Old 03-26-2014, 10:53 AM   #51
dman1982
dman1982's Avatar
Re: 5.3 swap build so far
No, the weather was horrible yesterday...I'm gonna get at it after lunch
Sgt Dennis Heineman
USMC Aviation Ordnance
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
2009 Troy Built with a 42 Inch Deck
My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371
dman1982 is offline   Reply With Quote
Old 03-26-2014, 05:36 PM   #52
dman1982
dman1982's Avatar
Fuel system pretty much done...
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-26-2014, 05:37 PM   #53
dman1982
dman1982's Avatar
2nd pic
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-26-2014, 05:39 PM   #54
dman1982
dman1982's Avatar
I don't know why I was so worried about it...wasn't too bad to do once I did it
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-26-2014, 05:40 PM   #55
dman1982
dman1982's Avatar
It's not all the way in yet...just mocked up for the most part
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-26-2014, 09:08 PM   #56
mattcrp1
mattcrp1's Avatar
Thats looking great! I am hoping to have mine done soon also. I like the hose wraping of the line.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 03-26-2014, 09:40 PM   #57
dman1982
dman1982's Avatar
Making some progress
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-26-2014, 09:42 PM   #58
dman1982
dman1982's Avatar
Thanks man...had to swap over my valve covers, glad ls1nova pointed it out...getting pretty excited
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-26-2014, 10:12 PM   #59
ls1nova71
ls1nova71's Avatar
Originally Posted by dman1982 View Post
2nd pic
If you're just going to clamp a hose on the filter, I would shove the hose over the flared part and then put a clamp on it, it will be a little tough to do, but it would be a more solid connection. Also, what's the blue thing on the output side of the filter? Looks like a quick disconnect tool?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 03-26-2014, 10:17 PM   #60
truckdude239
truckdude239's Avatar
Yea push the return hose on pass the barb there also shouldnt ge anything sticking out the otther side like that
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 03-26-2014, 10:26 PM   #61
dman1982
dman1982's Avatar
its was the return line, thats why i didn't put it on over the lip, its actually kinda a temp thing anyhow....
on to the next objective...that blue thing is a quick connect, i got it in a fuel line kit i bought a company a member suggested on here...pretty easy setup, i did have to go get a couple things since i went mostly quick connect...the only thing i didn't like about the kit was that it didn't come with two male connectors, that would have been good for a couple things on here...with the spot where i have the hose clamp I'm going to put another quick connect on there...i wasn't rushing but want to see how it would fit up there and how it would be around the exhaust, i do have the nylon hose covered with hose to help protect if from the heat...im also kinda paranoid about the lines so I'm going to wrap the exhaust back some so i don't have to worry about it
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-26-2014, 10:27 PM   #62
dman1982
dman1982's Avatar
i would have tried to get that over that barb but had hard enough time getting it to that point...even with hot water and spit
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-26-2014, 10:29 PM   #63
dman1982
dman1982's Avatar
swapping those valve covers around looks a lot better man....thanks for the correction...looks a lot better with the oil cap on there correctly
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-26-2014, 10:53 PM   #64
ls1nova71
ls1nova71's Avatar
Do you have a 5/16 quick connect you could put on the return? Also, not sure what you mean by the two male connectors? And the blue thing on the output of the filter, the filter has a retainer in it, you shouldn't need anything else.
Old 03-26-2014, 11:02 PM   #65
dman1982
dman1982's Avatar
i see...thats probably why it was such a pain in the butt to get out when i put it on....im actually worried about that...i may have to get a new filter...i bent one of the do dads in there when i pulled it out...i was able to bend it back, but still worried a bit
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-01-2014, 10:40 PM   #66
dman1982
dman1982's Avatar
Just need a quick little weld, and gas pedal is done
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-02-2014, 09:34 AM   #67
mattcrp1
mattcrp1's Avatar
Great progress, I totally agree with you on the lack of male connectors for these nylon fuel line kits. I am trying to make some male fittings with cut off fuel filter ends in both 3/8 and 5/16, and installing them in the compression fittings.
I have seen some kind of thermowraping for fuel lines on OE vehicles I am sure some product of exists. I am thinking of running a heat shield over my exhaust as it passes by the fuel lines.
IG mattcrp1
Old 04-02-2014, 10:06 AM   #68
desertdogg
desertdogg's Avatar
I thought you had a DBW ? did I miss something ?
Trying to get thru my LS swap
desertdogg is offline   Reply With Quote
Old 04-02-2014, 10:21 AM   #69
littlevictories
looks like a dbw pedal to me
littlevictories is offline   Reply With Quote
Old 04-02-2014, 10:31 AM   #70
desertdogg
desertdogg's Avatar
wow looks alot different than the one I have mine is all plastic looking
Old 04-02-2014, 10:37 AM   #71
ls1nova71
ls1nova71's Avatar
That would be a 2006-up pedal, the older ones were metal.
Old 04-02-2014, 11:43 AM   #72
dman1982
dman1982's Avatar
ya is what i ended up doing was cutting a few male ends off of some hardline and getting them welded, kinda sucks cause those things are expensive, but its cool, i got it I'm hoping to have the harness in today
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-02-2014, 11:44 AM   #73
dman1982
dman1982's Avatar
if it isn't a DBW then i have no idea what I'm going to do with that electrical bung up on top!!!
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-02-2014, 12:13 PM   #74
dman1982
dman1982's Avatar
Well gents that's what my pedals look like in there
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 04-02-2014, 12:14 PM   #75
dman1982
dman1982's Avatar
Kinda looks like Chevy put it in there lol
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
