Old 03-05-2014, 03:32 PM   #1
dman1982
dman1982's Avatar
5.3 swap build so far
well i figured id go ahead and show my progress as of now, i got a 84 k10 dropping a 2004 5.3 with 4l60e and bolting up my 208 transfer case, Im waiting a buttload of parts to get in the mail, but here is a couple pics of what i got done so far
Sgt Dennis Heineman
USMC Aviation Ordnance
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
2009 Troy Built with a 42 Inch Deck
My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371
dman1982 is offline   Reply With Quote
Old 03-05-2014, 03:34 PM   #2
dman1982
dman1982's Avatar
Re: 5.3 swap build so far
heres a few more, the truck when i first got it and then after i put a lift on it
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-05-2014, 03:36 PM   #3
dman1982
dman1982's Avatar
i would love some advice on linkage and fuel delivery, with the fuel delivery i was going to get the fuel pump and sending unit out of a 2004 chevy truck and get the corvette fuel filter and mod my tank to take these any input? and as far as linkage I'm kinda lost
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-06-2014, 08:17 AM   #4
dman1982
dman1982's Avatar
any takers?
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-06-2014, 10:07 AM   #5
ls1nova71
ls1nova71's Avatar
I wouldn't go through all the work to mod your tank to make a more expensive pump when you can get an '87 tank and sender and add a higher pressure pump (Walbro255 would be a good choice). You would then use the Vette filter/regulator. You couldn't use that filter with an'04 pump anyway since they're internally regulated.
For the linkage you should be able to use the factory parts with some slight modification. Once you get the engine in you can hold it in position and see how far off it is.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 03-06-2014, 10:13 AM   #6
dman1982
dman1982's Avatar
so with the walbro 255 it goes inside the tank?
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-06-2014, 10:13 AM   #7
dman1982
dman1982's Avatar
i havnt messed with fuel injection too much
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-06-2014, 10:25 AM   #8
ls1nova71
ls1nova71's Avatar
Yes, if you get a tank and sender from an '87, they had in tank pumps, but were lower pressure so that's why you need a higher pressure pump.
Old 03-06-2014, 10:32 AM   #9
dman1982
dman1982's Avatar
gotcha...so in short I'm making this harder than it has to be
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-06-2014, 11:12 AM   #10
dman1982
dman1982's Avatar
is this the one i need? http://www.summitracing.com/interim/...ping#Estimator
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-06-2014, 11:30 AM   #11
ls1nova71
ls1nova71's Avatar
Something closer to this. http://www.summitracing.com/parts/vp...58-2/overview/ Keep in mind the hose length/shape may differ since it's going in a truck sender.
This is the type of sender you would need. The actual one will depend on which side your tank is on and how big it is. http://www.rockauto.com/catalog/more...291&cc=1059825
This should fit your existing tank, but it won't be baffled, and without baffling, the engine could momentarily starve for fuel under certain conditions (hard cornering or acceleration) when the fuel level is low.
Old 03-06-2014, 11:37 AM   #12
truckdude239
truckdude239's Avatar
i used an ac delo pump Amazon.com: ACDelco EP381 Fuel Pump: Automotive Amazon.com: ACDelco EP381 Fuel Pump: Automotive
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 03-06-2014, 11:39 AM   #13
dman1982
dman1982's Avatar
ordered....it was the same one that i put up haha
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-06-2014, 11:40 AM   #14
dman1982
dman1982's Avatar
Originally Posted by truckdude239 View Post
i went with the one listed above due to thats what everyone else is using (yes i would jump off a bridge if everyone else did too lol) but i havnt seen any complaints with this set up either
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-06-2014, 11:41 AM   #15
dman1982
dman1982's Avatar
that would have saved me some money tho
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-06-2014, 11:47 AM   #16
dman1982
dman1982's Avatar
so what year corvette filter do i have to get now? i got the pump check, sending unit check, filter....not check
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-06-2014, 11:54 AM   #17
ls1nova71
ls1nova71's Avatar
Get a Wix 33737. It's a 200 Vette filter. Any cheaper brand and it's a crap shoot if it will even work right out of the box. You DO have a returnless rail, right? 2004 you could get either depending on if it was flex fuel or not.
Old 03-06-2014, 12:04 PM   #18
dman1982
dman1982's Avatar
ill take a pic, but i don't think i do
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-06-2014, 12:08 PM   #19
ls1nova71
ls1nova71's Avatar
If you don't have a returnless rail, then you don't need the Vette filter. A returnless rail will only have one line, a return style will have two, a 3/8 feed and a 5/16 return. The dead giveaway is a vacuum hose from the intake to the fuel pressure regulator on the rail.
Old 03-06-2014, 12:10 PM   #20
dman1982
dman1982's Avatar
Here's one
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-06-2014, 12:11 PM   #21
dman1982
dman1982's Avatar
Another
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-06-2014, 12:12 PM   #22
dman1982
dman1982's Avatar
And a third
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-06-2014, 12:17 PM   #23
ls1nova71
ls1nova71's Avatar
A side shot would be easier to see it in, but that's a returnless rail. Get the Wix 33737.
Old 03-06-2014, 12:20 PM   #24
dman1982
dman1982's Avatar
thanks man....i tried getting all the angles in...off to the parts store...got a broken bolt in the side of the head where the manifold goes...errrrrr
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-07-2014, 03:09 PM   #25
dman1982
dman1982's Avatar
Well sitting around waiting on parts I did this....what's a good way to get sludge from underneath the valve cover?
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
