Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 03-06-2014, 08:31 AM   #51
ryanroo
ryanroo's Avatar
Re: Making an engine stand, the overkill way
the usual load is .035. i run .045 for some things at work, but for some reason my machine likes the smaller wire. it is an inverter power source that will make plenty of voltage, but something about it just welds cleaner with .035. at home i run .035 too. the MM250 will do it with 045 but i dont work on anything that needs that big of filler at home.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 03-06-2014, 09:39 PM   #52
ryanroo
ryanroo's Avatar
this box of beef showed up today. 32 lbs of casters. 5600 pounds of capacity between the four. i think it will do!
hopefully i can get a finished and loaded pic this weekend. im getting antsy to hang an engine off of it.
72 K20 12v build
Old 03-08-2014, 07:40 PM   #53
ryanroo
ryanroo's Avatar
so, i painted it and re-assembled it.
then i pulled the engine and mounted it up to the stand. very anticlimactic. i didnt see much if any deflection when the hoist sat it down.
it rolls like a dream and turns over with almost no effort.
Ronnie, this is how the rear main housing is accessible.
72 K20 12v build
Old 03-08-2014, 09:09 PM   #54
jbclassix
Junk Yartist
jbclassix's Avatar
what's with the matching pieces laying by the torque converter? Are they part of another adapter? This thing looks amazing! It makes the engine look small!
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 03-09-2014, 11:35 AM   #55
Ronnie the Wrench
Ronnie the Wrench's Avatar
We'll thought out. I'll show the guys in the morning. If you you need parts or specs or help let us know. We would be happy to help.
Ronnie the Wrench is offline   Reply With Quote
Old 03-09-2014, 11:57 AM   #56
ryanroo
ryanroo's Avatar
If you look closely at the pictures, you can see my failure.... i tacked that square tube in when i welded it to help with the weld associated draw. then i just decided to leave it. it wasnt planned for when i designed it for the reason i had to cut it back out. it made it impossible to get close to the engine hanging from the hoist. one of those, D'oh, moments... hahaha. i had spare pink for touch ups thankfully
Thank you sir! i may pick your brain one of these days! i will start tearing it down for new seals and gaskets, maybe today. i need to get some containers to organize it all as i pull it down.
72 K20 12v build
Old 03-10-2014, 09:10 AM   #57
ERASER5
ERASER5's Avatar
Cough coughpink caugh.
" It takes a big man to use pink. and an even bigger man to point at that man and laugh." ~ John Handy SNL
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 03-10-2014, 03:53 PM   #58
swamp rat
swamp rat's Avatar
I gotta admit i was expecting some killer custom paint airbrushing or flames, after all your skill set up to now has been unparallelled.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-10-2014, 09:01 PM   #59
ryanroo
ryanroo's Avatar
Haha, now that is funny!
72 K20 12v build
Old 03-10-2014, 09:05 PM   #60
ryanroo
ryanroo's Avatar
i wont claim to be un-artistic. there is a lot of what i think of as art in the fabwork i do, but paint... uh-uh. I can try to spray paint, never with any kind of consistency, but anything artistic will look a bit like I was having a seizure instead of actually trying my best...
72 K20 12v build
Old 03-11-2014, 02:34 PM   #61
Lemield
Lemield's Avatar
Wow! That is the nicest engine stand I've ever seen.....I have one that my Dad built that is huge and heavy and has an extra long middle leg....but yours is really nice! Great work!
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 11-25-2015, 06:36 PM   #62
garmar
garmar's Avatar
That bad boy looks like it could cantilever an entire car. Nice work!
garmar is offline   Reply With Quote
Old 11-25-2015, 08:06 PM   #63
truckster
truckster's Avatar
Wow, nice fabrication work!
What's with the pink primer, and what color are you planning on covering it with?
Just kidding. It looks really good.
truckster is offline   Reply With Quote
Old 12-04-2015, 11:11 AM   #64
drfloyd
That's the only 4 digit(likely 5 depending on how you value your time) engine stand I've ever had the pleasure of seeing. Really nice work. I have to ask, why the cutouts for the casters? Is that just aesthetic or is it to lower the center of gravity. Just curious. Nice piece. Did you buff it out before you mounted the motor up? Haha!
drfloyd is offline   Reply With Quote
