avatar
Nice frame set up man. This is one cool build! I love the idea of a hinged floor
Old 04-03-2014, 09:40 AM   #75
Spblack
Spblack's Avatar
thanks dubie,
cant wait to see your truck painted. when you gonna have that finished?
My builds:
