Old 06-16-2014, 04:05 PM   #51
Hendo
Re: Project "Blackbeard" 69 C-10
I was able to get the bed floor raised up 10". Looks good and wasn't as hard as I thought it would be to get done. My Porterbuilt hood hinges showed up and I was able to get them mostly installed. I want a drop member up front so bad but it will have to wait for the phase 2 build. Funds are a little tight.
Hendo is offline   Reply With Quote
Old 06-16-2014, 04:39 PM   #52
nlped
nlped's Avatar
Cool truck! Subscribed
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 06-18-2014, 08:09 PM   #53
Hendo
So today I was able to get the hinges painted and installed along with the hood. Looks good! I was surprised Porterbuilt doesn't supply directions for the installation. Thankfully there was a great article on this site giving a step by step. If you get these hinges do not go at the install alone. There are some crucial steps that you don't want to miss. I will say the hinges work and look great. They are worth the money. I also received my watts link for the rear in the mail. I forgot to take a photo of that.
Old 06-18-2014, 11:54 PM   #54
abraham.hd
Really like the patina on this truck, keep up the good work
abraham.hd is offline   Reply With Quote
Old 06-19-2014, 12:08 AM   #55
Hendo
Thanks Abe! Ya the patina is what I love the most about the truck. It's pretty unique. I haven't sen many C10 with the black and white patina around.
Old 06-20-2014, 09:17 PM   #56
Hendo
My watts link is in and the rear suspension is all tacked in. Tomorrow I am going to finish the welding. Post more pics tomorrow.
Old 06-22-2014, 06:03 PM   #57
Hendo
Did a whole lot of welding yesterday and today. I will drop the ass end out tomorrow and grind smooth all my ugly welds in preparation for paint. Still need to make some mounts for the air tanks and put in the rear frame bed mounts. I love progress!
Old 06-23-2014, 09:21 AM   #58
bodydropped68
bodydropped68's Avatar
looking good
bodydropped68 is offline   Reply With Quote
Old 06-23-2014, 09:24 AM   #59
Bennett68C10
Bennett68C10's Avatar
Nice job on the rear suspension. Looks really good.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 06-23-2014, 09:22 PM   #60
Hendo
Got the rear frame completely welded and painted today. Lots of work grinding and prepping but it was worth the effort. I want to run my airlines with this copper tubing. What do you guys think?
Old 06-23-2014, 09:26 PM   #61
Hendo
Bodydropped and Bennett thanks for the kind words. This is my first build and I think it is going well so far. It's amazing how much you learn as you go. A lot of times the hard way! lol
Old 06-24-2014, 07:56 AM   #62
mcbassin
Still Learning
mcbassin's Avatar
Very nice progress on the suspension. I'm not sure about the copper lines? I'm thinking it would work fine as long as you have cushioned mounts to keep it from rubbing. I don't think I've seen anyone running it on here.
mcbassin is offline   Reply With Quote
Old 06-24-2014, 08:01 AM   #63
lolife99
67-72 parts collector,…
lolife99's Avatar
Personally I would run DOT air line.
People HAVE run copper,... but it "work-hardens" with vibration.
Use quality fittings and air line with Loctite 545 on the pipe threads for a leak free installation.
Keith
Convert to disc brakes.
Old 06-24-2014, 08:53 AM   #64
Hendo
Thanks for the input. I have also seen people run alloy lines. Would there be any difference between the two? I just like the clean look and tight area of the hard lines. It is going to be a driver truck so if dot is better in the long run then that is what I will go with.
Old 06-27-2014, 07:17 PM   #65
Hendo
Been busting ass on the project lately. Rear end seals and drum brakes replaced. Everything painted and installed in the rear. I will install the air tanks, valves, bags, and shocks tomorrow. Hope to be able to run the air lines too.
Old 06-30-2014, 11:25 PM   #66
Hendo
Today I was able to install a few items and run a couple air lines.
Old 07-01-2014, 03:26 PM   #67
808_67C10
808_67C10's Avatar
Still love this truck! Keep the pics coming...
Frank (Hilo, Hawaii)
Trucks, Tacos, and Beer go together like Peanut Butter and Ladies!
85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383
67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298
79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461
808_67C10 is offline   Reply With Quote
Old 07-08-2014, 02:51 PM   #68
Hendo
I have all my air lines ran now and have moved to the wiring of the valves. Tanks and water traps are in. Tomorrow I want to test the airbag system and see if it works well as well as check for leaks.
Old 07-08-2014, 04:02 PM   #69
mikeleeshields
mikeleeshields's Avatar
Looking great. Keep up the good work.
1970 SWB Got My PB Suspension It's On Now- 1970 SWB - Porterbuilt to the Extreme
Mike
mikeleeshields is offline   Reply With Quote
Old 07-08-2014, 05:14 PM   #70
lolife99
lolife99's Avatar
looks great!!!
Keith
Old 07-21-2014, 06:46 PM   #71
Hendo
I was able to run all my fuel lines from the tank to the carb. I custom bent tube from the carb down to the pump and moved the filter to below the pump. I also mounted the brake master cylinder and started on bending in the brake lines. All air bag lines are done and the switches wired to the switch box. Truck is coming along pretty smooth. I hope to be driving it in a month or less.
Old 07-21-2014, 06:48 PM   #72
Hendo
More pics.
Old 07-22-2014, 08:54 PM   #73
invicta455
Sweet
invicta455 is offline   Reply With Quote
Old 07-22-2014, 10:09 PM   #74
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Looks good...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 07-25-2014, 09:46 AM   #75
Hendo
Got the front end on and did a couple small things like install the overflow and power steering canisters. I am waiting on a box from Jegs that contains my brake lines. Also my wiring harness is on its way.
